AR1206JR-071ML
AR1206JR-071ML
    YAGEO(国巨)
    贴片电阻 1206 1MΩ ±5% 1/4W ±100ppm/℃
AR1206JR-071ML 数据手册
DATA SHEET CHIP RESISTORS WITH NI/AU TERMINATIONS AR series 5%, 1% sizes 0402/0603/0805/1206 Product specification – Dec 23, 2008 V.7 Supersedes Date of Mar. 06, 2003 RoHS compliant Product specification Chip Resistor Surface Mount AR SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes AR0402 to AR1206 chip resistors with Ni/Au-terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. APPLICATIONS Power supply in small equipment Digital multi-meter Telecommunication Computer Automotive industry 2 9 0402/0603/0805/1206 (RoHS Compliant) SERIES YAGEO BRAND ordering code GLOBAL PART NUMBER ( PREFERRED ) AR XXXX X X X XX XXXX (1) (2) (3) (4) (5) (6) (1) SIZE 0402 0603 0805 1206 (2) TOLERANCE FEATURES RoHS compliant - - Products with lead free terminations meet RoHS requirements Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS Reducing environmentally hazardous wastes High component and equipment reliability Saving of PCB space None forbidden-materials used in products/production Halogen Free Epoxy F = ±1% J = ±5% (for Jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (5) TAPING REEL 07 = 7 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed resistance rules show in table of “Resistance rule of global part number”. (7) OPTIONAL CODE L = optional symbol (Note) Resistance rule of global part number Resistance code rule Example XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω ORDERING EXAMPLE The ordering code of a AR0603 chip resistor with gold terminations, value 56 X with ±1% tolerance, supplied in 7-inch tape reel is: AR0603FR-0756R(L). NOTE 1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Dec 23, 2008 V.7 Product specification Chip Resistor Surface Mount AR SERIES 3 9 0402/0603/0805/1206 (RoHS Compliant) PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER ( PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2322 XXX XXXXX (1) (2) Last digit of 12NC Resistance decade (3) (3) 0.01 to 0.0976 X 0.1 to 0.976 X 0 705 12xxx 1 to 9.76 X 8 - 706 2xxxx 10 to 97.6 X 9 - 705 19001 100 to 976 X 1 702 11xxx - 1 to 9.76 KX 2 1 to 10 MΩ 704 1xxxx - 10 to 97.6 KX 0Ω 3 - 702 19001 - 100 to 976 KX 4 SIZE TYPE START TOL. IN (1) (%) RESISTANCE RANGE PAPER/PE TAPE ON REEL (units) (2) 0402 RC31 2322 ±5% 1 to 10 MΩ - RC32 2322 ±1% 1 to 10 MΩ - 0Ω 2322 ±5% 1 to 10 MΩ RC22H 2322 ±1% Jumper 2322 Jumper 2322 0603 RC21 Last digit 5,000 10,000 7 0805 RC11 2322 ±5% 1 to 10 MΩ 730 11xxx - RC12 1 to 9.76 MX 2322 ±1% 1 to 10 MΩ 734 1xxxx - 5 - 0Ω 730 19001 - 10 to 97.6 MX 6 ±5% 1 to 10 MΩ 711 11xxx - Jumper 2322 1206 RC01 2322 RC02H 2322 ±1% 1 to 10 MΩ 729 1xxxx - Jumper 2322 - 0Ω 711 19001 - (1) The resistors have a 12-digit ordering code starting with 2322. Example: 0.02 X = 0200 or 200 0.3 X = 3007 or 307 1X = 1008 or 108 33 KX = 3303 or 333 10 MX = 1006 or 106 (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. (4) "L" is optional symbol (Note) . ORDERING EXAMPLE The ordering code of a RC22H resistor with gold terminations, value 56 X with ±1% tolerance, supplied in tape of 5,000 units per reel is: 232270415609 (L) or AR0603FR-0756R(L). NOTE 1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Dec 23, 2008 V.7 Product specification Chip Resistor Surface Mount AR SERIES 4 9 0402/0603/0805/1206 (RoHS Compliant) MARKING AR0402 ynsc007 No marking Fig. 1 AR0603 Fig. 2 Value = 12.4 KΩ E-96 series: 3 digits for 0603 ±1% EIA-96 marking method For 0603 ±1% E-24 series, one short bar under marking letter 563 ynsc003 Fig. 3 E-24 1% Value = 56 KΩ AR0603/0805/1206 E-24 series: 3 digits 03 YNSC001 Fig. 4 Value = 10 KΩ First two digits for significant figure and 3rd digit for number of zeros AR0805/1206 Both E-24 and E-96 series: 