RLD30P500UF
RLD30P500UF
    PTTC(聚鼎)
    FUSE_14X3MM_TM
    RLD 30V UF系列PTC器件
RLD30P500UF 数据手册
RLD 30V UF Series PTC Devices RLD 30V UF Series PTC Devices Description The 30V UF series provides radial resettable overcurrent protection with holding current from 0.9A to 9A. This series is suitable for applications with higher holding currant and higher working voltage up to 30V. Features  RoHS compliant and lead-free  30Vdc operating voltage  Halogen-free  40A maximum short current  Fast time-to-trip  Meet all USB protection requirements Applications  Powered USB for POS and IPC  Computers & peripherals  USB hubs, ports and peripherals  Automotive applications  General electronics  Motor protection Agency Approval and Environmental Compliance Agency File Number Regulation Standard E201431 2011/65/EU R50103284 IEC 61249-2-21:2003 Electrical Characteristics Maximum Time To Trip Current Time (A) (Sec.) Part Number Ihold (A) Itrip (A) Vmax (Vdc) Imax (A) Pd typ (W) RLD30P090UF 0.90 1.80 30 40 0.6 4.50 RLD30P110UF 1.10 2.20 30 40 0.7 5.50 RLD30P135UF 1.35 2.70 30 40 0.8 RLD30P160UF 1.60 3.20 30 40 RLD30P185UF 1.85 3.70 30 RLD30P250UF 2.50 5.00 RLD30P300UF 3.00 RLD30P400UF Resistance Agency Approval Rmin (Ω) R1max (Ω) 5.9 0.070 0.220   6.6 0.050 0.170   6.75 7.3 0.040 0.130   0.9 8.00 8.0 0.030 0.110   40 1.0 9.25 8.7 0.030 0.090   30 40 1.2 12.50 10.3 0.020 0.070   6.00 30 40 2.0 15.00 10.8 0.020 0.080   4.00 8.00 30 40 2.5 20.00 12.7 0.010 0.050   RLD30P500UF 5.00 10.00 30 40 3.0 25.00 14.5 0.010 0.050   RLD30P600UF 6.00 12.00 30 40 3.5 30.00 16.0 0.005 0.040   RLD30P700UF 7.00 14.00 30 40 3.8 35.00 17.5 0.005 0.030   RLD30P800UF 8.00 16.00 30 40 4.0 40.00 18.8 0.005 0.020   RLD30P900UF 9.00 18.00 30 40 4.2 40.00 20.0 0.005 0.020   新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Note on Electrical Characteristics ◼ Vocabulary Ihold = Hold current: maximum current device will pass without tripping in 23ºC still air. Itrip = Trip current: minimum current at which the device will trip in 23 ºC still air. Vmax = Maximum voltage device can withstand without damage at rated current (I max) Vop = Maximum continuous voltage device can withstand without damage at rated current (I max) Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax) Pd typ = Typical power dissipated from device when in the tripped state at 23 ºC still air. Rmin = Minimum resistance of device in initial (un-soldered) state. R1max = Maximum resistance of device at 23 ºC measured one hour after tripping or reflow soldering of 260 ºC for 20 sec. ◼ Caution: Operation beyond the specified rating may result in damage and possible arcing and flame. ◼ Specifications are subject to change without notice. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Polymeric PTC Selecting Guide ◼ Determine the following operating parameters for the circuits:  Normal operating current (Ihold) ․ Maximum interrupt current (Imax)  Maximum circuit voltage (Vmax) ․ Normal operating temperature surrounding device (minºC/maxºC) ◼ Select the device form factor and dimension suitable for the application:  Surface Mount Device (SMD) ․ Axial Leaded Device (ALD)  Radial Leaded Device (RLD) ․ DISC Device ․ Other Customized Form Factors ◼ Compare the maximum rating for Vmax and Imax of the PPTC device with the circuit in application and make sure the circuit’s requirement does not exceed the device rating. ◼ Check that PPTC device’s trip time (time-to-trip) will protect the circuit. ◼ Verify that the circuit operating temperature is within the PPTC device’s normal operating temperature range. ◼ Verify the performance and suitability of the chosen PPTC device in the application. ◼ Mechanical Stress  PPTC devices will undergo a thermal expansion during