TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CN:
1512019901
CUSTOMER
PRODUCT TYPE
SMD GLASS SEALING XTAL 5.0*3.2
NOMINAL FREQ.
8.000000MHz
TXC P/N
AA08000004
REVISION
A1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
Pb used in sealing glass material is exempt from EU directive
FMT-DOC015
Issue Date: 03.18'14 VER.B
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
CN:
PRODUCT TYPE
NOMINAL FREQ.
8.000000MHz
TXC P/N
AA08000004
REVISION
A1
PE/RD
QA
MFG
20-Apr-11
20-Apr-11
20-Apr-11
1512019901
NOTE:
(1)The green product standard set by TXC is based upon the international standards. Related information is
publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green
product quality system directives at the time.
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
MSL:Level 1
RoHS Compliant
FMT-DOC015
TXC P/N:
TXC CORPORATION
Rev
Revise page
A1
N/A
FMT-DOC015
Revise contents
Initial released
AA08000004
REVISION:
A1
PAGE:
1
Date
Ref.No.
Reviser
10-May-11
N/A
Xiaoyan Jiang
TXC CORPORATION
TXC P/N:
AA08000004
REVISION:
A1
PAGE:
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS
P.3
2
FACTORY LOCATION
P.3
3
DIMENSIONS
P.4
4
MARKING
P.4
5
SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS
FMT-DOC015
P.8~9
2
TXC P/N: AA08000004
TXC CORPORATION
REVISION:
A1
PAGE: 3
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.054±0.05 g/pcs
Parameters
SYM.
Electrical Spec.
MIN
TYP
MAX
Notes
UNITS
FL
8.000000
MHz
Fundamental
CL
16
pF
±30
ppm
at 25 ℃ ± 3 ℃
±30
ppm
Over Operating Temp. Range (Reference 25℃)
1
Nominal Frequency
2
Oscillation Mode
3
Load Capacitance
4
Frequency Tolerance
5
Frequency Stability
6
Operating Temperature
7
Aging
-40
100
uW
85
±3
ppm
1st Year
8
Drive Level
DL
9
Effective Resistance Rr
Rr
150
Ω
10 Shunt Capacitance C0
C0
pF
11 Insulation Resistance
500
MΩ
12 Storage Temperature Range
-40
85
at DC 100V
■ FACTORY LOCATION
TXC (NINGBO) CORPORATION
NO.189 Huang Shan West Road, Beilun District,
Ningbo Zhejiang China
FMT-DOC015
TXC P/N:
TXC CORPORATION
AA08000004
REVISION:
A1
PAGE:
■ DIMENSIONS
(Unit:mm)
*Coplanarity of solderable areas Camber 0.10 mm Max
■ MARKING
TXC □□□□
TXC Logo
Frequency Code
MHz=
Ex.: 8.000000
8.00
Lot Code
Line Code
Date Code
Date Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
M
*This date code will be cycled every four years
■ SUGGESTED REFLOW PROFILE
Solder melting point :220 ± 10 ℃ , 60 sec. Min
Peak Temperature: 260 ± 5 ℃ , 10 sec. Max.
10 sec
260
220
180
150
■ SUGGESTED MANUAL SOLDER CONDITION
Temperature: 350 ± 10 ℃
Time: 3 sec.
