74AUP1Z125GM,115
74AUP1Z125GM,115
    NEXPERIA(安世)
    XSON6_1.45x1MM
    带启用和内部电阻器的低功率X-tal驱动器
74AUP1Z125GM,115 数据手册
74AUP1Z125 Low-power X-tal driver with enable and internal resistor; 3-state Rev. 5 — 8 August 2012 Product data sheet 1. General description The 74AUP1Z125 combines the functions of the 74AUP1GU04 and 74AUP1G125 with enable circuitry and an internal bias resistor to provide a device optimized for use in crystal oscillator applications. When not in use the EN input can be driven HIGH, pulling up the X1 input and putting the device in a low-power disable mode. Schmitt trigger action at the EN input makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF at output Y. The IOFF circuitry disables the output Y, preventing the damaging backflow current through the device when it is powered down. The integration of the two devices into the 74AUP1Z125 produces the benefits of a compact footprint, lower power dissipation and stable operation over a wide range of frequency and temperature. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  ESD protection:  HBM JESD22-A114F Class 3A exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Latch-up performance exceeds 100 mA per JESD78B Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial power-down mode operation at output Y  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP1Z125GW 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74AUP1Z125GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AUP1Z125GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 74AUP1Z125GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AUP1Z125GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code[1] 74AUP1Z125GW 55 74AUP1Z125GM 55 74AUP1Z125GF 55 74AUP1Z125GN 55 74AUP1Z125GS 55 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram VCC RPU X1 3 6 Rbias EN 4 Y X2 1 001aaf141 RPU = pull-up resistance. Rbias = bias resistance. Fig 1. Logic symbol 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 2 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 6. Pinning information 6.1 Pinning 74AUP1Z125 74AUP1Z125 EN 1 6 EN 1 6 Y GND 2 5 VCC Y GND 2 5 VCC X1 3 4 X2 X1 3 4 X2 EN 1 6 Y GND 2 5 VCC X1 3 4 X2 001aaf144 001aaf143 Transparent top view Transparent top view 001aaf142 Fig 2. 74AUP1Z125 Pin configuration SOT363 Fig 3. Pin configuration SOT886 Fig 4. Pin configuration SOT891, SOT1115 and SOT1202 6.2 Pin description Table 3. Pin description Symbol Pin Description EN 1 enable input (active LOW) GND 2 ground (0 V) X1 3 data input X2 4 unbuffered output VCC 5 supply voltage Y 6 data output 7. Functional description Table 4. Function table[1] Input Output EN X1 X2 Y L L H H L H L L H L H Z H H L Z [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 3 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +4.6 V 50 - mA 0.5 +4.6 V 50 - mA 0.5 +4.6 V VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC Min Max Unit supply voltage 0.8 3.6 V VI input voltage 0 3.6 V VO output voltage 0 VCC V Tamb ambient temperature 40 +125 C t/V input transition rise and fall rate - 200 ns/V 74AUP1Z125 Product data sheet Conditions VCC = 0.8 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 4 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit 0.75  VCC - - V VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V - - 0.25  VCC V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V Tamb = 25 C VIH HIGH-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VIL LOW-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VOH HIGH-level output voltage Y output; VI at X1 input = VIH or VIL IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - - V IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - - V IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V X2 output; VI = GND or VCC 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 5 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL Y output; VI at X1 input = VIH or VIL LOW-level output voltage Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V X2 output; VI = GND or VCC II input leakage current IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V - - 0.1 A - - 0.1 A VI = GND; VCC = 0.8 V to 3.6 V - - 15 A - - 0.1 A X1 input VI = EN = VCC; VCC = 0 V to 3.6 V EN input VI = GND to 3.6 V; VCC = 0 V to 3.6 V Ipu pull-up current X1 input; EN = VCC IOZ OFF-state output current Y output; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V; EN = VCC IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V [1] - - 0.2 A [1] - - 0.2 A - - 75 A - - 40 A - 1.3 - pF - 0.8 - pF IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V ICC additional supply current EN input VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V CI input capacitance X1 input VCC = 0 V to 3.6 V; VI = GND or VCC EN input VCC = 0 V to 3.6 V; VI = GND or VCC 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 6 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions CO X2 output output capacitance Min Typ Max Unit - 1.5 - pF - 1.7 - pF VCC = 0.8 V - - - mA/V VCC = 1.1 V to 1.3 V 0.2 - 9.9 mA/V VCC = 1.4 V to 1.6 V 3.9 - 17.7 mA/V VCC = 1.65 V to 1.95 V 7.9 - 24.3 mA/V VCC = 2.3 V to 2.7 V 18 - 30.7 mA/V VO = GND; VCC = 0 V Y output VO = GND; VCC = 0 V gfs forward transconductance see Figure 10 and Figure 11 VCC = 3.0 V to 3.6 V Rbias bias resistance 20.5 - 32.4 mA/V 1.08 1.62 3.08 M 0.75  VCC - - V VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V - - 0.25  VCC V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V EN = GND; fi = 0 Hz; VI = 0 V or VCC; See Figure 5; for frequency behavior see Figure 6 Tamb = 40 C to +85 C VIH HIGH-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VIL LOW-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 7 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOH Y output; VI at X1 input = VIH or VIL HIGH-level output voltage Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V X2 output; VI = GND or VCC VOL LOW-level output voltage IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V Y output; VI at X1 input = VIH or VIL X2 output; VI = GND or VCC 74AUP1Z125 Product data sheet IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 8 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions II X1 input input leakage current VI = EN = VCC; VCC = 0 V to 3.6 V Min Typ Max Unit - - 0.5 A - - 0.5 A EN input VI = GND to 3.6 V; VCC = 0 V to 3.6 V Ipu pull-up current X1 input; EN = VCC VI = GND; VCC = 0.8 V to 3.6 V - - 15 A IOZ OFF-state output current Y output; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V; EN = VCC - - 0.5 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V [1] - - 0.5 A [1] - - 0.6 A - - 75 A - - 50 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V ICC additional supply current EN input VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V gfs Rbias forward transconductance bias resistance 74AUP1Z125 Product data sheet see Figure 10 and Figure 11 VCC = 0.8 V - - - mA/V VCC = 1.1 V to 1.3 V - - 10.8 mA/V VCC = 1.4 V to 1.6 V 1.8 - 21.2 mA/V VCC = 1.65 V to 1.95 V 7.5 - 29.9 mA/V VCC = 2.3 V to 2.7 V 15.0 - 38.0 mA/V VCC = 3.0 V to 3.6 V 17.8 - 39.2 mA/V 1.07 - 3.11 M EN = GND; fi = 0 Hz; VI = 0 V or VCC; See Figure 5; for frequency