fault condition. If PPTC devices are installed or placed in an application where the space between PPTC devices and the surrounding materials (e.g., covering materials, packaging materials, encapsulate materials and the like) is insufficient, it will cause an inhibiting effect upon the thermal expansion. Pressing, twisting, bending and other kinds of mechanical stress will also adversely affect the performance of the PPTC devices, and shall not be used or applied. ◼ Chemical Pollutants  Silicone-based oils, oils, solvents, gels, electrolytes, fuels, acids, and the like will adversely affect the properties of PPTC devices, and shall not be used or applied. ◼ Electronic and Thermal Effect  PPTC devices are secondary protection devices and are used solely for sporadic, accidental over-current or over-temperature error condition, and shall NOT be used if or when constant or repeated fault conditions (such fault conditions may be caused by, among others, incorrect pin-connection of a connector) or over-extensive trip events may occur.  PTTC devices are different from fuses and, when a fault condition occurs, will go into high-resistance state and do not open circuit, in which case the voltage at such PPTC devices may reach a hazardous level.  Operation over the maximum rating or other forms of improper use may cause failure, arcing, flame and/or other damage to the PPTC devices.  Conductive material contamination, such as metal particle, may induce shortage, flame or arcing.  Due to the inductance, the operation circuits may generate a circuit voltage (Ldi/dt) above the rated voltage of PPTC devices, which shall not be used under such circumstances. ◼ General  Customers shall evaluate and test the properties of PPTC devices independently to verify and ensure that their individual applications will be met.  The performance of PPTC devices will be adversely affected if they are improperly used under electronic, thermal and/or mechanical procedures and/or conditions non-conformant to those recommended by manufacturer.  Customers shall be responsible for determining whether it is necessary to have back-up, failsafe and/or fool-proof protection to avoid or minimize damage that may result from extra-ordinary, irregular function or failure of PPTC devices.  Any and all responsibilities and liabilities are disclaimed if any item under this notice of warning is not complied with. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Average Time-to-Trip Curves M L K J I H G F E D C A= B= C= D= E= F= G= H= I= J= K= L= M= RLD30P090UF RLD30P110UF RLD30P135UF RLD30P160UF RLD30P185UF RLD30P250UF RLD30P300UF RLD30P400UF RLD30P500UF RLD30P600UF RLD30P700UF RLD30P800UF RLD30P900UF B A 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Thermal Derating Curve Thermal Derating Table Recommended Hold Current (A) vs. Ambient Temperature (ºC) Part Number Ambient Operation Temperature -40 ºC -20 ºC 0 ºC 23 ºC 40 ºC 50 ºC 60 ºC 70 ºC 85 ºC RLD30P090UF 1.31 1.17 1.04 0.90 0.75 0.69 0.61 0.55 0.47 RLD30P110UF 1.60 1.43 1.27 1.10 0.91 0.85 0.75 0.67 0.57 RLD30P135UF 1.96 1.76 1.55 1.35 1.12 1.04 0.92 0.82 0.70 RLD30P160UF 2.32 2.08 1.84 1.60 1.33 1.23 1.09 0.98 0.83 RLD30P185UF 2.68 2.41 2.13 1.85 1.54 1.42 1.26 1.13 0.96 RLD30P250UF 3.63 3.25 2.88 2.50 2.08 1.93 1.70 1.53 1.30 RLD30P300UF 4.35 3.90 3.45 3.00 2.49 2.31 2.04 1.83 1.56 RLD30P400UF 5.80 5.20 4.60 4.00 3.32 3.08 2.72 2.44 2.08 RLD30P500UF 7.25 6.50 5.75 5.00 4.15 3.85 3.40 3.05 2.60 RLD30P600UF 8.70 7.80 6.90 6.00 4.98 4.62 4.08 3.66 3.12 RLD30P700UF 10.15 9.10 8.05 7.00 5.81 5.39 4.76 4.27 3.64 RLD30P800UF 11.60 10.40 9.20 8.00 6.64 6.16 5.44 4.88 4.16 RLD30P900UF 13.05 11.7 10.35 9.00 7.47 6.93 6.12 5.49 4.68 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 