PESD5V0L5UF,115
PESD5V0L5UF,115
    NEXPERIA(安世)
    SOT886
    ESD VRWM=5 V VBR(Min)=6.4 V VC=12 V IPP=2.5 A Ppp=25 W SOT886
PESD5V0L5UF,115 数据手册
PESDxL5UF; PESDxL5UV; PESDxL5UY Low capacitance unidirectional fivefold ESD protection diode arrays Rev. 02 — 8 January 2008 Product data sheet 1. Product profile 1.1 General description Low capacitance unidirectional fivefold ElectroStatic Discharge (ESD) protection diode arrays in small Surface-Mounted Device (SMD) plastic packages designed to protect up to five unidirectional signal lines from the damage caused by ESD and other transients. Table 1. Product overview Type number Package Package configuration Nexperia JEITA JEDEC PESD3V3L5UF SOT886 - MO-252 leadless ultra small PESD5V0L5UF SOT886 - MO-252 leadless ultra small PESD3V3L5UV SOT666 - - ultra small and flat lead PESD5V0L5UV SOT666 - - ultra small and flat lead PESD3V3L5UY SOT363 SC-88 - very small PESD5V0L5UY SOT363 SC-88 - very small 1.2 Features n n n n ESD protection of up to five lines Low diode capacitance Max. peak pulse power: PPP = 25 W Low clamping voltage: VCL = 12 V n n n n Ultra low leakage current: IRM = 5 nA ESD protection up to 20 kV IEC 61000-4-2; level 4 (ESD) IEC 61000-4-5 (surge); IPP = 2.5 A 1.3 Applications n Computers and peripherals n Audio and video equipment n Cellular handsets and accessories n Communication systems n Portable electronics n Subscriber Identity Module (SIM) card protection PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 1.4 Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit PESD3V3L5UF PESD3V3L5UV PESD3V3L5UY - - 3.3 V PESD5V0L5UF PESD5V0L5UV PESD5V0L5UY - - 5.0 V PESD3V3L5UF PESD3V3L5UV PESD3V3L5UY - 22 28 pF PESD5V0L5UF PESD5V0L5UV PESD5V0L5UY - 16 19 pF Per diode VRWM Cd reverse standoff voltage diode capacitance f = 1 MHz; VR = 0 V 2. Pinning information Table 3. Pinning Pin Description Simplified outline Symbol PESD3V3L5UF; PESD5V0L5UF 1 cathode (diode 1) 2 common anode 3 1 2 3 1 6 cathode (diode 2) 2 5 4 cathode (diode 3) 3 4 5 cathode (diode 4) 6 cathode (diode 5) 6 5 bottom view 006aaa159 4 PESD3V3L5UV; PESD5V0L5UV 1 cathode (diode 1) 2 common anode 3 4 5 cathode (diode 4) 6 cathode (diode 5) 5 4 1 6 cathode (diode 2) 2 5 cathode (diode 3) 3 4 1 2 006aaa159 3 © PESDXL5UF_V_Y_2 Product data sheet 6 Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 2 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays Table 3. Pinning …continued Pin Description Simplified outline Symbol PESD3V3L5UY; PESD5V0L5UY 1 cathode (diode 1) 2 common anode 3 cathode (diode 2) 4 cathode (diode 3) 5 cathode (diode 4) 6 cathode (diode 5) 6 1 5 2 4 1 6 2 5 3 4 3 006aaa159 3. Ordering information Table 4. Ordering information Type number PESD3V3L5UF Package Name Description Version XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1.45 × 0.5 mm SOT886 - plastic surface-mounted package; 6 leads SOT666 SC-88 plastic surface-mounted package; 6 leads SOT363 PESD5V0L5UF PESD3V3L5UV PESD5V0L5UV PESD3V3L5UY PESD5V0L5UY 4. Marking Table 5. Marking codes Type number Marking code[1] PESD3V3L5UF A1 PESD5V0L5UF A2 PESD3V3L5UV E1 PESD5V0L5UV E2 PESD3V3L5UY K3* PESD5V0L5UY K4* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 3 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions PPP peak pulse power tp = 8/20 µs IPP peak pulse current tp = 8/20 