74AVC1T45GM,115
74AVC1T45GM,115
    NEXPERIA(安世)
    XSON6_1.45x1MM
    电压电平 转换器 双向 1 电路 1 通道 500Mbps 6-XSON,SOT886(1.45x1)
74AVC1T45GM,115 数据手册
74AVC1T45 Dual-supply voltage level translator/transceiver; 3-state Rev. 8 — 10 December 2018 Product data sheet 1. General description The 74AVC1T45 is a single bit, dual supply transceiver with 3-state output that enables bidirectional level translation. It features two 1-bit input-output ports (A and B), a direction control input (DIR) and dual supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between 0.8 V and 3.6 V making the device suitable for translating between any of the low voltage nodes (0.8 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V). Pins A and DIR are referenced to VCC(A) and pin B is referenced to VCC(B). A HIGH on DIR allows transmission from A to B and a LOW on DIR allows transmission from B to A. The device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at GND level, both A and B are in the high-impedance OFF-state. 2. Features and benefits • • • • • • • • • • • • Wide supply voltage range: • VCC(A): 0.8 V to 3.6 V • VCC(B): 0.8 V to 3.6 V High noise immunity Complies with JEDEC standards: • JESD8-12 (0.8 V to 1.3 V) • JESD8-11 (0.9 V to 1.65 V) • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8-B (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114E Class 3B exceeds 8000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101C exceeds 1000 V Maximum data rates: • 500 Mbit/s (1.8 V to 3.3 V translation) • 320 Mbit/s (< 1.8 V to 3.3 V translation) • 320 Mbit/s (translate to 2.5 V or 1.8 V) • 280 Mbit/s (translate to 1.5 V) • 240 Mbit/s (translate to 1.2 V) Suspend mode Latch-up performance exceeds 100 mA per JESD 78 Class II Inputs accept voltages up to 3.6 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AVC1T45GW -40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74AVC1T45GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1 x 1.45 x 0.5 mm 74AVC1T45GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm SOT1115 74AVC1T45GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm SOT1202 74AVC1T45GX -40 °C to +125 °C X2SON6 plastic thermal extremely thin small outline package; no leads; 6 terminals; body 1 x 0.8 x 0.35 mm SOT1255 4. Marking Table 2. Marking Type number Marking code[1] 74AVC1T45GW B5 74AVC1T45GM B5 74AVC1T45GN B5 74AVC1T45GS B5 74AVC1T45GX B5 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram DIR A 5 DIR 3 A 4 VCC(A) B B VCC(B) VCC(A) VCC(B) 001aag885 Fig. 1. Logic symbol 74AVC1T45 Product data sheet 001aag886 Fig. 2. Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 2 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 6. Pinning information 6.1. Pinning 74AVC1T45 74AVC1T45 VCC(A) 1 6 VCC(B) GND 2 5 DIR A 3 4 B VCC(A) 1 6 VCC(B) GND 2 5 DIR A 3 4 B 001aag972 Transparent top view 001aag971 Fig. 3. Pin configuration SOT363 Fig. 4. Pin configuration SOT886 74AVC1T45 VCC(A) 1 6 74AVC1T45 VCC(B) GND 2 5 DIR A 3 4 B VCC(A) VCC(B) 1 6 GND 3 A aaa-000876 5 DIR 4 B aaa-022602 Transparent top view Transparent top view Fig. 5. 