Technical Data 10446
Effective September 2015
FP0505R
High frequency, high current power inductors
Applications
Servers
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
Desktop VRMs and EVRDs
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Load modules
Environmental Data
Description
High current carrying capacity
Low core loss
5.0 x 5.0mm footprint surface mount package in
an 4.8mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range (Component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
FP0505R
Product Specifications
Part Number8
OCL1
(nH) ±10%
FLL2 (nH)
minimum
Irms3
(amps)
Isat14
(amps)
Isat25
(amps)
Isat36
(amps)
DCR (mΩ)
±25% @ 20°C
K-factor7
100
68
30
34
26
24
0.38
1279
R1 Version
FP0505R1-R100-R
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.1Vrms, 0.0Adc, @ +25°C
2. Full Load Inductance (FLL) Test Parameters: 100kHz, 0.1Vrms, @ Isat, @ +25ºC
3. Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 125°C under worst case operating
conditions verified in the end application.
4. Isat1: Peak current for approximately 20% rolloff @ +25°C
5. Isat2: Peak current for approximately 20% rolloff @ +100°C
6. Isat3: Peak current for approximately 20% rolloff @ +125°C
7. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI * 10-3 Bp-p: (Gauss),
K: (K-factor from table), L: (Inductance in nH), ΔI (Peak to peak ripple current in Amps).
8. Part Number Definition: FP0505Rx-Rxxx-R
FP0505R = Product code and size
x= Version indicator
Rxxx= inductance value in μH, R= decimal point ,
-R suffix = RoHS compliant
b
Dimensions (mm)
a
0.20
min
5.0
max
1.2
±0.2
4.8
max
2.0
typ
Recommended Pad Layout
2
0505Rx
Rxxx
wwly R
5.0
max
1
1.7
1.8
Part marking: 0505Rx (x = Version Indicator), Rxxx = Inductance value in uH (R= decimal point)
wwly = date code, R = revision level
Tolerances are ±0.15 millimeters unless stated otherwise
All soldering surfaces to be coplanar within 0.1 millimeters
PCB tolerances are ±0.1 millimeters unless stated otherwise
DCR measured from point “a” to point “b”
Do not route traces or vias underneath the inductor
www.eaton.com/elx
1
1.4
±0.2
2.0
2
Schematic
2
FP0505R
Packaging information (mm)
Supplied in tape and reel packaging, 1,000 parts per 13” diameter reel
4.0
1.75
16.0
±0.3
1.5
2.0
dia
5
1.
a
di
12.0
7.5
5.2
5.2
5.0
User Direction of feed
Temperature rise vs. total loss
FP0505R1
60
Temperature Rise (°C)
50
40
30
0.10
0.20
0.30
0.40
0.50
0.60
0.70
Total Loss (W)
www.eaton.com/elx
3
FP0505R
Core loss vs. Bp-p
FP0505R1
1
300KHz
500KHz
Core Loss (mw)
100KHz
1MHz
0.1
200KHz
0.01
0.001
0.0001
100
1000
10000
B p-p (Gauss)
Inductance characteristics
FP0505R1-R100-R
120%
100%
% of OCL
80%
60%
-40°C
40%
+25°C
+100°C
20%
0%
+125°C
10
15
I DC (Amps)
4
www.eaton.com/elx
25
30
35
40
FP0505R
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP0505R1-R100-R”相匹配的价格&库存,您可以联系我们找货
