A ll data sheet.com
SI4482DY-T1-E3
www.VBsemi.tw
N-Channel 100 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
100
RDS(on) (Ω)
a
ID (A)
0.040 at VGS = 10 V
6.4
0.047 at V GS = 8 V
5.5
• Halogen-free According to IEC 61249-2-21
Definition
• Extremely Low Qgd for Switching Losses
• 100 % Rg Tested
• 100 % Avalanche Tested
• Compliant to RoHS Directive 2002/95/EC
Qg (Typ.)
23 nC
D
APPLICATIONS
SO-8
• Primary Side Switch
S
1
8
D
S
2
7
D
S
3
6
D
G
4
5
D
G
S
Top View
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current (TJ = 150 °C)
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
ID
IDM
Pulsed Drain Current
TC = 25 °C
TA = 25 °C
IS
Single Pulse Avalanche Current
Single Pulse Avalanche Energy
L = 0.1 mH
IAS
EAS
Maximum Power Dissipation
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
PD
Continuous Source-Drain Diode Current
Limit
100
± 20
6.4
5.1
5.5b, c
4.5b, c
Operating Junction and Storage Temperature Range
Unit
V
A
26
4.5
2.6b, c
3.8
3.1b, c
2b, c
- 55 to 150
TJ, Tstg
mJ
W
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambientb, f
t ≤ 10 s
Maximum Junction-to-Foot (Drain)
Steady State
Symbol
RthJA
RthJF
Typical
33
17
Maximum
40
21
Unit
°C/W
Notes:
a. Based on TC = 25 °C.
b. Surface mounted on 1” x 1” FR4 board.
c. t = 10 s.
d. Maximum under steady state conditions is 80 °C/W.
E-mail:China@VBsemi TEL:86-755-83251052
1
A ll data sheet.com
SI4482DY-T1-E3
www.VBsemi.tw
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
100
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
ΔVDS /TJ
VGS(th) Temperature Coefficient
ΔVGS(th) /TJ
Gate-Source Threshold Voltage
ID = 250 µA
VGS(th)
VDS = VGS , ID = 250 µA
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
RDS(on)
Transconductancea
gfs
Forward
V
172
mV/°C
- 10
1.0
3.0
V
± 100
nA
VDS = 100 V, VGS = 0 V
1
VDS = 100 V, VGS = 0 V, TJ = 55 °C
10
VDS ≥ 10 V, VGS = 10 V
30
µA
A
VGS = 10 V, ID = 5 A
0.036
0.040
VGS = 8 V, ID = 5 A
0.037
0.047
VDS = 15 V, ID = 5 A
23
Ω
S
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-on Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
1735
VDS = 50 V, VGS = 0 V, f = 1 MHz
tr
pF
37
VDS = 75 V, VGS = 10 V, ID = 5 A
28.5
43
23
35
VDS = 75 V, VGS = 8 V, ID = 5 A
8
f = 1 MHz
0.85
1.3
14
21
VDD = 50 V, RL = 10 Ω
ID ≅ 5 A, VGEN = 10 V, Rg = 1 Ω
12
18
22
33
tf
6
10
td(on)
16
24
tr
td(off)
nC
6.5
td(on)
td(off)
160
ID ≅ 5 A, VGEN = 8 V, Rg = 1 Ω
tf
12
18
7
12
Ω
ns
Drain-Source Body Diode Characteristics
IS
Pulse Diode Forward Currenta
ISM
Body Diode Voltage
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
TC = 25 °C
7.7
50
IS = 2.6 A
IF = 5 A, dI/dt = 100 A/µs, TJ = 25 °C
A
0.77
1.2
V
63
95
ns
110
165
nC
49
14
ns
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %
a. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
A ll data sheet.com
SI4482DY-T1-E3
www.VBsemi.tw
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
1.2
60
VGS = 10 V thru 6 V
VGS = 5 V
0.9
I D - Drain Current (A)
48
36
24
TC = 125 °C
0.6
TC = 25 °C
0.3
12
VGS = 4 V
TC = - 55 °C
2
3
4
5
VDS - Drain-to-Source Voltage (V)
0.051
