IRLR3410TRPBF
www.VBsemi.com
N-Channel 100 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
RDS(on) ()
ID (A)
100
0.114 at VGS = 10 V
15
TrenchFET® Power MOSFET
175 °C Junction Temperature
PWM Optimized
100 % Rg Tested
Compliant to RoHS Directive 2002/95/EC
APPLICATIONS
• Primary Side Switch
D
TO-252
G
S
G
D
S
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Symbol
Limit
Drain-Source Voltage
Parameter
VDS
100
Gate-Source Voltage
VGS
± 20
Continuous Drain Current (TJ = 175 °C)b
TC = 25 °C
TC = 125 °C
Pulsed Drain Current
Continuous Source Current (Diode Conduction)
Avalanche Current
Single Pulse Avalanche Energy
Maximum Power Dissipation
L = 0.1 mH
TC = 25 °C
TA = 25 °C
V
15
ID
13
IDM
40
IS
3
A
IAS
3
EAS
18
mJ
96b
W
PD
3a
TJ, Tstg
Operating Junction and Storage Temperature Range
Unit
- 55 to 175
°C
THERMAL RESISTANCE RATINGS
Parameter
Junction-to-Ambienta
Junction-to-Case (Drain)
Notes:
a. Surface mounted on 1" x 1" FR4 board.
b. See SOA curve for voltage derating.
服务热线:400-655-8788
Symbol
t 10 s
Steady State
RthJA
RthJC
Typical
Maximum
15
18
40
50
0.85
1.1
Unit
°C/W
IRLR3410TRPBF
www.VBsemi.com
m
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
100
VGS(th)
VDS = VGS, ID = 250 µA
1.0
IGSS
VDS = 0 V, VGS = ± 20 V
Typ.a
Max.
Unit
Static
Drain-Source Breakdown Voltage
Gate Threshold Voltage
Gate-Body Leakage
Zero Gate Voltage Drain Current
On-State Drain Currentb
Drain-Source On-State Resistanceb
IDSS
± 100
VDS = 100 V, VGS = 0 V
1
VDS = 100 V, VGS = 0 V, TJ = 125 °C
50
VDS = 100 V, VGS = 0 V, TJ = 175 °C
250
ID(on)
VDS =5 V, VGS = 10 V
RDS(on)
40
Forward
0.114
VGS = 10 V, ID = 3 A, TJ = 125 °C
0.120
VGS = 10 V, ID = 3 A, TJ = 175 °C
0.140
µA
0.120
VDS = 15 V, ID = 3 A
gfs
nA
A
VGS = 4.5 V ID = 3 A
Transconductanceb
V
2.5
35
S
Dynamica
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Chargec
Qg
Gate-Source Chargec
Qgs
c
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Timec
td(on)
Turn-Off Delay Timec
td(off)
Turn-On Delay
Rise Timec
950
VGS = 0 V, VDS = 25 V, F = 1 MHz
pF
60
24
VDS = 50 V, VGS = 10 V, ID = 3 A
tr
Fall Timec
120
41
nC
8
12
0.5
VDD = 50 V, RL = 5.2 Ω
ID ≅ 3 A, VGEN = 10 V, Rg = 2.5 Ω
tf
2.9
15
25
50
75
30
45
60
90
ns
Source-Drain Diode Ratings and Characteristics (TC = 25 °C)
Diode Forward Voltage
5
ISM
Pulsed Current
b
Source-Drain Reverse Recovery Time
A
VSD
IF = 3 A, VGS = 0 V
0.9
1.5
V
trr
IF = 3 A, dI/dt = 100 A/µs
180
250
ns
Notes:
a. Guaranteed by design, not subject to production testing.
b. Pulse test; pulse width 300 µs, duty cycle 2 %.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
IRLR3410TRPBF
www.VBsemi.com
m
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
40
8
VGS = 10 V thru 5 V
4V
6
I D - Drain Current (A)
30
3V
10
4
TC = 125 °C
2
25 °C
- 55 °C
2V
4
6
8
2
3
4
5
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
70
6
0.4
R DS(on) - On-Resistance ()
TC = - 55 °C
60
g fs - Transconductance (S)
1
50
25 °C
40
125 °C
30
0.2
VGS = 5 V
VGS = 10 V
0.1
10
0.0
30
40
ID - Drain Current (A)
On-Resistance vs. Drain Current
C - Capacitance (pF)
Transconductance
1500
Ciss
900
600
300
Crss
VDS = 100 V
ID = 19 A
16
12
8
4
Coss
60
80
Capacitance
服务热线:400-655-8788
10
100
40
Qg - Total Gate Charge (nC)
Gate Charge
50
60
IRLR3410TRPBF
www.VBsemi.com
m
0.3
100
VGS = 10 V
ID = 5 A
I S - Source Current (A)
(Normalized)
0.25
0.2
0.15
0.1
TJ = 150 °C
10
TJ = 25 °C
0.05
0.0
- 50
- 25
50
75
100
125
150
1
175
0.6
0.9
1.2
VSD - Source-to-Drain Voltage (V)
TJ - Junction Temperature ( °C)
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
THERMAL RATINGS
10
7
100 µs
10 µs
Limited by R DS(on)*
6
5
4
5
1 ms
10 ms
1
100 ms
1 s, DC
TC = 25 °C
Single Pulse
3
50
75
100
125
TC - Case Temperature (°C)
150
175
0.1
0.1
Maximum Avalanche Drain Current
vs. Case Temperature
1
10
1000
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
2
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10- 4
10- 3
10- 2
10- 1
Square Wave Pulse Duration (s)
1
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
10
30
IRLR3410TRPBF
www.VBsemi.com
m
TO-252AA CASE OUTLINE
E
MILLIMETERS
A
C2
e
b2
D1
e1
E1
L
gage plane height (0.5 mm)
L4
b
L5
H
D
L3
b3
C
A1
DIM.
MIN.
MIN.
MAX.
A
2.18
2.38
0.086
0.094
A1
0.127
0.005
b
0.64
0.88
0.025
0.035
b2
0.76
1.14
0.030
0.045
b3
4.95
5.46
0.195
0.215
C
0.46
0.61
0.018
0.024
C2
0.46
0.89
0.018
0.035
D
5.97
6.22
0.235
0.245
D1
5.21
0.205
0.265
E
6.35
6.73
0.250
E1
4.32
0.170
H
9.40
10.41
0.370
0.410
e
2.28 BSC
0.090 BSC
e1
4.56 BSC
0.180 BSC
L
1.40
1.78
0.055
0.070
L3
0.89
1.27
0.035
0.050
L4
1.02
0.040
L5
1.14
1.52
0.045
0.060
ECN: X12-0247-Rev. M, 24-Dec-12
DWG: 5347
Note
• Dimension L3 is for reference only.
服务热线:400-655-8788
INCHES
MAX.
IRLR3410TRPBF
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR DPAK (TO-252)
0.224
(6.180)
0.087
(2.202)
(2.286)
0.180
0.055
(4.572)
(1.397)
Recommended Minimum Pads
Dimensions in Inches/(mm)
服务热线:400-655-8788
0.090
0.420
(10.668)
0.243
(5.690)
IRLR3410TRPBF
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related
to the product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
服务热线:400-655-8788
