Additional Resources:
Product Page
3D Model
PCB Footprint
date
04/07/2022
page
1 of 5
MODEL: PJ-001AH-67 │ DESCRIPTION: DC POWER JACK
FEATURES
IP67 waterproof
low profile
through hole
reflow solder compatible
shielded
SPECIFICATIONS
parameter
conditions/description
min
typ
rated input voltage
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc between adjacent contacts
voltage withstand
for 1 minute between adjacent contacts
-25
life
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
Note:
5
A
50
30
mΩ
mΩ
MΩ
0.3
operating temperature
units
Vdc
100
insertion/withdrawal force
IP level
max
24
500
Vac
3
kg
85
5,000
°C
cycles
IP67
1. When measured at a current of less than 100 mA/1 kHz
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
SOLDERABILITY
parameter
reel storage
at relative humidity
很抱歉,暂时无法提供与“PJ-001AH-67”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 450+25.13505450+3.04623
