BCV64B
PNP general-purpose double transistor
Rev. 4 — 2 August 2010
Product data sheet
1. Product profile
1.1 General description
PNP general-purpose double transistor in a small SOT143B Surface-Mounted
Device (SMD) plastic package.
Table 1.
Product overview
Type number
BCV64B
Package
PNP complement
Nexperia
JEITA
SOT143B
BCV63B
1.2 Features and benefits
Low current (max. 100 mA)
Low voltage (max. 30 V and 6 V)
AEC-Q101 qualified
Small SMD plastic package
1.3 Applications
General-purpose switching and amplification
For use in Schmitt trigger applications
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
−100
mA
V
Per transistor
collector current
IC
Transistor TR1
VCEO
collector-emitter voltage
open base
−30
hFE
DC current gain
VCE = −5 mV;
IC = −2 mA
220
475
−6
220
475
Transistor TR2
VCEO
hFE
[1]
open base
DC current gain
VCE = −700 V;
IC = −2 mA
Due to matched dies, hFE values for TR2 are the same as for TR1.
[1]
V
BCV64B
Nexperia
2. Pinning information
Table 3.
Pinning
Pin
Description
Simplified outline
1
collector TR2 and base TR1
2
collector TR1
3
emitter TR1 and TR2
4
base TR2
4
Graphic symbol
2
3
1
TR1
TR2
1
2
3
4
006aab230
3. Ordering information
Table 4.
Type number
BCV64B
Package
Name
Description
Version
plastic surface-mounted package; 4 leads
SOT143B
4. Marking
Table 5.
Marking codes
Type number
Marking code[1]
BCV64B
*C6
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
BCV64B
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
BCV64B
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Per transistor
VEBO
emitter-base voltage
−6
V
IC
collector current
−100
mA
ICM
peak collector current
−200
mA
IB
base current
−100
mA
open collector
Transistor TR1
VCBO
collector-base voltage
open emitter
−30
V
VCEO
open base
−30
V
Transistor TR2
VCBO
open emitter
−6
V
VCEO
open base
−6
V
Ptot
total power dissipation
Tamb ≤ 25 °C
250
mW
Per device
[1]
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB).
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from
junction to ambient
in free air
[1]
BCV64B
Product data sheet
[1]
Min
Typ
Max
Unit
500
K/W
Device mounted on an FR4 PCB.
3 of 12
BCV64B
Nexperia
7. Characteristics
Table 8.
Characteristics
Tj = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
collector-base
cut-off current
VCB = −30 V; IE = 0 A
−15
nA
VCB = −30 V; IE = 0 A;
Tj = 150 °C
−5
μA
VCEsat
collector-emitter
saturation voltage
IC = −10 mA;
IB = −0.5 mA
−75
−300
mV
VBEsat
base-emitter
saturation voltage
IC = −10 mA;
IB = −0.5 mA
−700
mV
Per transistor
ICBO
[2]
Transistor TR1
hFE
DC current gain
VCE = −5 V;
IC = −2 mA
220
475
VCEsat
collector-emitter
saturation voltage
IC = −100 mA;
IB = −5 mA
−250
−650
mV
VBEsat
base-emitter
saturation voltage
IC = −100 mA;
IB = −5 mA
[2]
−850
mV
VBE
base-emitter voltage
IC = −2 mA;
VCE = −5 V
[3]
−600
−650
−750
mV
IC = −10 mA;
VCE = −5 V
[3]
−820
mV
fT
transition frequency
VCE = −5 V;
IC = −10 mA;
f = 100 MHz
100
MHz
Cc
collector capacitance
VCB = −10 V;
IE = ie = 0 A;
f = 1 MHz
4
pF
220
475
−250
mV
−700
mV
Transistor TR2
BCV64B
Product data sheet
hFE
DC current gain
VCE = −700 mV;
IC = −2 mA
VCEsat
collector-emitter
saturation voltage
IC = −100 mA;
IB = −5 mA
VBE
IC = −2 mA;
VCE = −700 mV
[1]
[3]
[1]
[2]
VBEsat decreases by about 1.7 mV/K with increasing temperature.