Time (sec)
120 sec
60 sec
Re-solder times: twice
FMT-DOC015
4
TXC P/N:
TXC CORPORATION
AA08000004
A1
REVISION:
PAGE:
5
■ STRUCTURE ILLUSTRATION
COMPONENTS
NO
MATERIALS
FINISH/SPECIFICATIONS
Base(Package)
Ceramic (AI2O3)
Ceramic (AI2O3)
PAD
Au
Tungsten metalize
1
Cap
2
3
+ Ni plating
+ Au plating
4
Crystal blank
SiO2
5
Conductive adhesive
Resin+Ag
6
Electrode
Noble Metal
7
Sealing Glass
Glass(PbO)
FMT-DOC015
TXC P/N:
TXC CORPORATION
AA08000004
REVISION:
A1
PAGE: 6
■ EMBOSS CARRIER TAPE & REEL
F
E
B
H
G
DIMENSIONS
A
1.65±0.10
B
C
Feeding
D
C
A
D
E
F
G
H
5.40±0.10 3.50±0.10 8.00±0.10 12.00±0.30 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm)
REMARK :
Products put in 1000pcs
Trailer
160mm(Min)
Empty Sealed
Leader
160mm(Min)
230mm(Min)
User direction of feed
DIMENSIONS
FMT-DOC015
L
L1
W
W1
180±1.00
13±0.50
16.5±0.20
12±0.10
(UNIT:mm)
TXC CORPORATION
TXC P/N:
AA08000004
REVISION:
A1
PAGE:
7
■ PACKING
Reel Quantity :
1. Reel X 5 (5 Reels x1 )
2. Reel X 10 (10 Reels x1 )
3. Reel X 20 (10 Reels x2 )
4. Reel X 40 (10 Reels x4 )
Label B
Box Size:
1. L200 X W200 X H140mm
2. L200 X W200 X H250mm
3. L400 X W200 X H250mm
4. L400 X W400 X H280mm
Tape
Tape
Label A
Label B
QA Pass
(Label A) Size:100 X 100mm
(Label B) Size:80 X 40mm
[STORAGE]
1.The storage time to be 1 year maximum.
2.Don't be caught in the rain.
3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine.
4.If customers have special requirements, we can paste labels according to it.
FMT-DOC015
TXC P/N:
TXC CORPORATION
AA08000004
REVISION:
A1
PAGE:
■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant)
1.Mechanical Endurance
1.1
1.2
Test Methods
Test Item
No.
Mechanical Shock
Vibration
Test Criteria
2000 G , 0.3 m Sec. ,3 times for all 3 directions.
BC
Frequency range
10 ~ 2000 Hz
Acceleration
20G
Amplitude
1.52mm
Sweep time
20 minute
Pendicular axes each test time
4 hours
BC
(Total test time 12 hours)
F
1.3
Terminal Strength
17.7N force for 60sec +/-1sec.
1.4
Board Flex
Duration time:60 Sec Minimum,Deviation:3mm
1.5
Solderability
BC
Temperature
245 oC +/- 5oC
Immersing depth
0.5 mm minimum
Immersion time
5 +/- 0.5 seconds
Flux
Rosin resin methyl alcohol
E
solvent ( 1 : 4 )
2.Environmental Endurance
Test Item
No.
Test Methods
SPEC
o
2.1
Resistance To Soldering Test temperature
Heat
Test time
2.2
High Temp. Storage
+ 85℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
2.3
Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
260 +/- 5 C
BCD
10 +/- 1 sec.
-40℃~85℃,for 1000 cycles.
B C D
1 cycle
85+/-3 0C
2.4
Temperature cycle
25 0C
-40+/-3 C
BCD
15 min.
15 min.
2min.Max
2.5
Operational Life
1000 hrs @ 85± 3°C. Rated VDD applied with 1 MΩ.
BCD
2.6
High Temp&Humidity
85℃ ± 3℃ , RH 85% , 1000 Hrs
BCD
FMT-DOC015
8
TXC CORPORATION
TXC P/N:
AA08000004
REVISION
A1
PAGE: 9
Specifications
A
Frequency change: Within ±5ppm or in customer's specification.
B
Frequency change: Within ±10ppm or in customer's specification.
C
Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value).
D
After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour, and
measured.
E
Minimum 95% of immersed terminal shall be covered with new uniform solder.
Measurement condition
FMT-DOC015
很抱歉,暂时无法提供与“AA08000004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.88576
- 30+1.81936
- 100+1.68656
- 500+1.55376
- 1000+1.48736