2 Pin configuration SOT1115 and SOT1202 Fig. 6. Pin configuration SOT1255 (X2SON6) 6.2. Pin description Table 3. Pin description Symbol Pin Description VCC(A) 1 supply voltage port A and DIR GND 2 ground (0 V) A 3 data input or output B 4 data input or output DIR 5 direction control VCC(B) 6 supply voltage port B 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 3 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Supply voltage Input Input/output[1] VCC(A), VCC(B) DIR[2] A B 0.8 V to 3.6 V L A=B input 0.8 V to 3.6 V H input B=A GND[3] X Z Z [1] [2] [3] The input circuit of the data I/O is always active. The DIR input circuit is referenced to VCC(A). When either VCC(A) or VCC(B) is at GND level, the device goes into suspend mode. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC(A) Conditions Min Max Unit supply voltage A -0.5 +4.6 V VCC(B) supply voltage B -0.5 +4.6 V IIK input clamping current VI input voltage IOK output clamping current VO < 0 V VO output voltage Active mode VI < 0 V [1] -50 - -0.5 +4.6 -50 - [1][2][3] -0.5 [1] -0.5 Suspend or 3-state mode mA V mA VCCO + 0.5 V +4.6 V IO output current VO = 0 V to VCCO - ±50 mA ICC supply current ICC(A) or ICC(B) - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] [3] [4] Tamb = -40 °C to +125 °C [4] The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed. VCCO is the supply voltage associated with the output port. VCCO + 0.5 V should not exceed 4.6 V. For SC-88 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. For X2SON6 and XSON6 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 4 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A 0.8 3.6 V VCC(B) supply voltage B 0.8 3.6 V VI input voltage 0 3.6 V VO output voltage 0 VCCO V 0 3.6 V -40 +125 °C - 5 Active mode [1] Suspend or 3-state mode Tamb ambient temperature Δt/ΔV input transition rise and fall rate [1] [2] VCCI = 0.8 V to 3.6 V [2] ns/V VCCO is the supply voltage associated with the output port. VCCI is the supply voltage associated with the input port. 10. Static characteristics Table 7. Typical static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V).[1] Symbol Parameter Conditions VOH HIGH-level output voltage VI = VIH or VIL VOL LOW-level output voltage VI = VIH or VIL Tamb = 25 °C IO = -1.5 mA; VCC(A) = VCC(B) = 0.8 V IO = 1.5 mA; VCC(A) = VCC(B) = 0.8 V Unit Min Typ Max - 0.69 - V - 0.07 - V - ±0.025 ±0.25 μA - ±0.5 ±2.5 μA II input leakage current DIR input; VI = 0 V or 3.6 V; VCC(A) = VCC(B) = 0.8 V to 3.6 V IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCC(A) = VCC(B) = 0.8 V to 3.6 V IOFF power-off leakage current A port; VI or VO = 0 V to 3.6 V; VCC(A) = 0 V; VCC(B) = 0.8 V to 3.6 V - ±0.1 ±1 μA B port; VI or VO = 0 V to 3.6 V; VCC(B) = 0 V; VCC(A) = 0.8 V to 3.6 V - ±0.1 ±1 μA [2] CI input capacitance DIR input; VI = 0 V or 3.3 V; VCC(A) = VCC(B) = 3.3 V - 1.0 - pF CI/O input/output capacitance A and B port; Suspend mode; VO = VCCO or GND; VCC(A) = VCC(B) = 3.3 V - 4.0 - pF [1] [2] VCCO is the supply voltage associated with the output port. For I/O ports, the parameter IOZ includes the input leakage current. 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 5 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V).