Additional Resources:
Product Page
3D Model
date
09/16/2020
page
1 of 5
MODEL: CMS-3520-18N │ DESCRIPTION: SPEAKER
FEATURES
• micro-speaker
• 85 dB
• rated 1.0 W
SPECIFICATIONS
parameter
conditions/description
min
input power
max power: 50 second on, 120 seconds off, 10
cycles
impedance
at 2.0 kHz, 1.0 V
6.8
8
9.2
Ω
resonant frequency (Fo)
at 1.0 V
560
700
840
Hz
frequency response
typ
max
units
1.0
1.5
W
F0
sound pressure level
at 1.0 W, 50 cm, avg at 0.8, 1.0, 1.2, 1.5 kHz
at 1.0 W, 10 cm, avg at 0.8, 1.0, 1.2, 1.5 kHz
82
95
distortion
at 1.0 kHz, rated power
buzz, rattle, etc.
must be normal at sine wave, frequency range
polarity
cone moves forward w/ positive dc current to “+” terminal
dimensions
35 x 20 x 7.6
magnet
Nd-Fe-B
frame material
ABS
cone material
cloth
terminal
solder terminals
85
98
10,000
Hz
88
101
dB
dB
10
2.83
V
mm
weight
5.8
g
operating temperature
-20
60
°C
storage temperature
-30
70
°C
390
°C
hand soldering
for maximum 3 seconds
RoHS
yes
Notes:
370
1. All specifications measured at 15~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
cuidevices.com
380
Product Page
CUI Devices │ MODEL: CMS-3520-18N │ DESCRIPTION: SPEAKER
3D Model
date 09/16/2020 │ page 2 of 5
MECHANICAL DRAWING
units: mm
tolerance: ±0.3 mm
cuidevices.com
Product Page
3D Model
date 09/16/2020 │ page 3 of 5
RESPONSE CURVES
Frequency Response Curve
Test Conditions: 1.0 W / 10 cm
Total Harmonic Distortion Curve
cuidevices.com
Product Page
3D Model
date 09/16/2020 │ page 4 of 5
PACKAGING
units: mm
Tray QTY: 50 pcs per tray
Carton Size: 365 x 270 x 315 mm
Carton QTY: 1,000 pcs per carton
500pcs
cuidevices.com
Product Page
3D Model
date 09/16/2020 │ page 5 of 5
REVISION HISTORY
rev.
1.0
description
date
initial release
09/16/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMS-3520-18N”相匹配的价格&库存,您可以联系我们找货