1600
C - Capacitance (pF)
2000
0.047
VGS = 8 V
0.043
VGS = 10 V
Ciss
800
400
0.035
40
50
Coss
Crss
ID - Drain Current (A)
40
60
80
100
On-Resistance vs. Drain Current and Gate Voltage
Capacitance
2.5
10
ID = 5 A
ID = 5 A
VDS = 50 V
VGS = 10 V
2.1
VDS = 75 V
6
VDS = 100 V
4
(Normalized)
8
R DS(on) - On-Resistance
VGS - Gate-to-Source Voltage (V)
10
1200
0.039
10
8
Transfer Characteristics
0.055
Output Characteristics
R DS(on) - On-Resistance (Ω)
4
1.7
VGS = 8 V
1.3
0.9
2
12
18
Qg - Total Gate Charge (nC)
Gate Charge
24
30
0.5
- 50
- 25
50
75
100
125
150
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
3
A ll data sheet.com
SI4482DY-T1-E3
www.VBsemi.tw
0.20
I S - Source Current (A)
10
R DS(on) - Drain-to-Source On-Resistance (Ω)
100
TJ = 150 °C
1
TJ = 25 °C
0.1
0.01
0.001
ID = 5 A
0.16
0.12
TJ = 125 °C
0.08
TJ = 25 °C
0.04
0.00
0.4
0.6
0.8
1
2
VSD - Source-to-Drain Voltage (V)
10
160
Power (W)
0.5
VGS(th) (V)
8
200
1.0
ID = 5 mA
- 0.5
- 1.0
- 1.5
- 50
6
On-Resistance vs. Gate-to-Source Voltage
Source-Drain Diode Forward Voltage
0.0
4
120
80
40
- 25
50
100
75
125
150
0.01
0.1
1
10
Time (s)
TJ - Temperature ( C)
Threshold Voltage
Single Pulse Power, Junction-to-Ambient
100
Limited by RDS(on)*
10
1 ms
1
10 ms
100 ms
0.1
TA = 25 °C
Single Pulse
0.01
0.01
1s
10 s
DC
1
10
100 1000
minimum VGS at which RDS(on) is specified
0.1
* VGS
Safe Operating Area, Junction-to-Ambient
4
A ll data sheet.com
SI4482DY-T1-E3
www.VBsemi.tw
9
7
5
4
2
50
75
100
125
150
TC - Case Temperature (°C)
8.0
2.0
6.4
1.6
4.8
1.2
Power (W)
Power (W)
Current Derating*
3.2
1.6
0.8
0.4
0.0
0.0
50
75
100
125
150
50
75
100
TA - Ambient Temperature (°C)
Power, Junction-to-Case
125
150
* The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
5
A ll data sheet.com
SI4482DY-T1-E3
www.VBsemi.tw
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
Notes:
0.1
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
0.02
t1
t2
2. Per Unit Base = RthJA = 65 °C/W
3. TJM - TA = PDMZthJA(t)
4. Surface Mounted
Single Pulse
0.01
10-4
10-3
10-2
10-1
10
1
100
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10-3
10-2
10-1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
6
A ll data sheet.com
SI4482DY-T1-E3
www.VBsemi.tw
SOIC (NARROW): 8-LEAD
JEDEC Part Number: MS-012
8
6
7
5
E
1
3
2
H
4
S
h x 45
D
C
0.25 mm (Gage Plane)
A
e
B
All Leads
q
A1
L
0.004"
MILLIMETERS
INCHES
DIM
Min
Max
Min
Max
A
1.35
1.75
0.053
0.069
A1
0.10
0.20
0.004
0.008
B
0.35
0.51
0.014
0.020
C
0.19
0.25
0.0075
0.010
D
4.80
5.00
0.189
0.196
E
3.80
4.00
0.150
e
0.101 mm
1.27 BSC
0.157
0.050 BSC
H
5.80
6.20
0.228
0.244
h
0.25
0.50
0.010
0.020
L
0.50
0.93
0.020
0.037
q
0°
8°
0°
8°
S
0.44
0.64
0.018
0.026
ECN: C-06527-Rev. I, 11-Sep-06
DWG: 5498
7
A ll data sheet.com
SI4482DY-T1-E3
www.VBsemi.tw
RECOMMENDED MINIMUM PADS FOR SO-8
0.172
(4.369)
0.028
0.022
0.050
(0.559)
(1.270)
0.152
(3.861)
0.047
(1.194)
0.246
(6.248)
(0.711)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
Return to Index
8
A ll data sheet.com
SI4482DY-T1-E3
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
9
