Customer Name
Customer P/N
Frequency
Aker Approved P/N
Aker MPN
Rev.
: 4.000000
MHz
: SMA-004000-5BL4T2
: SMA-004000-5BL4T2
:1
ISSUE DATE
: Jan.25.2019
APPROVED
CHECKED
PREPARED
Tin
Kiku
APPROVED BY CUSTOMER
AKER TECHNOLOGY CO., LTD.
ADDRESS : NO 11-3, Jianguo Rd., T.E.P.Z ,Tanzi Dist., Taichung City 427, Taiwan.
TEL:886-4-25335978
FAX : 886-4-25336011
Web: www.aker.com.tw
RoHS compliant
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SMA-004000-5BL4T2
SHEET : 1 of 10
Tin
REV . : 1
Kiku
Rev.
Date
Reviser
Revise contents
1
2019/1/25
Kiku
Initial Released
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SMA-004000-5BL4T2
Tin
SHEET : 2 of 10
Kiku
REV . : 1
SMD CRYSTAL OSCILLATOR
1 . ELECTRICAL CHARACTERISTICS
Standard atmospheric conditions
Unless otherwise specified , the standard range of atmospheric conditions for making measurement
and tests are as follow :
Ambient temperature : 25±5℃
Relative humidity
: 40%~70%
If there is any doubt about the results , measurement shall be made within the following limits :
Ambient temperature : 25±3℃
Relative humidity
: 40%~70%
AKER Model : SMA-531
Cutting Model : AT CUT
Parameters
Nominal Frequency
Frequency Stability
Supply Voltage
Output Load CMOS
Aging
Enable Control
Operating Temperature
Storage Temperature Range
Output Voltage High
Output Voltage Low
Input Current
Standby Current
Rise Time
Fall Time
Symmetry (Duty ratio)
Start-up Time
Enable Voltage High
Disable Voltage Low
Output Enable Delay Time
Output Disable Delay Time
Electrical Spec
Symbol Min.
Notes
Typ. Max. Units.
4.000000
MHz
± 50
ppm
VDD
3.3 ± 10%
V
CL
15
pF
±3
ppm First Year
Yes
Pad 1
-40
25
85
-55
125
VoH
2.97
V
VoL
0.33
V
Icc
7
mA
IsT
10
µA
Tr
10
ns 10%~90%VDD Level
Tf
10
ns 10%~90%VDD Level
TH/T
40
60
Tosc
10
ms
Vhi
70%VDD
V
Vlo
30%VDD V
T on
10
ms
T off
200
ns
*Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.*
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SMA-004000-5BL4T2
Tin
SHEET : 3 of 10
Kiku
REV . : 1
2 . C - MOS LOAD OUTPUT WAVEFORM
Tr
Tf
VDD
"1"Level
90% VDD
"0"Level
50% VDD
10% VDD
GND
TW
T
3 . C - MOS LOAD TEST CIRCUIT
CMOS
T.P.
A
#4 #3
#1 #2
DC
Power
Supply
V
CL
0.01 µF
***Because SMA series has no by pass capacitor.
So,we recommend our customer to use capacitor 0.01 µF
in join Vcc and GND.
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SMA-004000-5BL4T2
Tin
SHEET : 4 of 10
Kiku
REV . : 1
4 . MARKING :
Voltage Note1
L 4.000
FREQUENCY
AKER AA
Year/Month Code:Please make refer to following tables.
Production line code
Pin1
AKER LOGO.
5 . DIMENSION :
( UNIT : mm )
METAL CAP
CERAMIC BASE
3.2 ± 0.1
5.0 ± 0.1
MARKING
1.60
#2
#3
#1
#4
2.54 ± 0.20
#1 : E/D
#4 : VDC
#2 : GND
#3 : OUTPUT
Bottom
1.40
1.20
2.20
1.20 ± 0.20 1.0 (Ref.)