µs Min Max Unit [1][2] - 25 W [1][2] - 2.5 A Per diode Per device Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5. [2] Measured from pin 1, 3, 4, 5 or 6 to pin 2. Table 7. ESD maximum ratings Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions electrostatic discharge voltage IEC 61000-4-2 (contact discharge) Min Max Unit - 20 kV - 10 kV Per diode VESD MIL-STD-883 (human body model) [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1, 3, 4, 5 or 6 to pin 2. Table 8. [1][2] ESD standards compliance Standard Conditions Per diode IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 4 kV © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 4 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 µs IPP (%) 80 e−t 50 % IPP; 20 µs 40 10 % t tr = 0.7 ns to 1 ns 0 0 10 20 30 30 ns 40 t (µs) 60 ns Fig 1. 8/20 µs pulse waveform according to IEC 61000-4-5 Fig 2. ESD pulse waveform according to IEC 61000-4-2 6. Characteristics Table 9. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit PESD3V3L5UF PESD3V3L5UV PESD3V3L5UY - - 3.3 V PESD5V0L5UF PESD5V0L5UV PESD5V0L5UY - - 5.0 V Per diode VRWM IRM VBR reverse standoff voltage reverse leakage current PESD3V3L5UF PESD3V3L5UV PESD3V3L5UY VRWM = 3.3 V - 75 300 nA PESD5V0L5UF PESD5V0L5UV PESD5V0L5UY VRWM = 5.0 V - 5 25 nA PESD3V3L5UF PESD3V3L5UV PESD3V3L5UY 5.3 5.6 5.9 V PESD5V0L5UF PESD5V0L5UV PESD5V0L5UY 6.4 6.8 7.2 V breakdown voltage IR = 1 mA © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 5 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays Table 9. Characteristics …continued Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Cd f = 1 MHz; VR = 0 V VCL rdif Min Typ Max Unit PESD3V3L5UF PESD3V3L5UV PESD3V3L5UY - 22 28 pF PESD5V0L5UF PESD5V0L5UV PESD5V0L5UY - 16 19 pF diode capacitance [1][2] clamping voltage PESD3V3L5UF PESD3V3L5UV PESD3V3L5UY IPP = 1 A - - 10 V PESD3V3L5UF PESD3V3L5UV PESD3V3L5UY IPP = 2.5 A - - 12 V PESD5V0L5UF PESD5V0L5UV PESD5V0L5UY IPP = 1 A - - 10 V PESD5V0L5UF PESD5V0L5UV PESD5V0L5UY IPP = 2.5 A - - 12 V differential resistance IR = 1 mA PESD3V3L5UF PESD3V3L5UV PESD3V3L5UY - - 200 Ω PESD5V0L5UF PESD5V0L5UV PESD5V0L5UY - - 100 Ω [1] Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5. [2] Measured from pin 1, 3, 4, 5 or 6 to pin 2. © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 6 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 006aab139 102 006aab140 1.2 PPP PPP(25°C) 1.0 PPP (W) 0.8 10 0.6 0.4 0.2 1 1 102 10 103 104 0 0 50 100 150 tp (µs) Tj (°C) Tamb = 25 °C Fig 3. Peak pulse power as a function of exponential pulse duration; typical values 006aab141 25 Fig 4. Relative variation of peak pulse power as a function of junction temperature; typical values 006aab142 10 Cd (pF) 20 IR IR(25°C) 15 (1) 1 (2) 10 5 0 0 1 2 3 4 5 10−1 −75 −25 25 75 125 VR (V) 175 Tj (°C) f = 1 MHz; Tamb = 25 °C (1) PESD3V3L5UF; PESD3V3L5UV; PESD3V3L5UY (2) PESD5V0L5UF; PESD5V0L5UV; PESD5V0L5UY Fig 5. Diode capacitance as a function of reverse voltage; typical values Fig 6. Relative variation of reverse current as a function of junction temperature; typical values © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 7 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays I −VCL −VBR −VRWM V −IRM −IR − + P-N −IPP 006aaa407 Fig 7. V-I characteristics for a unidirectional ESD protection diode © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 8 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays ESD TESTER RZ 450 Ω RG 223/U 50 Ω coax 4 GHz DIGITAL OSCILLOSCOPE 10× ATTENUATOR (1) 50 Ω CZ IEC 61000-4-2 network CZ = 150 pF; RZ = 330 Ω DUT Device Under Test (1): attenuator is only used for open socket high voltage measurements vertical scale = 200 V/div horizontal scale = 50 ns/div vertical scale = 5 V/div horizontal scale = 50 ns/div PESD5V0L5UF/V/Y GND1 GND PESD3V3L5UF/V/Y GND2 unclamped +1 kV ESD voltage waveform (IEC 61000-4-2 network) clamped +1 kV ESD voltage waveform (IEC 61000-4-2 network) GND GND vertical scale = 200 V/div horizontal scale = 50 ns/div unclamped −1 kV ESD voltage waveform (IEC 61000-4-2 network) vertical scale = 5 V/div horizontal scale = 50 ns/div clamped −1 kV ESD voltage waveform (IEC 61000-4-2 network) 006aab143 Fig 8. ESD clamping test setup and waveforms © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 9 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 7. Application information The devices are designed for the protection of up to five unidirectional data or signal lines from the damage caused by ESD and surge pulses. The devices may be used on lines where the signal polarities are both, positive and negative with respect to ground. The devices provide a surge capability of 25 W per line for an 8/20 µs waveform each. high-speed data lines high-speed data lines DUT DUT GND GND 006aab144 Fig 9. Typical application for unidirectional application of five lines 006aab145 Fig 10. Typical application for bidirectional application of four lines Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. Place the device as close to the input terminal or connector as possible. 2. The path length between the device and the protected line should be minimized. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Ground planes should be used whenever possible. For multilayer PCBs, use ground vias. © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 10 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 8. Package outline 0.50 max 1.05 0.95 1.7 1.5 0.04 max 0.6 3 4 2 5 1 6 0.40 0.32 0.35 0.27 6 0.6 0.5 5 4 0.25 0.17 0.3 0.1 0.5 1.5 1.4 1.7 1.5 1.3 1.1 pin 1 index 0.5 1 2 3 0.27 0.17 0.5 0.18 0.08 1 Dimensions in mm 04-07-22 Fig 11. Package outline PESDxL5UF (SOT886) Dimensions in mm Fig 12. Package outline PESDxL5UV (SOT666) 2.2 1.8 6 2.2 1.35 2.0 1.15 04-11-08 1.1 0.8 5 4 2 3 0.45 0.15 pin 1 index 1 0.3 0.2 0.65 0.25 0.10 1.3 Dimensions in mm 06-03-16 Fig 13. Package outline PESDxL5UY (SOT363/SC-88) © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 11 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 9. Packing information Table 10. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PESD3V3L5UF PESD5V0L5UF PESD3V3L5UV PESD5V0L5UV Package SOT886 SOT886 SOT666 SOT666 Description Packing quantity 3000 4000 5000 8000 10000 4 mm pitch, 8 mm tape and reel; T1 [2] - - -115 - - 4 mm pitch, 8 mm tape and reel; T4 [3] - - -132 - - 4 mm pitch, 8 mm tape and reel; T1 [2] - - -115 - - 4 mm pitch, 8 mm tape and reel; T4 [3] - - -132 - - 2 mm pitch, 8 mm tape and reel - - - -315 - 4 mm pitch, 8 mm tape and reel - -115 - - - 2 mm pitch, 8 mm tape and reel - - - -315 - 4 mm pitch, 8 mm tape and reel PESD3V3L5UY PESD5V0L5UY SOT363 SOT363 - -115 - - - 4 mm pitch, 