MM3Z2V0BW- MM3Z75BW
SMT-Type Zener Diode
FEATURES
Large selection of zener voltages: 2V ~ 75V
Tight voltage tolerance: ±2% for B-series
Ultra low-profile package well suited for automated assembly
MSL Class 1 compatible
to
r
APPLICATIONS
uc
General voltage regulation
Mobile & handheld systems
ORDERING INFORMATION
Marking
MM3Z2V0BW - MM3Z75BW
See Page 2
co
Part Number
nd
Package
mi
SOD-323
Parameter
Se
MAXIMUM RATING (@ TA = 25°C unless otherwise specified)
Symbol
Value
Unit
VF
0.9
V
PD
400
mW
RθJA
313
°C/W
Junction Temperature Range
TJ
-55 ~ +150
°C
Storage Temperature Range
TSTG
-65 ~ +150
°C
Forward Voltage @ IF=10mA
CR
O
Power Dissipation
JS
MI
Thermal Resistance (Junction-to-Ambient)
Note: Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint
www.jsmsemi.com
第1/4页
MM3Z2V0BW- MM3Z75BW
Zener Voltage Range
Type
Marking
VZT( at IZT )
Min( V )
Nom( V )
Dynamic
Impedance
IZT
Max( V )
Reverse Current
ZZT( at IZT )
IR
at VR
(mA)
Max (Ω)
Max( μA )
(V)
B0
1 .96
2.0
2 .04
5
100
120
0.5
MM3Z2V2BW
C0
2 . 16
2.2
2 .24
5
100
120
0.7
MM3Z2V4BW
1C
2 .35
2 .4
2 .45
5
100
120
1
MM3Z2V7BW
1D
2 .65
2.7
2 .75
5
110
120
1
MM3Z3V0BW
1E
2 .94
3.0
3 .06
5
120
50
1
MM3Z3V3BW
1F
3 .23
3.3
3 .37
5
130
MM3Z3V6BW
1H
3 .53
3.6
3 .67
5
130
10
1
MM3Z3V9BW
1J
3 .82
3.9
3 .98
5
130
5
1
MM3Z4V3BW
1K
4 .21
4.3
4 .39
5
130
MM3Z4V7BW
1M
4 .61
4.7
4 .79
5
130
MM3Z5V1BW
1N
5
5.1
5.2
5
MM3Z5V6BW
1P
5 .49
5.6
5 .71
5
MM3Z6V2BW
1R
6 .08
6.2
6 .32
5
MM3Z6V8BW
1X
6 .66
6.8
6 .94
5
MM3Z7V5BW
1Y
7 .35
7.5
7 .65
5
MM3Z8V2BW
1Z
8 .04
8.2
8 .36
MM3Z9V1BW
2A
8 .92
9.1
9 .28
MM3Z10BW
2B
9.8
10
MM3Z11BW
2C
10 .78
11
MM3Z12BW
2D
11 .76
12
MM3Z13BW
2E
12 .74
13
MM3Z15BW
2F
14 .7
MM3Z16BW
2H
15 .68
MM3Z18BW
2J
MM3Z20BW
2K
MM3Z22BW
2M
MM3Z24BW
2N
MM3Z27BW
2P
MM3Z30BW
2R
MM3Z33BW
2X
MM3Z36BW
2Y
MM3Z39BW
2Z
MM3Z43BW
MM3Z47BW
to
r
MM3Z2V0BW
1
1
130
2
1.5
80
1
2.5
50
1
3
30
0.5
3.5
30
0.5
4
5
0.5
5
5
30
0.5
6
5
30
0.1
7
11 .22
5
30
0.1
8
12 .24
5
35
0.1
9
13 .26
5
35
0.1
10
15
15 .3
5
40
0.1
11
16
16 .32
5
40
0.1
12
17 .64
18
18 .36
5
45
0.1
13
Se
mi
30
10 .2
co
nd
uc
5
2
5
50
0.1
15
22
22 .44
5
55
0.1
17
23 .52
24
24 .48
5
60
0.1
19
26 .46
27
27 .54
2
70
0.1
21
29 .4
30
30 .60
2
80
0.1
23
32 .34
33
33 .66
2
80
0.1
25
35 .28
36
36 .72
2
90
0.1
27
38 .22
39
39 .78
2
100
0.1
30
3A
42 . 14
43
43 .86
2
130
0.1
33
3B
46 .06
47
47 .94
2
150
0.1
36
MM3Z51BW
3C
49 .98
51
52 .02
2
180
0.1
39
MM3Z56BW
3D
54 .88
56
57 . 12
2
200
0.1
43
MM3Z62BW
3E
60 .76
62
63 .24
2
215
0.1
47
MM3Z68BW
3F
66 .64
68
69 .36
2
240
0.1
52
MM3Z75BW
3H
73 .5
75
76 .5
2
265
0.1
56
JS
MI
CR
O
19 .6
21 .56
( 1 ) VZT is tested with pulses (20 ms)
www.jsmsemi.com
第2/4页
MM3Z2V0BW- MM3Z75BW
JS
MI
CR
O
Se
mi
co
nd
uc
to
r
TYPICAL CHARACTERISTICS
0.020
0.015
0.010
0.100
IZ = 5m A
0.080
0.060
IZ = 50μA
0.005
0.040
0.000
TC of VZ(%°/C)
0.020
-0.010
0.000
-0.005 -0.015
-0.020
-0.020
10
40
50
60
70
80
VZ , ZENER VOLTAGE(V)
(V ) V O L T A G E Z , V Z E N E R
Fig. 5 Typical Temperature Coefficient of Zener Voltage
0246810
Fig. 6 Typical Temperature Coefficient of Zener Voltage
www.jsmsemi.com
第3/4页
MM3Z2V0BW- MM3Z75BW
PACKAGE OUTLINE (Unit: mm)
Plastic surface mounted package
K
C
SOD-323
Dimension
Min.
Max.
A
1.60
1.80
B
1.20
1.40
0.80
0.90
0.25
0.35
0.22
0.42
B
D
to
r
A
C
D
E
E
H
J
J
CR
O
0.10
0.05
0.15
2.55
2.75
0.63
Se
mi
MOUNTING PAD LAYOUT (Unit: mm)
JS
MI
0.02
co
nd
K
uc
H
0.83
1.60
2.85
PACKAGE INFORMATION
Part Number
MM3Z2V0BW – MM3Z75BW
Package
Shipping Quantity
SOD-323
3000pcs / Tape & Reel
www.jsmsemi.com
第4/4页
很抱歉,暂时无法提供与“MM3Z3V3BW”相匹配的价格&库存,您可以联系我们找货