[1][2] Symbol Parameter Conditions VIH data input HIGH-level input voltage -40 °C to +85 °C -40 °C to +125 °C Unit Min Max Min Max VCCI = 0.8 V 0.70VCCI - 0.70VCCI - V VCCI = 1.1 V to 1.95 V 0.65VCCI - 0.65VCCI - V VCCI = 2.3 V to 2.7 V 1.6 - 1.6 - V VCCI = 3.0 V to 3.6 V 2 - 2 - V VCC(A) = 0.8 V 0.70VCC(A) - 0.70VCC(A) - V VCC(A) = 1.1 V to 1.95 V 0.65VCC(A) - 0.65VCC(A) - V VCC(A) = 2.3 V to 2.7 V 1.6 - 1.6 - V VCC(A) = 3.0 V to 3.6 V 2 - 2 - V VCCI = 0.8 V - 0.30VCCI - 0.30VCCI V VCCI = 1.1 V to 1.95 V - 0.35VCCI - 0.35VCCI V VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.9 - 0.9 V VCC(A) = 0.8 V - 0.30VCC(A) - 0.30VCC(A) V VCC(A) = 1.1 V to 1.95 V - 0.35VCC(A) - 0.35VCC(A) V VCC(A) = 2.3 V to 2.7 V - 0.7 - 0.7 V VCC(A) = 3.0 V to 3.6 V - 0.9 - 0.9 V VCCO - 0.1 - VCCO - 0.1 - V IO = -3 mA; VCC(A) = VCC(B) = 1.1 V 0.85 - 0.85 - V IO = -6 mA; VCC(A) = VCC(B) = 1.4 V 1.05 - 1.05 - V IO = -8 mA; VCC(A) = VCC(B) = 1.65 V 1.2 - 1.2 - V IO = -9 mA; VCC(A) = VCC(B) = 2.3 V 1.75 - 1.75 - V IO = -12 mA; VCC(A) = VCC(B) = 3.0 V 2.3 - 2.3 - V - 0.1 - 0.1 V IO = 3 mA; VCC(A) = VCC(B) = 1.1 V - 0.25 - 0.25 V IO = 6 mA; VCC(A) = VCC(B) = 1.4 V - 0.35 - 0.35 V IO = 8 mA; VCC(A) = VCC(B) = 1.65 V - 0.45 - 0.45 V IO = 9 mA; VCC(A) = VCC(B) = 2.3 V - 0.55 - 0.55 V IO = 12 mA; VCC(A) = VCC(B = 3.0 V - 0.7 - 0.7 V DIR input VIL LOW-level input voltage data input DIR input VOH VOL VI = VIH or VIL HIGH-level output voltage IO = -100 μA; VCC(A) = VCC(B) = 0.8 V to 3.6 V VI = VIH or VIL LOW-level output voltage IO = 100 μA; VCC(A) = VCC(B) = 0.8 V to 3.6 V 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 6 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Max Min Max - ±1 - ±1.5 μA - ±5 - ±7.5 μA II input leakage current DIR input; VI = 0 V or 3.6 V; VCC(A) = VCC(B) = 0.8 V to 3.6 V IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCC(A) = VCC(B) = 3.6 V IOFF power-off leakage current A port; VI or VO = 0 V to 3.6 V; VCC(A) = 0 V; VCC(B) = 0.8 V to 3.6 V - ±5 - ±35 μA B port; VI or VO = 0 V to 3.6 V; VCC(B) = 0 V; VCC(A) = 0.8 V to 3.6 V - ±5 - ±35 μA VCC(A) = 0.8 V to 3.6 V; VCC(B) = 0.8 V to 3.6 V - 8 - 12 μA VCC(A) = 3.6 V; VCC(B) = 0 V - 8 - 12 μA VCC(A) = 0 V; VCC(B) = 3.6 V -2 - -8 - μA VCC(A) = 0.8 V to 3.6 V; VCC(B) = 0.8 V to 3.6 V - 8 - 12 μA VCC(A) = 3.6 V; VCC(B) = 0 V -2 - -8 - μA VCC(A) = 0 V; VCC(B) = 3.6 V - 8 - 12 μA - 16 - 24 μA [3] supply current A port; VI = 0 V or VCCI; IO = 0 A ICC B port; VI = 0 V or VCCI; IO = 0 A A plus B port (ICC(A) + ICC(B)); IO = 0 A; VI = 0 V or VCCI; VCC(A) = 0.8 V to 3.6 V; VCC(B) = 0.8 V to 3.6 V [1] [2] [3] VCCO is the supply voltage associated with the output port. VCCI is the supply voltage associated with the data input port. For I/O ports, the parameter IOZ includes the input leakage current. 