MFS
Sub-miniature Switches
RoHS Compliant
■Common Specifications
●Initial contact resistance
Measured at 1.5mA 200 µVAC 1kHz
●Dilectric strength
Measurement at 500 VAC.
●Insulation Resistance
Measured at 500VDC
●Operating temperature range
−10℃〜+70℃
■Part Numbering
MFS 101 D
− 6 − Z
Switching function
Registration number
Number of poles
Series code
101
1-pole
D
201
2-poles
EA
401
4-poles
1−pole or 3−poles
N
2 poles or 4−poles
PA
MFS101D−6−Z
ON - ON
ON-ON-ON
ON - ON
ON-ON-ON
■Specifications
Non-shorting
Max.
Min.
Rating
2
2.5
3
1.2
10
2-φ1.2
2
2
8
■PC Hole Layouts
1.2
20mΩ Max.
Dielectric strength
AC500V 1 minute
Insulation resistance
100MΩ Min.
Electrical life
5,000 cycles
Operating force
0.98〜2.94N
Switch timing
Non-shorting
2.5 (Stroke)
3
3.3
Max.
(Top view)
DC10V 0.3A(Resistive load)
DC5V 10mA(Resistive load)
Switching function
(Viewed from A)
Circuit diagram
5
5
2.5
(1)
ON
ON
2−3
2−1
2.5
0.3
0.5
Terminal numbers are not shown on the switch.
No. of
terminals
φ0.7
(1)
(2)
8
(3)
3
(2)
(3)
MFS
MFS101D−8−Z
■ Specifications
shorting
Max.
Rating
Min.
■PC Hole Layouts
(Top view)
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles at DC30V 0.3A
100cycles at AC30V 2A
Operating force
2.45±0.98 N
Switch timing
Shorting
Switching function
(Viewed from A)
10
8
2.5(Stroke)
C0.5
2−1
2−3
3
Max.
Min.
DC12V 0.3A(Resistive load)
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
0.98±2.94N
Switch timing
Non-shorting
8.1
5
1.9
φ1.2
φ0.7
0.3
2.7
3.1
0.5
(Top view)
3.3
0.8
3
■PC Hole Layouts
ON
Rating
3
1.2
ON
No. of
Circuit diagram terminals
■ Specifications
Non-shorting
0.4
MFS101D−9−Z
DC30V 0.3A
AC30V 2A (Resistive load)
0.8
1.5
2
2
Switching function
(Viewed from A)
ON
ON
2−1
2−3
No. of
3
☆ MFS101D−10−Z
■ Specifications
Non-shorting
20mΩ Max.
3.5
Dielectric strength
AC500V 1 minute
2
100MΩ Min.
Electrical life
5,000 cycles
Operating force
2.94±1.96N
Switch timing
Non-shorting
2
(Stroke)
2
■PC Hole Layouts
1
2.5
0.3
0.5
2
2
3.4
→Page 531.
☆:Semi-standard products.
Switching function
(Viewed from A)
Circuit diagram
No. of
terminals
0.5
2
2.5
4
(Top view)
shorting
DC30V 0.3A(Resistive load)
2
1
Max.
Min.
Rating
8.8
ON
ON
2−3
2−1
3
MFS
MFS101D−14−Z
■ Specifications
Non-shorting
Max.
Min.
Rating
■Panel Cut−Out Dimensions
(Top view)
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
1.96±0.98N
Switch timing
Non-shorting
Switching function
(Viewed from A)
ON
ON
2−1
2−3
No. of
3
MFS
☆MFS101EA−Z
※[Note] See below.
■ Specifications
Max.
Rating
Min.
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
Operating force
2.45±0.98N 1.47±0.98N
Switch timing
■PC Hole Layouts
(Top view)
Undefined
Switching function
Circuit diagram
(Viewed from A)
ON
ON
ON
3−1
3−2
3−4
MFS201N−Z
DC30V 0.3A
No. of
terminals
4
: Operating force from the center to the outer side (right or left).
: Operating force from the outer side (right or left) to the center.
■ Specifications
Non-shorting
Max.
Min.
Rating
AC125V 1A ・ DC30V 1A
30mΩ Max.
Dielectric strength
AC500V 1 minute
300MΩ Min.
Electrical life
5,000 cycles
Operating force
0.98〜4.9N
Switch timing
Non-shorting
(Top view)
Switching function
(Viewed from A)
ON
ON
2−1
5−4
2−3
5−6
Circuit diagram
No. of
terminals
6
■ Specifications
MFS201N−4−Z
Non-shorting
Max.
Min.
Rating
■PC Hole Layouts
20mΩ Max.
Dielectric strength
AC500V 1 minute
300MΩ Min.
Electrical life
5,000 cycles
Operating force
1.47〜4.41N
Switch timing
Non-shorting
(Top view)
Switching function
(Viewed from A)
ON
ON
2−1
5−4
2−3
5−6
Circuit diagram
No. of
terminals
6
※:Please note that MFS101EA-Z can be either Shorting or Non-shorting.
MFS
Non-shorting
■ Specifications
17
(2)
(3)
(4)
(5)
(6)
3 ストローク
5.2
20mΩ Max.
Dielectric strength
AC500V 1 minute
300MΩ Min.
Electrical life
5,000 cycles
Operating force
1.47〜4.41N
Switch timing
Non-shorting
5
4
Max.
Min.
Rating
4
(1)
7.5
MFS201N−9−Z
(Top view)
9
■PC Hole Layouts
2
(2)
(5)
(3)
(6)
0.6
4
2.5
(1)
(2)
1
0.5
4
No. of
terminals
Circuit diagram
3
(1)
(4)
Switching function
(Viewed from A)
ON
ON
2−1
5−4
2−3
5−6
(3)
6
(4)
(5)
(6)
MFS201N−16−Z
■ Specifications
Non-shorting
Max.