behavior see Figure 6 All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 9 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit 0.75  VCC - - V VCC = 0.8 V 0.75  VCC - - V VCC = 0.9 V to 1.95 V 0.70  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V - - 0.25  VCC V VCC = 0.8 V - - 0.25  VCC V VCC = 0.9 V to 1.95 V - - 0.30  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V Tamb = 40 C to +125 C VIH HIGH-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VIL LOW-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VOH HIGH-level output voltage Y output; VI at X1 input = VIH or VIL IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - V IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - V - X2 output; VI = GND or VCC 74AUP1Z125 Product data sheet IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 10 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL Y output; VI = VIH or VIL LOW-level output voltage Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - 0.33  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V V X2 output; VI = GND or VCC II input leakage current IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 IO = 1.1 mA; VCC = 1.1 V - - 0.33  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V - - 0.75 A - - 0.75 A VI = GND; VCC = 0.8 V to 3.6 V - - 15 A - - 0.75 A X1 input VI = EN = VCC; VCC = 0 V to 3.6 V EN input VI = GND to 3.6 V; VCC = 0 V to 3.6 V Ipu pull-up current X1 input; EN = VCC IOZ OFF-state output current Y output; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V; EN = VCC IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V [1] - - 0.75 A [1] - - 0.75 A - - 75 A - - 75 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V ICC additional supply current EN input VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 11 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions gfs see Figure 10 and Figure 11 forward transconductance VCC = 0.8 V [1] bias resistance Typ Max Unit - - - mA/V VCC = 1.1 V to 1.3 V - - 10.8 mA/V VCC = 1.4 V to 1.6 V 1.8 - 21.2 mA/V VCC = 1.65 V to 1.95 V 6.9 - 29.9 mA/V VCC = 2.3 V to 2.7 V 13.4 - 38.0 mA/V VCC = 3.0 V to 3.6 V Rbias Min EN = GND; fi = 0 Hz; VI = 0 V or VCC; See Figure 5; for frequency behavior see Figure 6 15.8 - 39.2 mA/V 1.07 - 3.11 M Only for output Y and input EN. Rbias VCC II X1 X2 VI VO 001aai359 VO – VI R bias = ----------------II Fig 5. Test circuit for measuring bias resistance 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 12 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 001aai159 20 Rbias (MΩ) 16 (1) 12 8 (2) 4 (3) 0 1.0 1.5 2.0 2.5 3.0 3.5 VCC (V) (1) fi = 30 kHz. (2) fi = 1 MHz. (3) fi = 10 MHz. Fig 6. Typical bias resistance versus supply voltage 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 13 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 6.2 - - - - ns VCC = 1.1 V to 1.3 V 0.9 2.3 4.4 0.9 4.8 5.3 ns VCC = 1.4 V to 1.6 V 0.7 1.7 3.1 0.6 3.4 3.8 ns VCC = 1.65 V to 1.95 V 0.5 1.4 2.6 0.5 2.9 3.2 ns VCC = 2.3 V to 2.7 V 0.4 1.1 2.0 0.4 2.3 2.6 ns 0.3 1.0 1.8 0.3 2.1 2.4 ns - 18.5 - - - - ns 2.8 5.9 12.5 3.2 14.8 16.3 ns VCC = 1.4 V to 1.6 V 2.2 4.2 7.7 2.6 9.1 10.1 ns VCC = 1.65 V to 1.95 V 1.9 3.5 6.2 2.2 7.8 8.6 ns VCC = 2.3 V to 2.7 V 1.6 2.9 4.8 1.9 6.2 6.9 ns 1.4 2.6 4.1 1.7 4.7 5.2 ns - 31.2 - - - - ns VCC = 1.1 V to 1.3 V 3.1 6.1 13.8 2.9 16.3 18.0 ns VCC = 1.4 V to 1.6 V 2.5 4.3 8.2 2.3 9.7 10.7 ns VCC = 1.65 V to 1.95 V 2.1 3.6 6.5 2.0 7.6 8.4 ns VCC = 2.3 V to 2.7 V 1.8 2.9 4.8 1.7 5.8 6.4 ns 1.7 2.6 4.1 1.7 4.7 5.2 ns CL = 5 pF tpd propagation delay X1 to X2; see Figure 7 [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V X1 to Y; see Figure 7 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 3.0 V to 3.6 V ten enable time EN to Y; see Figure 8 [3] VCC = 0.8 V VCC = 3.0 V to 3.6 V tdis disable time EN to Y; see Figure 8 VCC = 0.8 V 74AUP1Z125 Product data sheet [4] - 11.1 - - - - ns VCC = 1.1 V to 1.3 V 2.5 4.5 9.0 2.9 9.4 10.4 ns VCC = 1.4 V to 1.6 V 2.0 3.3 6.4 2.3 6.7 7.4 ns VCC = 1.65 V to 1.95 V 1.9 3.2 6.0 2.0 6.4 7.1 ns VCC = 2.3 V to 2.7 V 1.4 2.3 4.4 1.7 4.7 5.2 ns VCC = 3.0 V to 3.6 V 1.7 2.6 4.4 1.7 4.9 5.4 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 14 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 9.6 - - - - ns 1.2 3.1 6.1 1.2 6.8 7.5 ns VCC = 1.4 V to 1.6 V 1.0 2.3 4.0 0.9 4.6 5.1 ns VCC = 1.65 V to 1.95 V 0.8 1.9 3.3 0.7 3.8 4.2 ns VCC = 2.3 V to 2.7 V 0.6 1.5 2.7 0.6 3.1 3.5 ns 0.5 1.3 2.4 0.5 2.7 3.0 ns - 21.4 - - - - ns VCC = 1.1 V to 1.3 V 3.2 6.7 14.3 3.6 16.2 17.9 ns VCC = 1.4 V to 1.6 V 2.1 4.9 8.9 3.0 10.1 11.2 ns VCC = 1.65 V to 1.95 V 1.9 4.1 6.9 2.6 8.0 8.8 ns VCC = 2.3 V to 2.7 V 2.1 3.4 5.4 2.3 6.6 7.3 ns 1.8 3.1 4.8 2.1 5.6 6.2 ns CL = 10 pF tpd propagation delay X1 to X2; see Figure 7 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 3.0 V to 3.6 V X1 to Y; see Figure 7 [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V ten enable time EN to Y; see Figure 8 [3] VCC = 0.8 V tdis disable time - 34.4 - - - - ns VCC = 1.1 V to 1.3 V 3.6 6.9 15.5 3.4 16.0 17.6 ns VCC = 1.4 V to 1.6 V 2.3 5.0 9.3 2.2 9.6 10.6 ns VCC = 1.65 V to 1.95 V 2.0 4.2 7.2 1.9 7.9 8.7 ns VCC = 2.3 V to 2.7 V 1.8 3.4 5.5 1.7 6.4 7.1 ns VCC = 3.0 V to 3.6 V 1.7 3.2 4.9 1.7 5.5 6.1 ns - 13.0 - - - - ns EN to Y; see Figure 8 VCC = 0.8 V 74AUP1Z125 Product data sheet [4] VCC = 1.1 V to 1.3 V 3.4 5.7 10.4 3.4 10.8 11.9 ns VCC = 1.4 V to 1.6 V 2.1 4.2 7.6 2.2 8.0 8.8 ns VCC = 1.65 V to 1.95 V 2.2 4.3 7.3 1.9 7.6 8.4 ns VCC = 2.3 V to 2.7 V 1.6 3.1 5.3 1.7 5.5 6.1 ns VCC = 3.0 V to 3.6 V 2.1 3.8 6.0 1.7 6.5 7.2 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 15 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 13.0 - - - - ns 1.6 3.8 7.9 1.4 8.8 9.7 ns VCC = 1.4 V to 1.6 V 1.3 2.8 4.9 1.1 5.7 6.3 ns VCC = 1.65 V to 1.95 V 1.0 2.3 4.0 0.9 4.7 5.2 ns VCC = 2.3 V to 2.7 V 0.8 1.9 3.2 0.8 3.7 4.1 ns 0.7 1.6 2.9 0.7 3.3 3.7 ns - 24.2 - - - - ns VCC = 1.1 V to 1.3 V 3.6 7.5 16.1 4.0 17.6 19.4 ns VCC = 1.4 V to 1.6 V 3.0 5.4 9.7 3.3 10.6 11.7 ns VCC = 1.65 V to 1.95 V 2.2 4.6 7.7 2.9 9.0 9.9 ns VCC = 2.3 V to 2.7 V 2.0 3.9 6.1 2.6 7.3 8.1 ns 2.0 3.6 5.4 2.3 5.9 6.5 ns CL = 15 pF tpd propagation delay X1 to X2; see Figure 7 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 3.0 V to 3.6 V X1 to Y; see Figure 7 [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V ten enable time EN to Y; see Figure 8 [3] VCC = 0.8 V tdis disable time - 37.5 - - - - ns VCC = 1.1 V to 1.3 V 4.0 7.7 17.2 3.7 17.5 19.3 ns VCC = 1.4 V to 1.6 V 3.0 5.5 10.0 2.5 10.2 11.3 ns VCC = 1.65 V to 1.95 V 2.3 4.7 7.9 2.1 9.2 10.2 ns VCC = 2.3 V to 2.7 V 2.0 3.9 6.2 2.0 7.4 8.2 ns VCC = 3.0 V to 3.6 V 2.0 3.6 5.5 1.9 6.0 6.6 ns - 14.8 - - - - ns EN to Y; see Figure 8 VCC = 0.8 V 74AUP1Z125 Product data sheet [4] VCC = 1.1 V to 1.3 V 4.3 6.8 11.2 3.7 12.4 13.7 ns VCC = 1.4 V to 1.6 V 3.0 5.1 8.1 2.5 8.9 9.8 ns VCC = 1.65 V to 1.95 V 3.0 5.4 8.0 2.1 9.3 10.3 ns VCC = 2.3 V to 2.7 V 2.1 3.9 6.1 2.0 7.3 8.1 ns VCC = 3.0 V to 3.6 V 2.9 5.1 7.2 1.9 7.9 8.7 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 16 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 23.2 - - - - ns 2.4 6.0 13.1 2.2 14.8 16.3 ns VCC = 