4 digits 00 YNSC004 Fig. 5 Value = 10 KΩ First three digits for significant figure and 4th digit for number of zeros For further marking information, please see special data sheet “Chip resistors marking”. www.yageo.com Dec 23, 2008 V.7 Product specification Chip Resistor Surface Mount AR 5 9 0402/0603/0805/1206 (RoHS Compliant) SERIES CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (Gold) are added. See fig. 6. OUTLINES For dimension see Table 1 overcoat Primary glass layer resistive layer (Jumper chip is a conductor) inner electrode H termination ceramic substrate I2 overcoat I1 DIMENSIONS Table 1 For outlines see fig. 6 TYPE L (mm) W (mm) W H (mm) I1 (mm) I2 (mm) AR0402 1.00 ±0.05 0.50 ±0.05 0.35 ±0.05 0.20 ±0.10 0.25 ±0.10 YNSC075 L AR0603 1.60 ±0.10 0.80 ±0.10 0.45 ±0.10 0.25 ±0.15 0.25 ±0.15 AR0805 2.00 ±0.10 1.25 ±0.10 0.50 ±0.10 0.35 ±0.20 0.35 ±0.20 Fig. 6 Chip resistor outlines AR1206 3.10 ±0.10 1.60 ±0.10 0.55 ±0.10 0.45 ±0.20 0.40 ±0.20 ELECTRICAL CHARACTERISTICS Table 2 TYPE Operating Max. RESISTANCE RANGE Temperature Working Range Voltage AR0402 AR0603 1 Ω ≤ R ≤ 10 MΩ AR0805 Zero ohm Jumper < 0.05 Ω AR1206 –55 °C to +155 °C CHARACTERISTICS Max. Dielectric Overload Withstanding Voltage Voltage 50 V 100 V 50 V 100 V Temperature Jumper Criteria Coefficient Rated Max. of Resistance Current Current 100 V 10 Ω < R ≤ 10 MΩ: ±100 ppm/°C 100 V 1.0 A 2.0 A 1.0 A 2.0 A 1 Ω ≤ R ≤ 10 Ω: ±200 ppm/°C 2.0 A 5.0 A 2.0 A 10.0A 150 V 300 V 300 V 200 V 500 V 500 V www.yageo.com Dec 23, 2008 V.7 Product specification Chip Resistor Surface Mount AR SERIES 6 9 0402/0603/0805/1206 (RoHS Compliant) FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL DIMENSION AR0402 AR0603 AR0805 AR1206 7" (178 mm) 10,000 5,000 5,000 5,000 Paper taping reel (R) NOTE 1. For Paper/PE tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”. FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE handbook, halfpage AR0402 to AR1206: –55 °C to +155 °C P (%Prated ) P OWER RATING Each type rated power at 70°C: MLB206_2 100 AR0402=1/16 W; AR0603=1/10 W; AR0805=1/8 W; AR1206=1/4 W. 50 RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V = √(P X R) or max. working voltage whichever is less 0 55 0 50 70 100 155 o Tamb ( C) Fig. 7 Maximum dissipation (Pmax) in percentage of rated power as a function of the operating ambient temperature (Tamb ) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (X) www.yageo.com Dec 23, 2008 V.7 Product specification Chip Resistor Surface Mount AR SERIES 7 9 0402/0603/0805/1206 (RoHS Compliant) TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Life/ Operational Life/ Endurance MIL-STD-202G-method 108A 1,000 hours at 70±5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required ±(2%+0.05 Ω) High Temperature Exposure/ Endurance at upper category temperature MIL-STD-202G-method 108A 1,000 hours at maximum operating temperature depending on specification, unpowered ±(1%+0.05 Ω) IEC 60115-1 4.25.3 JIS C 5202-7.11 No direct impingement of forced air to the parts Moisture Resistance MIL-STD-202G-method 106F IEC 60115-1 4.24.2 IEC 60115-1 4.25.1
AR1206JR-071ML
物料型号:YAGEO Phicomp 系列AR的片式电阻,包括0402、0603、0805、1206尺寸,符合RoHS标准。
器件简介:这些片式电阻采用厚膜工艺制造,具有Ni/Au端子,并符合RoHS要求,无铅端子,减少了环境有害废物,提高了组件和设备的可靠性,节省了PCB空间。
引脚分配:文档中没有明确提到引脚分配,但通常这类片式电阻为表面贴装元件,两端为金属端子。
参数特性: - 电阻值编码规则:例如XRXX表示1Q,9R76表示9.76欧姆。 - 公差:±1%或±5%。 - 包装类型:纸带卷装。 - 温度系数:基于规格书。 - 卷带尺寸:7英寸直径卷。
功能详解: - 电阻由高等级陶瓷基板上方构成,内部金属电极与厚膜电阻元件接触。 - 电阻元件由贵金属嵌入玻璃中,上面覆盖第二层玻璃以防止环境影响。 - 电阻经过激光修调至额定电阻值。 - 电阻覆盖有保护性环氧涂层,最后添加两个外部端子(金)。
应用信息:适用于小型设备电源、数字万用表、电信、计算机、汽车工业等领域。
封装信息:提供了0402、0603、0805、1206尺寸的详细尺寸数据,包括高度、长度、端子间距等。
电气特性:包括工作温度范围、最大工作电压、最大过载电压、介质耐压、电阻温度系数、额定电流、最大电流等。
测试和要求:包括寿命、操作寿命、耐温、耐湿、热冲击、短时间过载、耐焊接热、焊盘润湿、浸出等测试条件、程序和要求。
AR1206JR-071ML 价格&库存
很抱歉,暂时无法提供与“AR1206JR-071ML”相匹配的价格&库存,您可以联系我们找货
