74LVC1G3157GN,132
74LVC1G3157GN,132
    NEXPERIA(安世)
    XSON6_0.9X1MM
    2声道模拟多路复用器/解复用器
74LVC1G3157GN,132 数据手册
74LVC1G3157 2-channel analog multiplexer/demultiplexer Rev. 7 — 14 February 2017 1 Product data sheet General description The 74LVC1G3157 provides one analog multiplexer/demultiplexer with one digital select input (S), two independent inputs/outputs (Y0, Y1) and a common input/output (Z). Schmitt trigger action at the select input makes the circuit tolerant of slower input rise and fall times across the entire VCC range from 1.65 V to 5.5 V. 2 Features and benefits • Wide supply voltage range from 1.65 V to 5.5 V • Very low ON resistance: – 7.5 Ω (typical) at VCC = 2.7 V – 6.5 Ω (typical) at VCC = 3.3 V – 6 Ω (typical) at VCC = 5 V • Switch current capability of 32 mA • Break-before-make switching • High noise immunity • CMOS low power consumption • TTL interface compatibility at 3.3 V • Latch-up performance meets requirements of JESD 78 Class I • ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V • Control input accepts voltages up to 5.5 V • Multiple package options • Specified from -40 °C to +85 °C and from -40 °C to +125 °C 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G3157GW -40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74LVC1G3157GV -40 °C to +125 °C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74LVC1G3157GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1.45 × 0.5 mm SOT886 74LVC1G3157GF -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1 × 0.5 mm SOT891 74LVC1G3157GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 × 1.0 × 0.35 mm SOT1115 74LVC1G3157GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 × 1.0 × 0.35 mm SOT1202 74LVC1G3157GX -40 °C to +125 °C X2SON6 plastic thermal extremely thin small outline package; no leads; 6 terminals; body 1 × 0.8 × 0.35 mm 4 Marking Table 2. Marking Type number Marking code 74LVC1G3157GW YJ 74LVC1G3157GV YJ 74LVC1G3157GM YJ 74LVC1G3157GF YJ 74LVC1G3157GN YJ 74LVC1G3157GS YJ 74LVC1G3157GX YJ [1] SOT1255 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 5 Functional diagram Y1 S 1 Y1 3 Y0 Z S 6 Z 4 Y0 001aac355 001aac354 Figure 1. Logic symbol 6 Figure 2. Logic diagram Pinning information 6.1 Pinning 74LVC1G3157 Y1 1 6 S GND 2 5 VCC Y0 3 4 Z 74LVC1G3157 Y1 1 6 S GND 2 5 VCC Y0 3 4 Z Transparent top view 001aac357 001aac356 Figure 3. Pin configuration SOT363 and SOT457 Figure 4. Pin configuration SOT886 74LVC1G3157 Y1 1 6 S GND 2 5 VCC Y0 3 4 Z 74LVC1G3157 Y1 1 GND Figure 5. Pin configuration SOT891, SOT1115 and SOT1202 74LVC1G3157 Product data sheet 2 3 Y0 001aaf546 Transparent top view S 6 5 VCC 4 Z aaa-022365 Transparent top view Figure 6. Pin configuration SOT1255 All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 6.2 Pin description Table 3. Pin description Symbol Pin Description Y1 1 independent input or output GND 2 ground (0 V) Y0 3 independent input or output Z 4 common output or input VCC 5 supply voltage S 6 select input 7 Functional description Table 4. Function table [1] Input S Channel on L Y0 H Y1 [1] H = HIGH voltage level; L = LOW voltage level. 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions supply voltage [1] VI input voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V ISK switch clamping current VI < -0.5 V or VI > VCC + 0.5 V VSW switch voltage enable and disable mode ISW switch current VSW > -0.5 V or VSW < VCC + 0.5 V ICC [2] Min Max Unit -0.5 +6.5 V -0.5 +6.5 V -50 - mA - ±50 mA -0.5 VCC + 0.5 V - ±50 mA supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C - 250 mW Ptot [1] [2] [3] total power dissipation Tamb = -40 °C to +125 °C [3] The minimum input voltage rating may be exceeded if the input current rating is observed. The minimum and maximum switch voltage ratings may be exceeded if the switch clamping current rating is observed. For SC-88 and SC-74 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON6 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 9 Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage Conditions VSW switch voltage Tamb ambient temperature Δt/ΔV [1] [2] input transition rise and fall rate Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V 0 - VCC V °C enable and disable mode [1] -40 - +125 VCC = 1.65 V to 2.7 V [2] - - 20 ns/V VCC = 2.7 V to 5.5 V [2] - - 10 ns/V To avoid sinking GND current from terminal Z when switch current flows in terminal Yn, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal Z, no GND current will flow from terminal Yn. In this case, there is no limit for the voltage drop across the switch. Applies to control signal levels. 