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 7 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 11. Dynamic characteristics Table 9. Typical dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9; for wave forms see Fig. 7 and Fig. 8[1] Symbol Parameter Conditions VCC(B) 0.8 V 1.2 V 1.5 V Unit 1.8 V 2.5 V 3.3 V VCC(A) = 0.8 V and Tamb = 25 °C tpd tdis 15.5 8.1 7.6 7.7 8.4 9.2 ns B to A 15.5 12.7 12.3 12.2 12.0 11.8 ns DIR to A 12.2 12.2 12.2 12.2 12.2 12.2 ns DIR to B 11.7 7.9 7.6 8.2 8.7 10.2 ns DIR to A 27.2 20.6 19.9 20.4 20.7 22.0 ns DIR to B 27.7 20.3 19.8 19.9 20.6 21.4 ns disable time ten [1] propagation delay A to B enable time tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. ten is a calculated value using the formula shown in Section 12.4 Table 10. Typical dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9; for wave forms see Fig. 7 and Fig. 8[1] Symbol Parameter Conditions VCC(A) Unit 0.8 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V VCC(B) = 0.8 V and Tamb = 25 °C tpd propagation delay A to B 15.5 12.7 12.3 12.2 12.0 11.8 ns B to A 15.5 8.1 7.6 7.7 8.4 9.2 ns tdis disable time DIR to A 12.2 4.9 3.8 3.7 2.8 3.4 ns DIR to B 11.7 9.2 9.0 8.8 8.7 8.6 ns DIR to A 27.2 17.3 16.6 16.5 17.1 17.8 ns DIR to B 27.7 17.6 16.1 15.9 14.8 15.2 ns ten [1] enable time tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. ten is a calculated value using the formula shown in Section 12.4 Table 11. Typical power dissipation capacitance Voltages are referenced to GND (ground = 0 V).[1][2] Symbol Parameter Conditions VCC(A) = VCC(B) Unit 0.8 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V A port: (direction A to B); B port: (direction B to A) 1 2 2 2 2 2 pF A port: (direction B to A); B port: (direction A to B) 9 11 11 12 14 17 pF Tamb = 25 °C CPD [1] [2] power dissipation capacitance CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC x fi x N + Σ(CL x VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of the outputs. fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω. 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 8 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state Table 12. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9; for wave forms see Fig. 7 and Fig. 8[1] Symbol Parameter Conditions VCC(B) Unit 1.2 V±0.1 V 1.5 V±0.1 V 1.8 V±0.15 V 2.5 V±0.2 V 3.3 V±0.3 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.1 V to 1.3 V; Tamb = -40 °C to +85 °C tpd tdis ten propagation delay A to B 1.0 9.0 0.7 6.8 0.6 6.1 0.5 5.7 0.5 6.1 ns B to A 1.0 9.0 0.8 8.0 0.7 7.7 0.6 7.2 0.5 7.1 ns disable time DIR to A 2.2 8.8 2.2 8.8 2.2 8.8 2.2 8.8 2.2 8.8 ns DIR to B 2.2 8.4 1.8 6.7 2.0 6.9 1.7 6.2 2.4 7.2 ns DIR to A - 17.4 - 14.7 - 14.6 - 13.4 - 14.3 ns DIR to B - 17.8 - 15.6 - 14.9 - 14.5 - 14.9 ns enable time VCC(A) = 1.4 V to 1.6 V; Tamb = -40 °C to +85 °C tpd tdis ten propagation delay A to B 1.0 8.0 0.7 5.4 0.6 4.6 0.5 3.7 0.5 3.5 ns B to A 1.0 6.8 0.8 5.4 0.7 5.1 0.6 4.7 0.5 4.5 ns disable time DIR to A 1.6 6.3 1.6 6.3 1.6 6.3 1.6 6.3 1.6 6.3 ns DIR to B 2.0 7.6 1.8 5.9 1.6 6.0 1.2 4.8 1.7 5.5 ns DIR to A - 14.4 - 11.3 - 11.1 - 9.5 - 10.0 ns DIR to B - 14.3 - 11.7 - 10.9 - 10.0 - 9.8 ns enable time VCC(A) = 1.65 V to 1.95 V; Tamb = -40 °C to +85 °C propagation delay A to B 1.0 7.7 0.6 5.1 0.5 4.3 0.5 3.4 0.5 3.1 ns B to A 1.0 6.1 0.7 4.6 0.5 4.4 0.5 3.9 0.5 3.7 ns tdis disable time DIR to A 1.6 5.5 1.6 5.5 1.6 5.5 1.6 5.5 1.6 5.5 ns DIR to B 1.8 7.7 1.8 5.7 1.4 5.8 1.0 4.5 1.5 5.2 ns ten enable time DIR to A - 13.8 - 10.3 - 10.2 - 8.4 - 8.9 ns DIR to B - 13.2 - 10.6 - 9.8 - 8.9 - 8.6 ns tpd VCC(A) = 2.3 V to 2.7 V; Tamb = -40 °C to +85 °C tpd