6 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Physical Dimensions (mm.) Fig. 3 Fig. 2 Fig. 1 Fig. 5 Fig. 4 A B C D E Y (Max.) (Max.) (Typ.) (Min.) (Max.) (Typ.) RLD30P090UF 7.4 12.2 5.1±0.7 7.6 3.0 RLD30P090UF-S 7.4 10.6 5.1±0.7 7.6 3.0 RLD30P110UF 7.4 14.2 5.1±0.7 7.6 RLD30P110UF-S 7.4 12.0 5.1±0.7 RLD30P135UF 8.9 13.5 5.1±0.7 RLD30P135UF-S 8.9 11.3 RLD30P160UF 8.9 RLD30P160UF-S Part Number Fig. Lead Dia. 1.0 3 0.51 1.0 4 0.51 3.0 1.0 3 0.51 7.6 3.0 1.0 4 0.51 7.6 3.0 1.0 3 0.51 5.1±0.7 7.6 3.0 1.0 4 0.51 15.2 5.1±0.7 7.6 3.0 1.0 3 0.51 8.9 12.8 5.1±0.7 7.6 3.0 1.0 4 0.51 RLD30P185UF 10.2 15.7 5.1±0.7 7.6 3.0 1.0 3 0.51 RLD30P185UF-S 10.2 13.8 5.1±0.7 7.6 3.0 1.0 4 0.51 RLD30P250UF 11.4 18.3 5.1±0.7 7.6 3.0 1.0 3 0.51 RLD30P250UF-S 11.4 16.0 5.1±0.7 7.6 3.0 1.0 4 0.51 RLD30P300UF 11.4 19.2 5.1±0.7 7.6 3.0 1.2 3 0.81 RLD30P300UF-S 11.4 15.2 5.1±0.7 7.6 3.0 1.2 4 0.81 RLD30P400UF 14.0 22.0 5.1±0.7 7.6 3.0 1.2 3 0.81 RLD30P400UF-S 14.0 17.3 5.1±0.7 7.6 3.0 1.2 4 0.81 RLD30P500UF 14.0 25.6 10.2±1.0 7.6 3.0 1.2 3 0.81 RLD30P500UF-S 14.0 23.0 10.2±1.0 7.6 3.0 1.2 4 0.81 RLD30P600UF 16.5 26.8 10.2±1.0 7.6 3.0 1.2 3 0.81 RLD30P600UF-S 16.5 23.4 10.2±1.0 7.6 3.0 1.2 4 0.81 RLD30P700UF 19.1 28.6 10.2±1.0 7.6 3.0 1.2 3 0.81 RLD30P700UF-S 19.1 25.0 10.2±1.0 7.6 3.0 1.2 4 0.81 RLD30P800UF 21.6 31.1 10.2±1.0 7.6 3.0 1.2 3 0.81 RLD30P800UF-S 21.6 26.9 10.2±1.0 7.6 3.0 1.2 4 0.81 RLD30P900UF 24.1 31.6 10.2±1.0 7.6 3.0 1.2 3 0.81 RLD30P900UF-S 24.1 27.0 10.2±1.0 7.6 3.0 1.2 4 0.81 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 7 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Recommend Pad Layout (mm) A B D1 D2 (Typ.) (Typ.) (Typ.) (Typ.) RLD30P090UF 5.1 1.0 1.0 2.5 Part Number RLD30P110UF 5.1 1.0 1.0 2.5 RLD30P135UF 5.1 1.0 1.0 2.5 RLD30P160UF 5.1 1.0 1.0 2.5 RLD30P185UF 5.1 1.0 1.0 2.5 RLD30P250UF 5.1 1.0 1.0 2.5 RLD30P300UF 5.1 1.2 1.5 3.5 RLD30P400UF 5.1 1.2 1.5 3.5 RLD30P500UF 10.2 1.2 1.5 3.5 RLD30P600UF 10.2 1.2 1.5 3.5 RLD30P700UF 10.2 1.2 1.5 3.5 RLD30P800UF 10.2 1.2 1.5 3.5 RLD30P900UF 10.2 1.2 1.5 3.5 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 8 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Wave Soldering Parameters Profile Feature Condition (Note 1) Average Ramp-Up Rate (Tsmax to TP) 4ºC/second max. Preheat -Temperature Min (Tsmin) 100ºC -Temperature Max (Tsmax) 125ºC -Time (Tsmin to Tsmax) 60-180 seconds Peak Temperature (TP) 265ºC Max Time at Peak Temperature (tP) 5 seconds Ramp-Down Rate 6 ºC /second max. Time 25ºC to Peak Temperature 5 minutes max. 0ºC ~35ºC, ≦70%RH, 2 Years Storage Condition (Note 2) Note: 1. If the wave soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. 2. If the storage condition exceeds the suggest requirement or the storage time exceeds 2 years, then, 110°C/4hrs baking before wave soldering assembly process is recommended to remove the residual moisture contained in the epoxy coating. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 9 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Environmental Specifications Operating Temperature -40ºC to +85 ºC Maximum Device Surface Temperature in Tripped State 125ºC Passive Aging +85ºC , 1000 hours ±5% typical resistance change Humidity Aging +85ºC , 85%R.H. 1000 hours ±5% typical resistance change Thermal Shock MIL-STD-202 Method 107G +85ºC /-40ºC 10 times -30% typical resistance change Solvent Resistance MIL-STD-202, Method 215 No change Vibration MIL-STD-883C, Method 2007.1, Condition A No change Moisture Sensitivity Level Level 1, J-STD-020C Physical Specifications Lead Material P090UF-185UF: Tin-plated copper clad steel P250UF-P900UF: Tin-plated copper Soldering Characteristics Solderability per MIL-STD-202, Method 208E Insulating Material