CRD-15DD17P
CRD-15DD17P
    WOLFSPEED
    CRD-15DD17P
CRD-15DD17P 数据手册
CRD-15DD17P: Wide Input Voltage Range (300 VDC – 1200 VDC) 15 W Flyback Auxiliary Power Supply Board • Demonstration of the efficient operation of Cree’s 1700 V, 1Ω SiC MOSFET with an availability of high blocking voltage and high creepage distance (~ 7mm) • Cree’s 15 W flyback auxiliary power supply board can accept a wide range of AC or DC input voltage (480 VAC – 530 VAC) or (300 VDC – 1200 VDC) and provide 12 VDC at the output with an exceptional efficiency of 85 % • Simple control approach has been utilized to reduce the overall complexity and cost of the system • High-frequency operation of Cree’s 1700 V, 1Ω SiC MOSFET has been demonstrated as well that helps in reducing form factor of the board significantly. • Targeting high voltage applications such as motor drives, solar power, traction, and energy storage • Documentation includes bill of materials (BOM), schematic, board layout, application note and a power point presentation • Download application note • Available for purchase
CRD-15DD17P 价格&库存
很抱歉,暂时无法提供与“CRD-15DD17P”相匹配的价格&库存,您可以联系我们找货