Min.
Rating
■PC Hole Layouts
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
2.94±1.47N
Switch timing
Non-shorting
(Top view)
Switching function
(Viewed from A)
5.8
1.6
ON
ON
2−3
5−6
2−1
5−4
Circuit diagram
No. of
terminals
6
MFS201N−19−Z
■ Specifications
Shorting
Max.
Min.
Rating
■PC Hole Layouts
(Top view)
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
2.45±0.98N
Switch timing
Shorting
Switching function
(Viewed from A)
ON
ON
2−1
5−4
2−3
5−6
Circuit diagram
No. of
terminals
6
shorting
→Page 506.
MFS
★ MFS201N−20−Z
■ Specifications
Shorting
Max.
Min.
Rating
■PC Hole Layouts
(Top view)
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
4.41±1.47N
Switch timing
Shorting
Switching function
(Viewed from A)
ON
ON
2−1
5−4
2−3
5−6
Circuit diagram
No. of
terminals
6
MFS201N−21−Z
Non-shorting
■ Specifications
Max.
Min.
Rating
■PC Hole Layouts
(Top view)
★:Made to order products.
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
2.45±0.98N
Switch timing
Non-shorting
Switching function
(Viewed from A)
ON
ON
2−1
5−4
2−3
5−6
Circuit diagram
No. of
terminals
6
MFS
MFS201N−23−Z
■ Specifications
Non-shorting
Max.
Min.
Rating
Initial contact resistance 20mΩ Max.
■PC Hole Layouts
(Top view)
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
3.92±2.45N
Switch timing
Non-shorting
Switching function
(Viewed from A)
ON
ON
2−3
5−6
2−1
5−4
No. of
terminals
Circuit diagram
6
MFS201N−24−Z
■ Specifications
Non-shorting
Max.
Min.
Rating
9.8
5
Dielectric strength
AC500V 1 minute
1.5
100MΩ Min.
Electrical life
5,000 cycles
Operating force
1.96±0.98N
Switch timing
Non-shorting
2
2
(Stroke)
1.5
1
0.5
2
2.4
2.4
4
(Top view)
2
■PC Hole Layouts
0.3
Switching function
(Viewed from A)
Circuit diagram
No. of
terminals
0.5
2
2
ON
ON
2−3
5−6
2−1
5−4
6
shorting
→Page 506.
MFS
★MFS201PA−4−Z
■ Specifications
※[Note] See below.
Max.
Min.
Rating
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
Switch timing
■PC Hole Layouts
(Top view)
Undefined
Switching function
(Viewed from A)
Circuit diagram
ON
ON
ON
3−1
7−5
3−2
7−6
3−4
7−8
No. of
terminals
8
★MFS201PA−5−Z
■ Specifications
※[Note] See below.
Max.
Min.
Rating
■PC Hole Layouts
(Top view)
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
4.41
Switch timing
Undefined
Switching function
ON
ON
ON
3−1
7−5
3−2
7−6
3−4
7−8
※:Please note that MFS201PA-4-Z and MFS201PA-5-Z can be either Shorting or Non-shorting (See page 506).
+1.67
N
-2.16
Circuit diagram
(Viewed from A)
No. of
terminals
8
MFS
★MFS401N−2−Z
■ Specifications
Shorting
Max.
Min.
Rating
■PC Hole Layouts
(Top view)
20mΩ Max.
Dielectric strength
AC500V 1 minute
100MΩ Min.
Electrical life
5,000 cycles
Operating force
節度なし
detent)
1.57 N Max. (No No
detent
Switch timing
Shorting
Switching function
(Viewed from A)
ON
2−1
5−4
8−7
11−10
■Flux Cleaning
⑴ Manual Soldering
⑴ Solvent : Fluorine or Alcohol type.
Please refer to “MFS Series Heat-resistant Table”
shown below.
⑵ Auto Soldering
Circuit diagram
ON
2−3
5−6
8−9
11−12
■Soldering
Device:Soldering iron
No. of
terminals
12
⑵ MSF Series are not process sealed. If the PC board is
to be cleaned, clean the soldering surface of substrate
with a brush so that the switch is not exposed to the
cleaning solution.
MFS series are not compatible with auto soldering.
Soldering should be done manually.
⑶ When soldering two or more terminals to the common
land, use solder resist to solder them independently.
■Frequency of switch use
If the switch is not likely to be operated frequently (e.g.
two or three operations a year) in the dry circuit area,
a sulfide film is likely to be formed on the contacts,
resulting in contact failure. If this is the case, gold-plated
products are recommended. Please contact your local
Nidec Copal Electronics sales representative.
■MFS series heat-resistant table
Resin board
Phenol board
MFS101D−6−Z
MFS101D−9−Z
MFS101D−11−Z
MFS101D−8−Z
MFS201N−19−Z
MFS201N−20−Z
MFS101D−10−Z
MFS101D−14−Z
MFS201N−Z
MFS201N−4−Z
MFS201N−9−Z
MFS201N−16−Z
MFS201N−21−Z
MFS201N−23−Z
MFS201N−24−Z
MFS201PA−4−Z
MFS101EA−Z
MFS201PA−5−Z
MFS401N−2−Z
270℃ MAX. 3sec MAX.
■Packaging Specifications
360℃ MAX. 3sec MAX.
Plastic Bag
Type
Spec
Quantit
LOT y
Date NO
MA Code
DE IN C
H
FUJRoHSINA
ISO 〕
KU
shorting
→Page 506.
很抱歉,暂时无法提供与“MFS 101D-8-Z”相匹配的价格&库存,您可以联系我们找货
