Additional Resources:
Product Page
3D Model
date
11/13/2019
page
1 of 3
MODEL: PR-002B │ DESCRIPTION: DC POWER RECEPTACLE
FEATURES
• 2.35 mm center pin
• 4.0 A rating
• cable mount
RoHS
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
24
rated input current
contact resistance
between terminal and mating plug
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
units
Vdc
4.0
A
30
mΩ
500
Vac
100
MΩ
insertion/withdrawal force
0.4
2
kg
operating temperature
-10
50
°C
life
5,000
flammability rating
UL94V-2 for body only
RoHS
yes
cycles
SOLDERABILITY
parameter
hand soldering
for maximum 2 seconds
min
typ
360
cuidevices.com
max
units
°C
Product Page
3D Model
CUI Devices │ MODEL: PR-002B │ DESCRIPTION: DC POWER RECEPTACLE
date 11/13/2019│ page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
tolerance: ±0.3 mm
MATERIAL
PLATING
center pin
PBS
nickel
terminal 1
BSR
nickel
terminal 2
BSR
nickel
cap
PE
body
PA
41.0 1.614
10.5 0.413
4.0 0.157
4.0 0.157
10.0 0.394
5.7 0.224
2.35 0.093
4.0 0.157
8.0 0.315
1
2
10.0 0.394
M8 x 1.0
1
SCHEMATIC
2
MATING PLUG
Jack Insertion Depth: 9.3 mm
cuidevices.com
Model
PR-002B
Center Pin
Ø2.35 mm
Product Page
3D Model
date 11/13/2019│ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
11/11/2005
1.01
updated rating
03/06/2007
1.02
added contact resistance
08/20/2010
1.03
added pin designations
09/15/2010
1.04
applied new spec template
11/01/2013
1.05
updated datasheet
03/21/2017
1.06
brand update
11/13/2019
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PR-002B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+11.25967100+1.36480
- 300+11.20706300+1.35842
- 400+11.20681400+1.35839
- 1000+11.206561000+1.35836
- 1500+11.206311500+1.35833
- 国内价格 香港价格
- 10+11.4398310+1.38664
- 30+11.3863730+1.38016
- 100+11.38611100+1.38013
- 300+11.38586300+1.38010
- 1000+11.385611000+1.38006
- 国内价格
- 10+18.13571
- 20+17.25053
- 30+16.39660
- 40+15.54787
