Additional Resources:
Product Page
3D Model
PCB Footprint
date
12/12/2019
page
1 of 4
MODEL: CMI-1295-1285T │ DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
through hole
85 dB
magnetic
internally driven
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
12
operating voltage
current consumption
typ
8
at rated voltage
rated frequency
2,000
sound pressure level
at 10 cm, rated voltage
dimensions
Ø12 x 9.5
2,300
units
Vdc
16
Vdc
30
mA
2,600
Hz
85
dB
mm
weight
2.0
material
PBT
terminal
pins (red copper with tin plating)
g
operating temperature
-30
70
°C
storage temperature
-40
85
°C
max
units
250
°C
RoHS
Notes:
yes
1. All specifications measured at 25±3°C, humidity at 60~70%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
see recommended wave soldering profile
min
5±1 s
0.5~1.5°/s
>6°/s
Temperature (°C)
250
200
150
100
50
60
90
120 150 180 210 240 270
Time (sec)
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI Devices │ MODEL: CMI-1295-1285T │ DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 12/12/2019 │ page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
3DGV
+ROH
0$6.,1*/$%(/
(32;
很抱歉,暂时无法提供与“CMI-1295-1285T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+7.06892
- 10+6.71277
- 20+6.38369
- 30+6.06711
- 50+5.75261
- 国内价格
- 10+6.71277
- 20+6.38369
- 30+6.06711
- 50+5.75261
- 国内价格
- 100+5.60786
- 200+5.43915