1.4 V to 1.6 V 2.0 4.2 7.6 1.8 9.0 9.9 ns VCC = 1.65 V to 1.95 V 1.7 3.6 6.1 1.5 7.2 8.0 ns VCC = 2.3 V to 2.7 V 1.4 2.9 4.8 1.3 5.7 6.3 ns 1.2 2.5 4.3 1.1 5.1 5.7 ns - 32.6 - - - - ns VCC = 1.1 V to 1.3 V 4.8 9.6 21.0 5.0 21.7 23.9 ns VCC = 1.4 V to 1.6 V 4.0 6.9 12.4 4.3 13.5 14.9 ns CL = 30 pF tpd propagation delay X1 to X2; see Figure 7 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 3.0 V to 3.6 V X1 to Y; see Figure 7 [2] VCC = 0.8 V VCC = 1.65 V to 1.95 V 2.9 5.9 9.8 3.8 10.7 11.8 ns VCC = 2.3 V to 2.7 V 2.7 5.0 7.5 3.3 8.2 9.1 ns 2.7 4.7 6.8 3.1 7.7 8.5 ns VCC = 3.0 V to 3.6 V ten enable time EN to Y; see Figure 8 [3] VCC = 0.8 V tdis disable time - 47.1 - - - - ns VCC = 1.1 V to 1.3 V 5.2 9.9 21.0 4.8 21.7 23.9 ns VCC = 1.4 V to 1.6 V 4.0 7.1 12.4 3.1 13.5 14.9 ns VCC = 1.65 V to 1.95 V 3.0 6.0 9.9 2.8 10.7 11.8 ns VCC = 2.3 V to 2.7 V 2.7 5.0 7.7 2.6 8.1 9.0 ns VCC = 3.0 V to 3.6 V 2.7 4.8 6.8 2.6 7.7 8.5 ns - 20.3 - - - - ns EN to Y; see Figure 8 VCC = 0.8 V 74AUP1Z125 Product data sheet [4] VCC = 1.1 V to 1.3 V 6.0 10.2 15.3 4.8 16.5 18.2 ns VCC = 1.4 V to 1.6 V 4.4 7.8 11.2 3.1 12.3 13.6 ns VCC = 1.65 V to 1.95 V 5.1 8.8 12.5 2.8 13.3 14.7 ns VCC = 2.3 V to 2.7 V 3.6 6.3 8.6 2.6 9.5 10.5 ns VCC = 3.0 V to 3.6 V 5.2 8.8 11.5 2.6 13.0 14.3 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 17 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) VCC = 0.8 V - 7.1 - - - - pF VCC = 1.1 V to 1.3 V - 12.9 - - - - pF VCC = 1.4 V to 1.6 V - 19.2 - - - - pF VCC = 1.65 V to 1.95 V - 19.9 - - - - pF VCC = 2.3 V to 2.7 V - 21.6 - - - - pF VCC = 3.0 V to 3.6 V - 24.3 - - - - pF CL = 5 pF, 10 pF, 15 pF and 30 pF power dissipation capacitance CPD fi = 1 MHz; EN = GND; VI = GND to VCC [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZH and tPZL. [4] tdis is the same as tPHZ and tPLZ. [5] [5][6] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. [6] Feedback current is included in CPD. 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 18 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 12. Waveforms VI X1 input VM VM GND t PHL t PLH VOH X2, Y output VM VM VOL 001aaf145 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. Table 9. The input (X1) to output (X2, Y) propagation delays Measurement points Supply voltage Output Input VCC VM VM VI tr = tf 0.8 V to 3.6 V 0.5  VCC 0.5  VCC VCC  3.0 ns VI VM EN input GND tPLZ tPZL VCC Y output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY Y output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled 001aaf146 Measurement points are given in Table 10. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. Table 10. Enable and disable times Measurement points Supply voltage Input Output VCC VM VM VX VY 0.8 V to 1.6 V 0.5  VCC 0.5  VCC VOL + 0.1 V VOH  0.1 V 1.65 V to 2.7 V 0.5  VCC 0.5  VCC VOL + 0.15 V VOH  0.15 V 3.0 V to 3.6 V 0.5  VCC 0.5  VCC VOL + 0.3 V VOH  0.3 V 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 19 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state VCC VEXT 5 kΩ VI G VO DUT CL RT RL 001aac521 Test data is given in Table 11. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 9. Test circuit for measuring switching times Table 11. Test data Supply voltage Load VEXT VCC CL 0.8 V to 3.6 V 5 pF, 10 pF, 15 pF and 30 pF 5 k or 1 M [1] RL [1] tPLH, tPHL tPZH, tPHZ tPZL, tPLZ open GND 2  VCC For measuring enable and disable times RL = 5 k, for measuring propagation delays, setup and hold times and pulse width RL = 1 M. 001aad074 30 gfs (mA/V) 20 Rbias VCC 10 0.47 μF X 1 X2 100 μF Vi Io 0 0 1 2 3 4 VCC (V) 001aai360 Tamb = 25 C. I g fs = --------OV I fi = 1 kHz. VO is constant. Fig 10. Test set-up for measuring forward transconductance 74AUP1Z125 Product data sheet Fig 11. Typical forward transconductance as a function of supply voltage All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 20 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 13. Application information Crystal controlled oscillator circuits are widely used in clock pulse generators because of their excellent frequency stability and wide operating frequency range. The use of the 74AUP1Z125 provides the additional advantages of low power dissipation, stable operation over a wide range of frequency and temperature and a very small footprint. This application information describes crystal characteristics, design and testing of crystal oscillator circuits based on the 74AUP1Z125. 13.1 Crystal characteristics Figure 12 is the equivalent circuit of a quartz crystal. The reactive and resistive components of the impedance of the crystal alone, and the crystal with a series and a parallel capacitance, is shown in Figure 13. C1 L1 C0 R1 mnb102 Fig 12. Equivalent circuit of a crystal 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 21 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state C1 + resistance (1) R1 L1 C0 0 fr R1 fa f ∞ reactance − + C1 resistance RL (2) L1 C0 0 fL fa f R1 ∞ reactance CL − + Rp C1 resistance (3) CL C0 L1 0 fr fL fa f R1 ∞ reactance mnb104 − (1) (a) = resonance (2) (b) = anti-resonance (3) (c) = load resonance Fig 13. Reactance and resistance characteristics of a crystal 13.1.1 Design Figure 14 shows the recommended way to connect a crystal to the 74AUP1Z125. This circuit is basically a Pierce oscillator circuit in which the crystal is operating at its fundamental frequency and tuned by the parallel load capacitance of C1 and C2. C1 and C2 are in series with the crystal. They should be approximately equal. R1 is the drive-limiting resistor and is set to approximately the same value as the reactance of C1 at the crystal frequency (R1 = XC1). This results in an input to the crystal of 50 % of the rail-to-rail output of X2. This keeps the drive level into the crystal within drive specifications (the designer should verify this). Overdriving the crystal can cause damage. The internal bias resistor provides negative feedback and sets a bias point of the inverter near mid-supply, operating the 74AUP1GU04 in the high gain linear region. To calculate the values of C1 and C2, the designer can use the formula: C1  C2 C L = ------------------ + Cs C1 + C2 CL is the load capacitance as specified by the crystal manufacturer. Cs is the stray capacitance of the circuit and for 74AUP1Z125, Cs is equal to an input capacitance of 1.5 pF. 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 22 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 74AUP1GU04 74AUP1G125 portion portion Rbias X1 system load Y X2 Xtal C2 R1 C1 Csys Rsys 001aai549 Fig 14. Crystal oscillator configuration 13.1.2 Testing After the calculations are performed for a particular crystal, the oscillator circuit should be tested. The following simple checks verify the prototype design of a crystal controlled oscillator circuit. Perform the checks after laying out the board: • Test the oscillator over worst-case conditions (lowest supply voltage, worst-case crystal and highest operating temperature). Adding series and parallel resistors can simulate a worse case crystal. • Insure that the circuit does not oscillate without the crystal. • Check the frequency stability over a supply range greater than that which is likely to occur during normal operation. • Check that the start-up time is within system requirements. As the 74AUP1Z125 isolates the system loading, once the design is optimized, the single layout may work in multiple applications for any given crystal. 