山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
SMF Series
Surface mount transient voltage suppressor power 200 watts
Stand-Off Voltage: 5.0V~440V
FEATURES
PINNING
• For surface mounted applications in order to
PIN
optimize board space.
• Low profile package
DESCRIPTION
1
Cathode
2
Anode
• Glass passivated junction
1
• Low inductance
2
Unipolar
• Plastic package has Underwriters Laboratory
Flammability
Bipolar
MECHANICAL DATA
Top View
▪Case: SOD-123FL
Simplified outline SOD-123FL and symbol
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪Approx. Weight:15mg/0.00048oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Symbol
Value
Unit
Peak Pulse Power Dissipation on TA=2 5°C (Note 1,2,5, Fig1)
P PPM
200
W
Peak Forward Surge Current (Note 3)
I FSM
A
Peak Pulse Current on 10/1000 us waveform (Note 1 ) Fig 2
I PPM
see Table 1
A
Steady State Power Dissipation (Note 4)
P M(AV)
1
W
Operating Junction and Storage Range
T J,T STG
-55 to +150
°C
RθJA
180
°C/W
Parameter
Typical Thermal Resistance
(UNI)
NOTES
1. Non-repetitive current pulse per Fig 3 and derated above T A=25°C per Fig 2
2. Mounted on 5mm 2 copper pads to each terminal
3. 8.3ms single half sinewave, or equivalent square wave duty cycle=4 pulses per minutes maximum
4. lead temperature at T L=75°C
5. Peak pulse powe. waveform is tp=10/1000us
6. A transient suppressor is selected according to the working peak reverse voltage(V RWM), Which Should be
equal to or greater than the DC or continuous peak operating voltage level
2020.10
SOD123FL-TVS-SMF5.0A~SMF440A-200W
Page 1 of 4
山东晶导微电子股份有限公司
SMF Series
Table 1
Characteristics at Ta = 25°C
Test
Current
Breakdown
Voltage
Type
Marking
V RMW
Reverse
Leakage
Max. Clamp
Voltage
Peak Pulse
Current
I R @ V RWM
V C @ I PP
I PP
V BR @ I T
IT
Min
Max
Uni
Bi
Uni
Bi
V
V
V
mA
μA
V
SMF5.0A
SMF5.0CA
AE
CAE
5
6.4
7
10
400
9.2
SMF6.0A
SMF6.0CA
AG
CAG
6
6.67
7.37
10
400
10.3
19.4
SMF6.5A
SMF6.5CA
AK
CAK
6.5
7.22
7.98
10
250
11.2
17.9
SMF7.0A
SMF7.0CA
AM
CAM
7
7.78
8.6
10
100
12
16.7
SMF7.5A
SMF7.5CA
AP
CAP
7.5
8.33
9.21
1
50
12.9
15.5
A
21.7
SMF8.0A
SMF8.0CA
AR
CAR
8
8.89
9.83
1
25
13.6
14.7
SMF8.5A
SMF8.5CA
AT
CAT
8.5
9.44
10.4
1
10
14.4
13.9
SMF9.0A
SMF9.0CA
AV
CAV
9
10
11.1
1
5
15.4
13
SMFl0A
SMFl0CA
AX
CAX
10
11.1
12.3
1
2.5
17
11.8
SMF11A
SMF11CA
AZ
CAZ
11
12.2
13.5
1
2.5
18.2
11
SMF12A
SMF12CA
BE
CBE
12
13.3
14.7
1
2.5
19.9
10.1
SMF13A
SMF13CA
BG
CBG
13
14.4
15.9
1
1
21.5
9.3
CBK
14
15.6
17.2
1
1
23.2
8.6
SMF14A
SMF14CA
BK
SMF15A
SMF15CA
BM
CBM
15
16.7
18.5
1
1
24.4
8.2
SMF16A
SMF16CA
BP
CBP
16
17.8
19.7
1
1
26
7.7
SMF17A
SMF17CA
BR
CBR
17
18.9
20.9
1
1
27.6
7.2
SMF18A
SMF18CA
BT
CBT
18
1
1
29.2
6.8
SMF20A
SMF20CA
BV
CBV
24.5
1
1
32.4
6.2
SMF22A
SMF22CA
BX
CBX
22
24.4
26.9
1
1
35.5
5.6
SMF24A
SMF24CA
BZ
CBZ
24
26.7
29.5
1
1
38.9
5.1
SMF26A
SMF26CA
CE
CCE
26
28.9
31.9
1
1
42.1
4.8
SMF28A
SMF28CA
CG
CCG
28