propagation delay A to B 1.0 7.2 0.5 4.7 0.5 3.9 0.5 3.0 0.5 2.6 ns B to A 1.0 5.7 0.6 3.8 0.5 3.4 0.5 3.0 0.5 2.8 ns tdis disable time DIR to A 1.5 4.2 1.5 4.2 1.5 4.2 1.5 4.2 1.5 4.2 ns DIR to B 1.7 7.3 2.0 5.2 1.5 5.1 0.6 4.2 1.1 4.8 ns DIR to A - 13.0 - 9.0 - 8.5 - 7.2 - 7.6 ns DIR to B - 11.4 - 8.9 - 8.1 - 7.2 - 6.8 ns ten enable time VCC(A) = 3.0 V to 3.6 V; Tamb = -40 °C to +85 °C tpd tdis ten [1] propagation delay A to B 1.0 7.1 0.5 4.5 0.5 3.7 0.5 2.8 0.5 2.4 ns B to A 1.0 6.1 0.6 3.6 0.5 3.1 0.5 2.6 0.5 2.4 ns disable time DIR to A 1.5 4.7 1.5 4.7 1.5 4.7 1.5 4.7 1.5 4.7 ns DIR to B 1.7 7.2 0.7 5.5 0.6 5.5 0.7 4.1 1.7 4.7 ns DIR to A - 13.3 - 9.1 - 8.6 - 6.7 - 7.1 ns DIR to B - 11.8 - 9.2 - 8.4 - 7.5 - 7.1 ns enable time tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. ten is a calculated value using the formula shown in Section 12.4 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 9 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state Table 13. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9; for wave forms see Fig. 7 and Fig. 8[1] Symbol Parameter Conditions VCC(B) Unit 1.2 V±0.1 V 1.5 V±0.1 V 1.8 V±0.15 V 2.5 V±0.2 V 3.3 V±0.3 V Min Min Max Min Max Min Max Min Max Max VCC(A) = 1.1 V to 1.3 V; Tamb = -40 °C to +125 °C tpd tdis ten propagation delay A to B 1.0 9.9 0.7 7.5 0.6 6.8 0.5 6.3 0.5 6.8 ns B to A 1.0 9.9 0.8 8.8 0.7 8.5 0.6 8.0 0.5 7.9 ns disable time DIR to A 2.2 9.7 2.2 9.7 2.2 9.7 2.2 9.7 2.2 9.7 ns DIR to B 2.2 9.2 1.8 7.4 2.0 7.6 1.7 6.9 2.4 8.0 ns DIR to A - 19.1 - 16.2 - 16.1 - 14.9 - 15.9 ns DIR to B - 19.6 - 17.2 - 16.5 - 16.0 - 16.5 ns enable time VCC(A) = 1.4 V to 1.6 V; Tamb = -40 °C to +125 °C tpd tdis ten propagation delay A to B 1.0 8.8 0.7 6.0 0.6 5.1 0.5 4.1 0.5 3.9 ns B to A 1.0 7.5 0.8 6.0 0.7 5.7 0.6 5.2 0.5 5.0 ns disable time DIR to A 1.6 7.0 1.6 7.0 1.6 7.0 1.6 7.0 1.6 7.0 ns DIR to B 2.0 8.3 1.8 6.5 1.6 6.6 1.2 5.3 1.7 6.1 ns DIR to A - 15.8 - 12.5 - 12.3 - 10.5 - 11.1 ns DIR to B - 15.8 - 13.0 - 12.1 - 11.1 - 10.9 ns enable time VCC(A) = 1.65 V to 1.95 V; Tamb = -40 °C to +125 °C propagation delay A to B 1.0 8.5 0.6 5.7 0.5 4.8 0.5 3.8 0.5 3.5 ns B to A 1.0 6.8 0.7 5.1 0.5 4.9 0.5 4.3 0.5 4.1 ns tdis disable time DIR to A 1.6 6.1 1.6 6.1 1.6 6.1 1.6 6.1 1.6 6.1 ns DIR to B 1.8 8.5 1.8 6.3 1.4 6.4 1.0 5.0 1.5 5.8 ns ten enable time DIR to A - 15.3 - 11.4 - 11.3 - 9.3 - 9.9 ns DIR to B - 14.6 - 11.8 - 10.9 - 9.9 - 9.6 ns tpd VCC(A) = 2.3 V to 2.7 V; Tamb = -40 °C to +125 °C tpd propagation delay A to B 1.0 8.0 0.5 5.2 0.5 4.3 0.5 3.3 0.5 2.9 ns B to A 1.0 6.3 0.6 4.2 0.5 3.8 0.5 3.3 0.5 3.1 ns tdis disable time DIR to A 1.5 4.7 1.5 4.7 1.5 4.7 1.5 4.7 1.5 4.7 ns DIR to B 1.7 8.0 2.0 5.8 1.5 5.7 0.6 4.7 1.1 5.3 ns DIR to A - 14.3 - 10.0 - 9.5 - 8.0 - 8.4 ns DIR to B - 12.7 - 9.9 - 9.0 - 8.0 - 7.6 ns ten enable time VCC(A) = 3.0 V to 3.6 V; Tamb = -40 °C to +125 °C tpd tdis ten [1] propagation delay A to B 1.0 7.9 0.5 5.0 0.5 4.1 0.5 3.1 0.5 2.7 ns B to A 1.0 6.8 0.6 4.0 0.5 3.5 0.5 2.9 0.5 2.7 ns disable time DIR to A 1.5 5.2 1.5 5.2 1.5 5.2 1.5 5.2 1.5 5.2 ns DIR to B 1.7 7.9 0.7 6.1 0.6 6.1 0.7 4.6 1.7 5.2 ns DIR to A - 14.7 - 10.1 - 9.6 - 7.5 - 7.9 ns DIR to B - 13.1 - 10.2 - 9.3 - 