8 mm tape and reel; T1 [2] -115 - - - -135 4 mm pitch, 8 mm tape and reel; T2 [4] -125 - - - -165 4 mm pitch, 8 mm tape and reel; T1 [2] -115 - - - -135 4 mm pitch, 8 mm tape and reel; T2 [4] -125 - - - -165 [1] For further information and the availability of packing methods, see Section 13. [2] T1: normal taping [3] T4: 90° rotated reverse taping [4] T2: reverse taping 10. Soldering 1.250 0.675 0.370 (6×) 0.500 1.700 solder lands 0.500 solder paste 0.270 (6×) occupied area Dimensions in mm 0.325 (6×) 0.425 (6×) sot886_fr Reflow soldering is the only recommended soldering method. Fig 14. Reflow soldering footprint PESDxL5UF (SOT886) © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 12 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 2.75 2.45 2.10 1.60 0.15 (4×) 0.40 (6×) 2.00 1.70 1.00 0.55 (2×) 0.30 (2×) 0.375 (4×) 1.20 2.20 2.50 solder lands placement area solder resist occupied area 0.075 Dimensions in mm Reflow soldering is the only recommended soldering method. Fig 15. Reflow soldering footprint PESDxL5UV (SOT666) 2.65 0.60 (2×) 0.40 0.90 2.10 (2×) 2.35 solder lands solder paste 0.50 (4×) solder resist occupied area 0.50 (4×) Dimensions in mm 1.20 2.40 sot363 Fig 16. Reflow soldering footprint PESDxL5UY (SOT363/SC-88) © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 13 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 5.25 0.30 1.00 4.00 4.50 solder lands 1.15 3.75 solder resist occupied area transport direction during soldering Dimensions in mm sot363 Fig 17. Wave soldering footprint PESDxL5UY (SOT363/SC-88) © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 14 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes PESDXL5UF_V_Y_2 20080108 Product data sheet - Modifications: PESD3V3L5UV_ PESD5V0L5UV_1 PESD3V3L5UY_ PESD5V0L5UY_1 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • • • • • • Legal texts have been adapted to the new company name where appropriate. Type numbers PESD3V3L5UF and PESD5V0L5UF added Table 1 “Product overview”: added Section 4 “Marking”: marking code for PESD3V3L5UV amended Section 4 “Marking”: marking code for PESD5V0L5UV amended Section 4 “Marking”: marking code for PESD3V3L5UY amended Section 4 “Marking”: marking code for PESD5V0L5UY amended Figure 7: added Section 9 “Packing information”: added Section 10 “Soldering”: added Section 12 “Legal information”: updated PESD3V3L5UV_PESD5V0L5UV_1 20040323 Product specification - - PESD3V3L5UY_PESD5V0L5UY_1 20040323 Product specification - - © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 15 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © PESDXL5UF_V_Y_2 Product data sheet Rev. 02 — 8 January 2008 Nexperia B.V. 2017. All rights reserved 16 of 17 PESDxL5UF/V/Y Nexperia Low capacitance unidirectional fivefold ESD protection diode arrays 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Application information. . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Packing information. . . . . . . . . . . . . . . . . . . . . 12 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 08 January 2008
PESD5V0L5UF,115 价格&库存
很抱歉,暂时无法提供与“PESD5V0L5UF,115”相匹配的价格&库存,您可以联系我们找货
PESD5V0L5UF,115
  • 1+3.165031+0.39581
  • 10+2.4593010+0.30756
  • 100+1.47661100+0.18466
  • 500+1.36701500+0.17096
  • 1000+0.929551000+0.11625
  • 2000+0.855722000+0.10702
库存:23285
PESD5V0L5UF,115
库存:372
