Technical Data 4407
Effective June 2015
Supersedes March 2014
FP0906
High frequency, high current power inductors
Applications
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
Desktop and server VRMs and EVRDs
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Load modules
DCR Sensing circuits
Environmental Data
Storage temperature range (Component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
Product Description
High current carrying capacity
Low core loss
Controlled DCR for sensing circuits
Frequency range up to 2MHz
Inductance Range from 100nH to 300nH
Current range from 32.5 to 94 amps
9.6x6.45mm footprint surface mount
package in a 8.0mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
HALOGEN
Pb HF
FREE
FP0906
Technical Data 4407
Effective June 2015
Product specifications
Part Number7
OCL1
(nH) ±10%
FLL2
(nH) minimum
Irms3
(amps)
Isat14
(amps)
Isat25
(amps)
DCR (mΩ) ±5%
@ 20°C
K-factor6
FP0906R1-R10-R
100
72
51
94
81
0.29
451
FP0906R1-R12-R
120
86
51
79
68
0.29
451
FP0906R1-R15-R
150
108
51
65
55
0.29
451
FP0906R1-R18-R
180
129
51
55
45
0.29
451
FP0906R1-R22-R
220
155
51
44
37.5
0.29
451
FP0906R1-R28-R
280
200
51
34
29
0.29
451
FP0906R1-R30-R
300
216
51
32.5
27.5
0.29
451
1 Open Circuit Inductance (OCL) Test Parameters: 100kHz, 1.0Vrms, 0.0Adc, +25°C
2. Full Load Inductance (FLL) Test Parameters: 100kHz, 1.0Vrms, Isat1, +25°C
3. Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat
generating components will affect the temperature rise. It is recommended that the temperature
of the part not exceed 125°C under worst case operating conditions verified in the end application.
4. Isat1 : Peak current for approximately 20% rolloff @ +25°C
5. Isat2: Peak current for approximately 20% rolloff @ +125°C
6. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * I * 10-3. Bpp :(Gauss), K: (Kfactor from table), L: (Inductance in nH), I (Peak to peak ripple current in Amps).
7. Part Number Definition: FP0906Rx-Rxx-R
FP0906 = Product code and size
Rx= DCR indicator
Rxx= Inductance value in uH, R= decimal point
-R suffix = RoHS compliant
Dimensions–mm
Recommended Pad Layout
6.2
±0.2
8.0
max
a
2.54
2.3
±0.2
1
Schematic
1
0.3 ref
10.40
0906Rx
Rxx
wwllyy R
4.00
2
2
2.14
±0.2
b
Part marking: 0906Rx (Rx=DCR indicator), Rxx=Inductance value in uH (R=decimal point),
www=date code R=revision level
The nominal DCR is measured between point “a” and point “b”
Soldering surfaces to be coplanar within 0.1 millimeters
Do not route traces or vias underneath the inductor
Packaging–mm
Supplied in tape and reel packaging , 600 parts per 13” diameter reel
4.0
1.75
2.0
1.5 dia
9.7
24.00
±0.3
11.5
12.0
1.5 dia
6.5
8.0
User direction of feed
2
www.eaton.com/elx
FP0906
Technical Data 4407
Effective June 2015
Temperature rise vs. total loss
50
45
40
Temperature Rise (°C)
35
30
25
10
1.4
1.3
1.2
1.1
1.0
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
5
Total Loss (W)
Core loss vs Bp-p
1.0MHz
500kHz
300kHz
100kHz
10
1
Core Loss (W)
0.1
0.01
0.001
1000
100
0.00001
10000
0.0001
B p-p (Gauss)
Inductance characteristics
% of OCL vs. % of Isat1
FP0906R1-R10 to R18
110%
110%
100%
100%
90%
-40C
60%
+25C
www.eaton.com/elx
140%
130%
% of Isat1
120%
70%
60%
50%
40%
30%
20%
140%
130%
30%
+85C
110%
+125C
40%
100%
50%
90%
+85C
120%
% of Isat1
100%
80%
70%
60%
50%
40%
30%
20%
0%
40%
90%
+125C
110%
50%
70%
80%
+25C
60%
80%
0%
70%
% of OCL
-40C
10%
80%
10%
% of OCL
90%
30%
% of OCL vs. % of I sat1
FP0906R1-R22 to R30
3
FP0906
Technical Data 4407
Effective June 2015
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP0906R1-R12-R”相匹配的价格&库存,您可以联系我们找货