Cured, flame retardant epoxy polymer meets UL94V-0 requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 10 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Tape and Reel Specifications: EIA468-B/IEC60286-2 Dimension Description Carrier tape width Hold down tape width Top distance between tape edges Sprocket hole position Sprocket hole diameter* Abscissa to plane(straight lead) Abscissa to plane(kinked lead) Abscissa to top P090UF-P185UF Abscissa to top P250UF-P900UF Overall width without lead protrusion: P090UF-P185UF Overall width without lead protrusion: P250UF-P900UF Overall width with lead protrusion: P090UF-P185UF Overall width with lead protrusion: P250UF-P900UF Lead protrusion Protrusion of cut out Protrusion beyond hold-down tape Sprocket hole pitch: P090UF-P400UF Sprocket hole pitch: P500UF-P900UF Pitch tolerance Device pitch: P090UF-P300UF Device pitch: P400UF-P900UF Tape thickness Tape thickness with splice Splice sprocket hole alignment Body lateral deviation Body tape plane deviation Ordinate to adjacent component lead*: P090UF-P400UF Ordinate to adjacent component lead*: P500UF-P900UF Lead spacing: P090UF-P400UF Lead spacing: P500UF-P900UF Reel width P090UF-P300UF Reel width P400UF-P900UF Reel diameter Space between flanges less device* Arbor hole diameter Core diameter* Box Consecutive missing places Empty places per reel EIA Mark IEC Mark W W4 W6 W5 D0 H H0 H1 H1 C1 W W0 W2 W1 D0 H H0 H1 C2 L1 L l2 P0 P0 l1 L l2 P0 P0 t t1 t Δh Δp P1 Δh Δp P1 F F w2 w2 a w1 c n F F w w d f h Dim.(mm) Dimensions Tol.(mm) 18 11 3 9 4 18.5 16 32.2 47.5 42.5 57 43.2 58 1.0 11 Not specified 12.7 25.4 20 consecutive. 12.7 25.4 0.9 2.0 0 0 0 3.81 7.62 5.08 10.18 56 63.5 370 4.75 26 91 56/372/372 None 0.1%max. -0.5/+1.0 min. max. -0.5+0.75 -0.32/+0.2 +3.0 +0.5 max. max. max. max. max. max. +0.3 +0.5 +1 max. max. +0.3 +1.0 +1.3 +0.7 +0.7 +0.8 +0.8 max. max. max. -3.25/+9.25 +12.0 max. max. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 11 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Tape and Reel Specifications: EIA468-B/IEC60286-2 (Continued) Fig. 1 Fig. 2 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 12 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Marking on Device Polytronics Trademark Voltage rating Current rating & series code Date code Part Ordering Number System RLD 30 P □□□ UF - □□ Packaging Style (B: Bulk; TA: Tape & Ammo; TR: Tape & Reel) 30Vdc Lead- Free Product Series Holding Current Rating Polytronics Symbol Voltage Rating Radial Leaded Device 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 13 of 14 2018/10/25 Revision: Q RLD 30V UF Series PTC Devices Packaging Quantity Part Number RLD30P090UF RLD30P110UF RLD30P135UF RLD30P160UF RLD30P185UF RLD30P250UF RLD30P300UF RLD30P400UF RLD30P500UF RLD30P600UF RLD30P700UF RLD30P800UF RLD30P900UF Ordering Code RLD30P090UF-B RLD30P090UF-TR RLD30P090UF-TA RLD30P110UF-B RLD30P110UF-TR RLD30P110UF-TA RLD30P135UF-B RLD30P135UF-TR RLD30P135UF-TA RLD30P160UF-B RLD30P160UF-TR RLD30P160UF-TA RLD30P185UF-B RLD30P185UF-TR RLD30P185UF-TA RLD30P250UF-B RLD30P250UF-TR RLD30P250UF-TA RLD30P300UF-B RLD30P300UF-TR RLD30P300UF-TA RLD30P400UF-B RLD30P400UF-TR RLD30P400UF-TA RLD30P500UF-B RLD30P500UF-TR RLD30P500UF-TA RLD30P600UF-B RLD30P600UF-TR RLD30P600UF-TA RLD30P700UF-B RLD30P700UF-TR RLD30P700UF-TA RLD30P800UF-B RLD30P800UF-TR RLD30P800UF-TA RLD30P900UF-B RLD30P900UF-TR RLD30P900UF-TA Bag Quantity Reelpack Quantity Ammopack Quantity 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 200 1000 1000 200 1000 1000 200 1000 1000 200 1000 1000 100 1000 1000 100 1000 1000 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 14 of 14 2018/10/25 Revision: Q
RLD30P500UF 价格&库存
很抱歉,暂时无法提供与“RLD30P500UF”相匹配的价格&库存,您可以联系我们找货
