PESDxU1UT series
Ultra low capacitance ESD protection diode in SOT23 package
Rev. 02 — 20 August 2009
Product data sheet
1. Product profile
1.1 General description
Ultra low capacitance ElectroStatic Discharge (ESD) protection diode in a SOT23
(TO-236AB) small SMD plastic package designed to protect one high-speed data line
from the damage caused by ESD and other transients.
1.2 Features
n
n
n
n
Unidirectional ESD protection of one line
Ultra low diode capacitance: Cd = 0.6 pF
Max. peak pulse power: PPP up to 200 W
Low clamping voltage
n ESD protection > 23 kV
n IEC 61000-4-2; level 4 (ESD)
n IEC 61000-4-5; (surge)
1.3 Applications
n 10/100/1000 Ethernet
n FireWire
n Communication systems
n Local Area Network (LAN) equipment
n Computers and peripherals
n High-speed data lines
1.4 Quick reference data
Table 1.
Symbol
Parameter
VRWM
reverse stand-off voltage
Conditions
Min
Typ
Max
Unit
PESD3V3U1UT
3.3
V
PESD5V0U1UT
5.0
V
PESD12VU1UT
12
V
PESD15VU1UT
15
V
PESD24VU1UT
Cd
[1]
diode capacitance
Measured from pin 1 to 2
f = 1 MHz; VR = 0 V
[1]
24
V
0.6
1.5
pF
PESDxU1UT series
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Description
Simplified outline
1
cathode ESD protection diode
2
cathode compensation diode
3
common anode
Symbol
3
1
3
2
1
2
006aaa441
3. Ordering information
Table 3.
Type number
PESD3V3U1UT
Package
Name
Description
Version
plastic surface mounted package; 3 leads
SOT23
PESD5V0U1UT
PESD12VU1UT
PESD15VU1UT
PESD24VU1UT
4. Marking
Table 4.
Marking codes
Marking code[1]
Type number
PESD3V3U1UT
*AP
PESD5V0U1UT
*AQ
PESD12VU1UT
*AR
PESD15VU1UT
*AS
PESD24VU1UT
*AT
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
PESDXU1UT_SER_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 13
PESDxU1UT series
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Min
Max
Unit
PESD3V3U1UT
80
W
PESD5V0U1UT
80
W
PESD12VU1UT
200
W
PESD15VU1UT
200
W
200
W
PESD3V3U1UT
5
A
PESD5V0U1UT
5
A
PESD12VU1UT
5
A
PESD15VU1UT
5
A
PESD24VU1UT
3
A
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
PPP
Parameter
Conditions
peak pulse power
8/20 µs
[1]
PESD24VU1UT
peak pulse current
IPP
[1]
8/20 µs
Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5.
PESDXU1UT_SER_2
Product data sheet
[1]
3 of 13
PESDxU1UT series
Nexperia
Table 6.
ESD maximum ratings
Symbol
Parameter
Conditions
Min
Max
Unit
PESD3V3U1UT
30
kV
PESD5V0U1UT
30
kV
PESD12VU1UT
30
kV
PESD15VU1UT
30
kV
PESD24VU1UT
23
kV
10
kV
electrostatic discharge voltage
VESD
PESDxU1UT
IEC 61000-4-2
(contact discharge)
HBM MIL-STD-883
[1]
Device stressed with ten non-repetitive ESD pulses.
[2]
Table 7.
[1][2]
ESD standards compliance
Standard
Conditions
> 15 kV (air); > 8 kV (contact)
HBM MIL-STD-883; class 3
> 4 kV
001aaa631
IPP
001aaa630
120
100 %
90 %
100 % IPP; 8 µs
IPP
80
e−t
50 % IPP; 20 µs
40
10 %
30 ns
40
t (µs)
Fig 1.
t
tr = 0.7 ns to 1 ns
60 ns
8/20 µs pulse waveform according to
IEC 61000-4-5
Fig 2.
ESD pulse waveform according to
IEC 61000-4-2
PESDXU1UT_SER_2
Product data sheet
4 of 13
PESDxU1UT series
Nexperia
6. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified
Symbol
Parameter
VRWM
Conditions
Min
Typ
Max
Unit
PESD3V3U1UT
3.3
V
PESD5V0U1UT
5.0
V
PESD12VU1UT
12
V
PESD15VU1UT
15
V
PESD24VU1UT
24
V
reverse leakage current
IRM
PESD3V3U1UT
VRWM = 3.3 V
0.25
2
µA
PESD5V0U1UT
VRWM = 5.0 V
0.03
1
µA
PESD12VU1UT
VRWM = 12 V
很抱歉,暂时无法提供与“PESD12VU1UT,215”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.102001+0.37600
- 10+1.9358010+0.23470
- 100+0.88160100+0.10690
- 1000+0.621601000+0.07540
- 3000+0.386003000+0.04680
- 9000+0.377809000+0.04580
- 国内价格 香港价格
- 3000+0.389143000+0.04717
- 9000+0.387329000+0.04695
- 15000+0.3873115000+0.04695
- 45000+0.3873045000+0.04695
- 75000+0.3872975000+0.04695