31.1
34.4
1
1
45.4
4.4
SMF30A
SMF30CA
CK
CCK
30
33.3
36.8
1
1
48.4
4.1
SMF33A
SMF33CA
CM
CCM
33
36.7
40.6
1
1
53.3
3.8
SMF36A
SMF36CA
CP
CCP
36
40
44.2
1
1
58.1
3.4
SMF40A
SMF40CA
CR
CCR
40
44.4
49.1
1
1
64.5
3.1
SMF43A
SMF43CA
CT
CCT
43
47.8
52.8
1
1
69.4
2.9
SMF45A
SMF45CA
CV
CCV
45
50
55.3
1
1
72.7
2.8
SMF48CA
CX
CCX
48
53.3
58.9
1
1
77.4
2.6
CCZ
51
56.7
62.7
1
1
82.4
2.4
SMF48A
SMF51A
SMF51CA
CZ
SMF54A
SMF54CA
DE
CDE
54
60
66.3
1
1
87.1
2.3
SMF58A
SMF58CA
DG
CDG
58
64.4
71.2
1
1
93.6
2.1
SMF60A
SMF60CA
DK
CDK
60
66.7
73.7
1
1
96.8
1.8
SMF64A
SMF64CA
DM
CDM
64
71.1
78.6
1
1
103
1.7
SMF70A
SMF70CA
DP
CDP
70
77.8
86
1
1
113
1.5
SMF75A
SMF75CA
DR
CDR
75
83.3
92.1
1
1
121
1.4
SMF78A
SMF78CA
DT
CDT
78
86.7
95.8
1
1
126
1.4
SMF85A
SMF85CA
DV
CDV
85
94.4
104
1
1
137
1.3
SMF90A
SMF90CA
DX
CDX
90
100
111
1
1
146
1.2
SMF100A
SMF100CA
DZ
CDZ
100
111
123
1
1
162
1.1
SMF110A
SMF110CA
EE
CEE
110
122
135
1
1
177
1
SMF120A
SMF120CA
EG
CEG
120
133
147
1
1
193
0.9
SMF130A
SMF130CA
EK
CEK
130
144
159
1
1
209
0.8
SMF150A
SMF150CA
EM
CEM
150
167
185
1
1
243
0.7
SMF160A
SMF160CA
EP
CEP
160
178
197
1
1
259
0.7
CER
170
189
209
1
1
275
0.6
SMF170A
SMF170CA
ER
SMF180A
SMF180CA
ET
CET
180
201
222
1
1
292
0.5
SMF190A
SMF190CA
EV
CEV
190
211
232
1
1
308
0.5
SMF200A
SMF200CA
EX
CEX
200
224
247
1
1
324
0.5
SMF220A
SMF220CA
E22
CE22
220
246
272
1
1
356
0.5
SMF250A
SMF250CA
E25
CE25
250
279
309
1
1
405
0.5
SMF300A
SMF300CA
E30
CE30
300
335
371
1
1
486
0.45
SMF350A
SMF350CA
E35
CE35
350
391
432
1
1
567
0.4
SMF400A
SMF400CA
E40
CE40
400
447
494
1
1
648
0.35
SMF440A
SMF440CA
E44
CE44
440
492
543
1
1
713
0.3
山东晶导微电子股份有限公司
SMF Series
Fig.2 Forward Current Derating Curve
10
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
1.0
0.1
0.01
0.1
1
10
100
1000
10000
PEAK PULSE POWER(PPP)OR CURRENT(Ipp)
DERATINGIN PERCENTAGE%
P PPM ,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
100
80
60
40
I ppm ,Peak Pulse Current (%)
Peak Value
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
I ppm
80
Half Value-I pp /2
60
10/1000usec Waveform as Defined bye R.E.A.
40
2.0
3.0
4.0
I FSM ,PEAK FORWARD SURGE CURRENT,
AMPERES
T A =25°C
100
125
150
175
30
25
10
05
T,TIME,ms
2020.10
100
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Pulse Waveform
t f =10usec
75
T A ,AMBIENT TEMPERATURE,°C
td,PULSE WIDTH ,us
120
50
T J =T J max
8.3ms Single Half Sinepwave
JEDEC Method
10
100
Number of Cycles at 60Hz
www.sdjingdao.com
Page 3 of 4
山东晶导微电子股份有限公司
SMF Series
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123FL
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
g
pad
e
E
A
pad
HE
Top View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
mil
Bottom View
7°
The recommended mounting pad size
2.0
(79)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
2020.10
JD 201019 4B5/4B6/5B0/5B6
Page 4 of 4
很抱歉,暂时无法提供与“SMF5.0CA”相匹配的价格&库存,您可以联系我们找货