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 23 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 14. Package outline Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig 15. Package outline SOT363 (SC-88) 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 24 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig 16. Package outline SOT886 (XSON6) 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 25 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 e1 4 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Fig 17. Package outline SOT891 (XSON6) 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 26 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig 18. Package outline SOT1115 (XSON6) 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 27 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig 19. Package outline SOT1202 (XSON6) 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 28 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 15. Abbreviations Table 12. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 16. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP1Z125 v.5 20120808 Product data sheet - 74AUP1Z125 v.4 Modifications: 74AUP1Z125 v.4 Modifications: • Package outline drawing of SOT886 (Figure 16) modified. 20111201 • Product data sheet - 74AUP1Z125 v.3 Legal pages updated. 74AUP1Z125 v.3 20100909 Product data sheet - 74AUP1Z125 v.2 74AUP1Z125 v.2 20080807 Product data sheet - 74AUP1Z125 v.1 74AUP1Z125 v.1 20060803 Product data sheet - - 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 29 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 17. Legal information 17.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 17.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 17.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AUP1Z125 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 30 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 17.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 18. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AUP1Z125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 August 2012 © Nexperia B.V. 2017. All rights reserved 31 of 32 74AUP1Z125 Nexperia Low-power X-tal driver with enable and internal resistor; 3-state 19. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 13.1 13.1.1 13.1.2 14 15 16 17 17.1 17.2 17.3 17.4 18 19 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . 14 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Application information. . . . . . . . . . . . . . . . . . 21 Crystal characteristics. . . . . . . . . . . . . . . . . . . 21 Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Testing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 24 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 29 Legal information. . . . . . . . . . . . . . . . . . . . . . . 30 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 30 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 31 Contact information. . . . . . . . . . . . . . . . . . . . . 31 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 08 August 2012
74AUP1Z125GM,115 价格&库存
很抱歉,暂时无法提供与“74AUP1Z125GM,115”相匹配的价格&库存,您可以联系我们找货
74AUP1Z125GM,115
    • 5000+1.441445000+0.17470
    • 10000+1.4347010000+0.17388
    • 15000+1.4346715000+0.17388
    • 20000+1.4346420000+0.17387
    • 25000+1.4346125000+0.17387
    74AUP1Z125GM,115