8.3 - 7.9 ns enable time tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. ten is a calculated value using the formula shown in Section 12.4 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 10 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 11.1. Waveforms and test circuit VI VM A, B input GND tPHL tPLH VOH B, A output VM 001aae967 VOL Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. The data input (A, B) to output (B, A) propagation delay times VI DIR input VM GND t PLZ output LOW-to-OFF OFF-to-LOW t PZL VCCO VM VX VOL t PHZ output HIGH-to-OFF OFF-to-HIGH VOH t PZH VY VM GND outputs enabled outputs disabled outputs enabled 001aae968 Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 8. Enable and disable times Table 14. Measurement points Supply voltage Input [1] Output [2] VCC(A), VCC(B) VM VM VX VY 1.1 V to 1.6 V 0.5VCCI 0.5VCCO VOL + 0.1 V VOH - 0.1 V 1.65 V to 2.7 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH - 0.3 V [1] [2] VCCI is the supply voltage associated with the data input port. VCCO is the supply voltage associated with the output port. 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 11 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC VI G RL VO DUT RT CL RL 001aae331 Test data is given in Table 15. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance. VEXT = External voltage for measuring switching times. Fig. 9. Test circuit for measuring switching times Table 15. Test data Supply voltage Input Load VEXT VCC(A), VCC(B) VI [1] Δt/ΔV [2] CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ [3] 1.1 V to 1.6 V VCCI ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCCO 1.65 V to 2.7 V VCCI ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCCO 3.0 V to 3.6 V VCCI ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCCO [1] [2] [3] VCCI is the supply voltage associated with the data input port. dV/dt ≥ 1.0 V/ns VCCO is the supply voltage associated with the output port. 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 12 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 12. Application information 12.1. Unidirectional logic level-shifting application The circuit given in Fig. 10 is an example of the 74AVC1T45 being used in an unidirectional logic level-shifting application. VCC1 VCC1 VCC(A) 1 GND 2 A 74AVC1T45 3 VCC(B) 6 DIR 5 VCC2 VCC2 B 4 system-1 system-2 001aag973 Fig. 10. Unidirectional logic level-shifting application Table 16. Description unidirectional logic level-shifting application Pin Name Function Description 1 VCC(A) VCC1 supply voltage of system-1 (0.8 V to 3.6 V) 2 GND GND device GND 3 A OUT output level depends on VCC1 voltage 4 B IN input threshold value depends on VCC2 voltage 5 DIR DIR the GND (LOW level) determines B port to A port direction 6 VCC(B) VCC2 supply voltage of system-2 (0.8 V to 3.6 V) 12.2. Bidirectional logic level-shifting application Fig. 11 shows the 74AVC1T45 being used in a bidirectional logic level-shifting application. Since the device does not have an output enable pin, the system designer should take precautions to avoid bus contention between system-1 and system-2 when changing directions. VCC1 VCC1 VCC2 VCC(A) I/O-1 PULL-UP/DOWN GND A 1 2 74AVC1T45 3 6 5 4 VCC2 VCC(B) DIR I/O-2 PULL-UP/DOWN B DIR CTRL system-1 system-2 001aag974 Fig. 11. Bidirectional logic level-shifting application Table 17 gives a sequence that will illustrate data transmission from system-1 to system-2 and then from system-2 to system-1. 