Additional Resources:
Product Page
3D Model
date
08/24/2021
page
1 of 4
SERIES: CP85-2 │ DESCRIPTION: PELTIER MODULE
FEATURES
solid state device
2-stage cooler
precise temperature control
quiet operation
MODEL
CP854705-2
Notes:
1.
2.
3.
4.
Maximum
Maximum
Maximum
Maximum
input
voltage1
input
current2
output
Qmax3
max
(Vdc)
max
(A)
Th=27°C
(W)
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
16.1
8.5
51.6
58
85
95
voltage at ΔT max and Th=27°C
current to achieve ΔT max
heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C
temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa)
PART NUMBER KEY
CP85 X 705-2
Base Number
Length x Width:
4 = 40 x 40 mm
cuidevices.com
output
∆Tmax4
Product Page
3D Model
CUI Devices │ SERIES: CP85-2 │ DESCRIPTION: PELTIER MODULE
date 08/24/2021 │ page 2 of 4
SPECIFICATIONS
parameter
conditions/description
internal resistance1
solder melting temperature
connection between thermoelectric pairs
min
typ
max
units
1.485
1.65
1.815
Ω
1
MPa
80
°C
235
°C
assembly compression
hot side plate
RoHS
Note:
2011/65/EU
1. Measured by AC 4-terminal method at 25°C
MECHANICAL DRAWING
units: mm
MATERIAL
0.05
COLD SIDE
0.05
HOT SIDE
PLATING
ceramic plate
96% AL2O3
wire leads
20 AWG
sealer
silicon tubber 703 RTV (between cold
and hot side plates)
joint cover
scilicon rubber 703 RTV
marking
P/N & S/N printed on cold side
surface
tin
Red (+)
COLD SIDE
Black (-)
cuidevices.com
Product Page
3D Model
date 08/24/2021 │ page 3 of 4
PERFORMANCE (Th=27°C)
Input Voltage (V)
8.5 A
6.8 A
5.1 A
10
3.4 A
1.7 A
A
Heat Pumped, Q (W)
8.5
6.8
A
40
A
3.4
A
1.7
A
80
70
60
50
40
30
ΔT=Th-Tc (°C)
PERFORMANCE (Th=50°C)
Input Voltage (V)
8.5 A
6.8 A
5.1 A
10
3.4 A
1.7 A
Heat Pumped, Q (W)
8.5
A
6.8
40
5.1
A
3.4
A
A
A
80
70
60
50
ΔT=Th-Tc (°C)
cuidevices.com
40
30
Product Page
3D Model
date 08/24/2021 │ page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
09/12/2016
1.01
brand update
10/30/2019
1.02
updated solder melting point
08/24/2021
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CP854705-2”相匹配的价格&库存,您可以联系我们找货
