SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
MHL
High heat resistance, 125℃
New!
Series
・Downsized and Longer life from current MVH series
・Endurance : 2,000 to 4,000 hours at 125℃
・Rated voltage range : 10 to 35V. Nominal capacitance range : 47 to 680µF
・For automobile modules and other high temperature applications
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・Vibration resistant structure
・RoHS Compliant
MHL
Downsized
Longer life
MVH P94
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +125℃
10 to 35Vdc
(at 20℃, 120Hz)
±20%(M)
I=0.01CV
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage(Vdc)
10V 16V 25V 35V
tanδ(Max.)
0.24 0.20 0.16 0.14
(at 20℃, 120Hz)
Rated voltage(Vdc)
10V 16V 25V 35V
Z(-25℃)/Z(+20℃)
3
2
2
2
Z(-40℃)/Z(+20℃)
4
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for specified time
at 125℃.
F61 & F80 :2,000 hours
Time
HA0 & JA0:4,000 hours
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
● Terminal
● Terminal
● Size
Code : A
code : F61 to JA0
● Size
Code : G(Vibration resistant structure)
code : HA0 and JA0
Size code
Vent for JA0
Vent for JA0
0.3max.
W
0.3max.
L±0.3 (Note)
Note : L±0.5 for HA0 and JA0
2
3
4
5
6
7
8
9
10
11
12
B
6.6
6.6
8.3
10.3
C
7.2
7.2
9.0
11.0
W
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.9
1.9
3.1
4.5
: Dummy terminals
◆PART NUMBERING SYSTEM
1
φD
L
A
6.3 5.8 6.6
6.3 7.7 6.6
8 10.0 8.3
10 10.0 10.3
A±0.2
L±0.5
A±0.2
P
C±0.2
B±0.2
φD±0.5
P
C±0.2
B±0.2
φD±0.5
W
F61
F80
HA0
JA0
13
14
15
16
17
◆MARKING
18
EX) 35V47µF
E MH L A A A A D A A A A M A A A G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47µF:470,100µF:101)
Taping code
Terminal code (A, G)
Voltage code (ex. 35V:350)
Series code
Category
2Q
47
V HL
●Rated
voltage symbol
Rated voltage (Vdc) Symbol
A
10
C
16
E
25
V
35
Please refer to "Product code guide (surface mount type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
96
CAT. No. E1001N
TM
AIchip
MHLSeries
New!
◆STANDARD RATINGS
WV
(Vdc)
10
16
25
35
Cap
(µF)
Size code
100
220
330
470
680
47
100
220
330
470
680
47
100
220
330
47
100
220
330
F61
F80
HA0
HA0
JA0
F61
F61
F80
HA0
JA0
JA0
F61
F80
HA0
JA0
F61
F80
HA0
JA0
Impedance
(Ω max./100kHz)
20℃
-40℃
1.2
0.60
0.30
0.30
0.20
1.2
1.2
0.60
0.30
0.20
0.20
1.2
0.60
0.30
0.20
1.2
0.60
0.30
0.20
22
12
5.5
5.5
3.6
22
22
12
5.5
3.6
3.6
22
12
5.5
3.6
22
12
5.5
3.6
Rated ripple current
(mArms/125℃, 100kHz)
110
220
296
296
440
110
110
220
296
440
440
110
220
296
440
110
220
296
440
Part No.
EMHL100ADA101MF61G
EMHL100ADA221MF80G
EMHL100 □ DA331MHA0G
EMHL100 □ DA471MHA0G
EMHL100 □ DA681MJA0G
EMHL160ADA470MF61G
EMHL160ADA101MF61G
EMHL160ADA221MF80G
EMHL160 □ DA331MHA0G
EMHL160 □ DA471MJA0G
EMHL160 □ DA681MJA0G
EMHL250ADA470MF61G
EMHL250ADA101MF80G
EMHL250 □ DA221MHA0G
EMHL250 □ DA331MJA0G
EMHL350ADA470MF61G
EMHL350ADA101MF80G
EMHL350 □ DA221MHA0G
EMHL350 □ DA331MJA0G
□ : Enter the appropriate terminal code.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
47 to 680
120
0.93
1k
0.97
10k
1.00
100k
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
97
CAT. No. E1001N
很抱歉,暂时无法提供与“EMHL350ARA470MF61G”相匹配的价格&库存,您可以联系我们找货