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 13 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state Table 17. Description bidirectional logic level-shifting application H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. State DIR CTRL I/O-1 I/O-2 Description 1 H output input system-1 data to system-2 2 H Z Z system-2 is getting ready to send data to system-1. I/O-1 and I/O-2 are disabled. The bus-line state depends on bus hold. 3 L Z Z DIR bit is set LOW. I/O-1 and I/O-2 still are disabled. The bus-line state depends on bus hold. 4 L input output system-2 data to system-1 12.3. Power-up considerations The device is designed such that no special power-up sequence is required other than GND being applied first. Table 18. Typical total supply current (ICC(A) + ICC(B)) VCC(A) VCC(B) Unit 0V 0.8 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 0V 0 0.1 0.1 0.1 0.1 0.1 0.1 μA 0.8 V 0.1 0.1 0.1 0.1 0.1 0.7 2.3 μA 1.2 V 0.1 0.1 0.1 0.1 0.1 0.3 1.4 μA 1.5 V 0.1 0.1 0.1 0.1 0.1 0.1 0.9 μA 1.8 V 0.1 0.1 0.1 0.1 0.1 0.1 0.5 μA 2.5 V 0.1 0.7 0.3 0.1 0.1 0.1 0.1 μA 3.3 V 0.1 2.3 1.4 0.9 0.5 0.1 0.1 μA 12.4. Enable times Calculate the enable times for the 74AVC1T45 using the following formulas: • • ten (DIR to A) = tdis (DIR to B) + tpd (B to A) ten (DIR to B) = tdis (DIR to A) + tpd (A to B) In a bidirectional application, these enable times provide the maximum delay from the time the DIR bit is switched until an output is expected. For example, if the 74AVC1T45 initially is transmitting from A to B, then the DIR bit is switched, the B port of the device must be disabled before presenting it with an input. After the B port has been disabled, an input signal applied to it appears on the corresponding A port after the specified propagation delay. 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 14 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 13. Package outline Plastic surface-mounted package; 6 leads SOT363 D B E y A X HE 6 5 v M A 4 Q pin 1 index A 1 2 e1 A1 3 c bp Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig. 12. Package outline SOT363 (SC-88) 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 15 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig. 13. Package outline SOT886 (XSON6) 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 16 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 L L1 0.35 0.40 0.30 0.35 0.27 0.32 0.3 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig. 14. Package outline SOT1115 (XSON6) 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 17 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig. 15. Package outline SOT1202 (XSON6) 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 18 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state X2SON6: plastic thermal enhanced extremely thin small outline package; no leads; 6 terminals; body 1.0 x 0.8 x 0.35 mm SOT1255 X A D B