[3]
VBE decreases by about 2 mV/K with increasing temperature.
4 of 12
BCV64B
Nexperia
mgt715
1000
hFE
800
mgt716
−1200
VBE
(mV)
−1000
(1)
−800
600
(2)
(1)
−600
400
200
−10−2
−10−1
(2)
−400
(3)
−200
−1
−10
(3)
−10−2
−102
−103
IC (mA)
VCE = −5 V
−10−1
−1
−102
−103
IC (mA)
VCE = −5 V
(1) Tamb = 150 °C
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
(3) Tamb = 150 °C
Fig 1.
−10
DC current gain as a function of collector
current; typical values
mgt717
−104
VCEsat
(mV)
Fig 2.
Base-emitter voltage as a function of collector
mgt718
−1200
VBEsat
(mV)
−1000
(1)
−800
−103
(2)
−600
(3)
−400
−102
(1)
−200
(3) (2)
−10
−10−1
−1
−10
−102
−10−1
−103
−1
−10
−102
IC (mA)
IC/IB = 20
IC/IB = 20
(1) Tamb = 150 °C
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
(3) Tamb = 150 °C
Fig 3.
Collector-emitter saturation voltage as a
function of collector current; typical values
BCV64B
Product data sheet
−103
IC (mA)
Fig 4.
Base-emitter saturation voltage as a function
5 of 12
BCV64B
Nexperia
8. Application information
Rc
Rc
1
R1
4
2
Vo
TR1
TR2
3
R2
3
Vi
mgd828
Fig 5.
9. Test information
9.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
BCV64B
Product data sheet
6 of 12
BCV64B
Nexperia
10. Package outline
3.0
2.8
1.1
0.9
1.9
4
2.5
2.1
3
0.45
0.15
1.4
1.2
1
2
0.88
0.78
0.48
0.38
0.15
0.09
1.7
Dimensions in mm
Fig 6.
04-11-16
Package outline SOT143B
11. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
BCV64B
[1]
BCV64B
Product data sheet
Package
SOT143B
Description
4 mm pitch, 8 mm tape and reel
Packing quantity
3000
10000
-215
-235
For further information and the availability of packing methods, see Section 15.
7 of 12
BCV64B
Nexperia
12. Soldering
3.25
0.6
(3×)
0.5
(3×)
1.9
solder lands
0.7 0.6
(3×) (3×)
solder resist
2
solder paste
3
occupied area
0.7 0.6
Dimensions in mm
0.75
0.95
0.9
1
Fig 7.
sot143b_fr
Reflow soldering footprint SOT143B
4.45
2.2
1.2
(3×)
1.425
(3×)
solder lands
solder resist
4.6
2.575
occupied area
Dimensions in mm
1.425
preferred transport direction during soldering
1
1.2
Fig 8.
BCV64B
Product data sheet
sot143b_fw
Wave soldering footprint SOT143B
8 of 12
BCV64B
Nexperia
13. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BCV64B v.4
20100802
Product data sheet
BCV64B_3
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Section 1 “Product profile”: amended.
Section 3 “Ordering information”: added.
Section 4 “Marking”: updated.
Figure 1, 2, 3 and 4: added.
Section 8 “Application information”: added.
Section 9 “Test information”: added.
Figure 6: superseded by minimized package outline drawing.
Section 11 “Packing information”: added.
Section 12 “Soldering”: added.
Section 14 “Legal information”: updated.
BCV64B_3
19990521
Product specification
BCV64_CNV_2
BCV64_CNV_2
19970310
BCV64B
Product data sheet
9 of 12
BCV64B
Nexperia
14. Legal information
14.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
BCV64B
Product data sheet
10 of 12
BCV64B
Nexperia
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
14.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
15. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BCV64B
Product data sheet
11 of 12
Nexperia
BCV64B
16. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
10
11
12
13
14
14.1
14.2
14.3
14.4
15
16
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Application information. . . . . . . . . . . . . . . . . . . 6
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6
Quality information . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7
Packing information . . . . . . . . . . . . . . . . . . . . . 7
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Date of release: 02 August 2010