1.3MAX
2.54
(Recommended Land Pattern)
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SMA-004000-5BL4T2
Tin
SHEET : 5 of 10
Kiku
REV . : 1
6 . STRUCTURE ILLUSTRATION
A
B
D
C
E
G
N
I
K
R
A
M
F
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SMA-004000-5BL4T2
Tin
SHEET : 6 of 10
Kiku
REV . : 1
7 . PACKING :
TAPE SPECIFICATION
( Unit : mm )
OUTLINE DIMENSION
( Unit : mm )
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
8. COVER TAPE ADHESION STRENGTH:
9 . SOLDERING REFLOW PROFILE
SMA-004000-5BL4T2
Tin
SHEET : 7 of 10
Kiku
REV . : 1
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SMA-004000-5BL4T2
Tin
SHEET : 8 of 10
Kiku
REV . : 1
10. PACKING :
185mm
183mm
36mm
BOX = 1000 PCS / REEL
Stuff
210mm
625mm
390mm
SMD product packs 32 BOX = The outside box packs ( 1000 PCS * 32 BOX = 32000 PCS )(MAX)
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SMA-004000-5BL4T2
Tin
SHEET : 9 of 10
Kiku
REV . : 1
11 . MECHANICAL PERFORMANCE
TEST ITEMS
TEST METHODS AND TEST CONDITION
11.1 Drop Test
The specimen is measured for its frequency
before the test. It is then dropped from
a hight of 100 cm or more as a free fall object onto
a hard wooden plate of 30mm or more in thickness.
( in accordance with JIS-C0044 )
11.2 Vibration Test
before the test. Most them into
X,Y and Z axes, respectively, for the vibration test.
Vibration condition:
Frequency range ; 20~2000HZ
Peak to peak amplitude : 1.52 mm
Peak acceleration : 20G
Sweep time : 20 minute / axis
Pendicular total test time : 4 hours
( in accordance with MIL-STD-883F : 2007.3 )
before the test. Place the specimen on
the belt of the converynace and let it pass through
the reflow with the presetted temperature condition.
After passing twice the reflow place,the specimen
under the referee condition for -~2 hours and then
measure its electrical performance.
Temperature Condition of IR Simulation:
The temperature range of the preheated section
is setted at 150~180℃ for 60~120 sec. For the next
section the temperature range is setted at 217~260℃
for 45~90 sec. and within this time range the specimen
should be able to sustain at the peak temperature,
260+/-3℃ , for 10 sec long.
( in accordance with JESD22-B106-B )
Place the specimen in a pressurized container and
pressurize it with the detection gas ( mixed gas
consisting of 95% or more helium ) for at least 2 hours.
Complete the measurement of the concentration of
helium within 30 min after taking it out from the
pressurized container.
( in accordance with MIL-STD-883F : 1014.11 )
The referee condition .
Temperature 25 ± 2 ℃
Humidity
44 ~ 55 %
Pressure
86 ~ 106 kPa
11.3 Resistance to
Soldering Test
11.4 Fine Leak
Test
( in accordance with MIL-STD-883E : 1014. 9 )
PERFORMANCE
To satisfy the electrical
performance .
Less than
1.0 * 10 - 8 atm .c.c. / sec,
Helium
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SMA-004000-5BL4T2
Tin
SHEET : 10 of 10
Kiku
REV . : 1
12 . CLIMATIC RESISTANCE
TEST ITEMS
12.1 Low Temp
Exposure Test
before the test .
Place the specimen in the chamber and kept it
at the temperature of - 40 ± 3℃ for 168 ± 6 hours .
Take the specimen out of the chamber
and measure itselectrical performance after
leaving 1~2 hours under the referee condition.
( in accordance with JIS-C0020 )
12.2 Aging Test
before the test .
Place the specimen in the testing chamber and keep it
at the temperature of + 125 ± 3℃ for 720 ± 48 hours.
And then take the specimen out of the chamber and
measure its electrical performance after leaving
for 1 ~ 2 hours under the referee condition .
( in accordance with JIS-C0021 )
12.3 High
Temperature &
High Humidty
before the test .
kept it at the temperature of + 85 ± 5 ℃ and
humidity of 85 ± 5 % for 168 ± 6 hours.and
then take the specimen out and measure its
electrical performance after leaving for 1~2
( in accordance with MIL-STD-883F : 1004.7 )
12.4 Temperature
Cycle Test
before the test .
Subject the specimen to the 100 cycles of
temperature ranges stated below .
High temp . + 125 ± 3 ℃ (15± 3 min).
2~3 min.
2~3 min.
Low temp . -55 ±3 ℃ (15± 3 min).
Measure its electrical performance after leaving it
( in accordance with MIL-STD-883F : 1010.8 )
PERFORMANCE
performance .
很抱歉,暂时无法提供与“SMA-004000-5BL4T2”相匹配的价格&库存,您可以联系我们找货