A pin 1 ID area E A1 detail X C e1 b (4x) 4 3 y1 C A B v y L (4x) 2 5 Dh (2x) 1 6 e2 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 D Dh E e1 e2 b L v y y1 max 0.35 0.04 1.05 0.30 0.85 0.30 0.25 nom 0.32 0.02 1.00 0.25 0.80 0.60 0.40 0.25 0.20 0.10 0.05 0.05 0.22 0.17 min 0.30 0.00 0.95 0.22 0.75 sot1255_po Outline version References IEC JEDEC JEITA European projection Issue date 15-07-20 15-07-22 SOT1255 Fig. 16. Package outline SOT1255 (X2SON6) 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 19 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 14. Abbreviations Table 19. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15. Revision history Table 20. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AVC1T45 v.8 20181210 Product data sheet - 74AVC1T45 v.7 74AVC1T45 v.7 20170824 Product data sheet - 74AVC1T45 v.6 Modifications: • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74AVC1T45 v.6 20160420 Modifications: • 74AVC1T45 v.5 20160106 Modifications: • 74AVC1T45 v.4 20120622 Modifications: • 74AVC1T45 v.3 20111021 Modifications: • • 74AVC1T45 v.2 20090505 Product data sheet - 74AVC1T45 v.1 74AVC1T45 v.1 20080118 Product data sheet - - 74AVC1T45 Product data sheet Product data sheet - 74AVC1T45 v.5 Added type number 74AVC1T45GX(SOT1255/X2SON6 package). Product data sheet - 74AVC1T45 v.4 - 74AVC1T45 v.3 Table 16: Labels for pins 4 and 5 corrected. Product data sheet Package outline drawing of SOT886 (Fig. 13) modified. Product data sheet - 74AVC1T45 v.2 Added type number 74AVC1T45GN (SOT1115/XSON6 package). Added type number 74AVC1T45GS (SOT1202/XSON6 package). All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 20 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74AVC1T45 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 21 / 22 74AVC1T45 Nexperia Dual-supply voltage level translator/transceiver; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................5 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................8 11.1. Waveforms and test circuit.......................................11 12. Application information........................................... 13 12.1. Unidirectional logic level-shifting application............13 12.2. Bidirectional logic level-shifting application.............. 13 12.3. Power-up considerations......................................... 14 12.4. Enable times............................................................14 13. Package outline........................................................ 15 14. Abbreviations............................................................ 20 15. Revision history........................................................20 16. Legal information......................................................21 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 December 2018 74AVC1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 10 December 2018 © Nexperia B.V. 2018. All rights reserved 22 / 22
74AVC1T45GM,115 价格&库存
很抱歉,暂时无法提供与“74AVC1T45GM,115”相匹配的价格&库存,您可以联系我们找货
74AVC1T45GM,115
  • 725+1.25639725+0.15169
  • 1000+1.206281000+0.14564
库存:4580
74AVC1T45GM,115
    74AVC1T45GM,115
      • 725+1.21211
      • 1000+1.16376
      库存:4580