10 Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground 0 V). Symbol Parameter Conditions -40 °C to +85 °C Min VIH HIGH-level input voltage VCC = 1.65 V to 1.95 V LOW-level input voltage [1] Max Min Max Unit 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 3 V to 3.6 V 2.0 - - 2.0 - V 0.7VCC - - 0.7VCC - V VCC = 1.65 V to 1.95 V - - 0.35VCC - 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 3 V to 3.6 V - - 0.8 - 0.8 V 0.3VCC V VCC = 4.5 V to 5.5 V VIL Typ -40 °C to +125 °C VCC = 4.5 V to 5.5 V - - 0.3VCC - ±0.1 ±1 - ±1 μA II input leakage current pin S; VI = 5.5 V or GND; VCC = 0 V to 5.5 V [2] IS(OFF) OFF-state leakage current VCC = 5.5 V; see Figure 7 [2] - ±0.1 ±0.2 - ±0.5 μA IS(ON) ON-state leakage current VCC = 5.5 V; see Figure 8 [2] - ±0.1 ±1 - ±2 μA ICC supply current VI = 5.5 V or GND; VSW = GND or VCC; VCC = 1.65 V to 5.5 V [2] - 0.1 4 - 4 μA ΔICC additional supply current pin S; VI = VCC - 0.6 V; VCC = 5.5 V; VSW = GND or VCC [2] - 5 500 - 500 μA CI input capacitance - 2.5 - - - pF 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer Symbol Parameter Conditions -40 °C to +85 °C Min Typ [1] -40 °C to +125 °C Max Min Max Unit CS(OFF) OFF-state capacitance - 6.0 - - - pF CS(ON) ON-state capacitance - 18 - - - pF [1] [2] Typical values are measured at Tamb = 25 °C. These typical values are measured at VCC = 3.3 V 10.1 Test circuits VCC S VIL or VIH Y0 Z Y1 1 switch 2 switch S 1 VIH 2 VIL IS VI VO GND 001aac358 VI = VCC or GND and VO = GND or VCC. Figure 7. Test circuit for measuring OFF-state leakage current VCC VIL or VIH IS S Y0 1 Z Y1 2 VI switch switch S 1 VIH 2 VIL VO GND 001aac359 VI = VCC or GND and VO = open circuit. Figure 8. Test circuit for measuring ON-state leakage current 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 10.2 ON resistance Table 8. ON resistance At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Figure 10 to Figure 15. Symbol Parameter Conditions -40 °C to +85 °C [1] Min Typ RON(peak) ON resistance (peak) RON(rail) ON resistance (rail) -40 °C to +125 °C Unit Max Min Max VI = GND to VCC; see Figure 9 ISW = 4 mA; VCC = 1.65 V to 1.95 V - 34.0 130 - 195 Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 12.0 30 - 45 Ω ISW = 12 mA; VCC = 2.7 V - 10.4 25 - 38 Ω ISW = 24 mA; VCC = 3 V to 3.6 V - 7.8 20 - 30 Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 6.2 15 - 23 Ω ISW = 4 mA; VCC = 1.65 V to 1.95 V - 8.2 18 - 27 Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 7.1 16 - 24 Ω ISW = 12 mA; VCC = 2.7 V - 6.9 14 - 21 Ω ISW = 24 mA; VCC = 3 V to 3.6 V - 6.5 12 - 18 Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 5.8 10 - 15 Ω ISW = 4 mA; VCC = 1.65 V to 1.95 V - 10.4 30 - 45 Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 7.6 20 - 30 Ω ISW = 12 mA; VCC = 2.7 V - 7.0 18 - 27 Ω ISW = 24 mA; VCC = 3 V to 3.6 V - 6.1 15 - 23 Ω - 4.9 10 - 15 Ω ISW = 4 mA; VCC = 1.65 V to 1.95 V - 26.0 - - - Ω ISW = 8 mA; VCC = 2.3 V to 2.7 V - 5.0 - - - Ω ISW = 12 mA; VCC = 2.7 V - 3.5 - - - Ω ISW = 24 mA; VCC = 3 V to 3.6 V - 2.0 - - - Ω ISW = 32 mA; VCC = 4.5 V to 5.5 V - 1.5 - - - Ω VI = GND; see Figure 9 VI = VCC; see Figure 9 ISW = 32 mA; VCC = 4.5 V to 5.5 V RON(flat) [1] [2] ON resistance (flatness) [2] VI = GND to VCC Typical values are measured at Tamb = 25 °C and nominal VCC. Flatness is defined as the difference between the maximum and minimum value of ON resistance measured at identical VCC and temperature. 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 10.3 ON resistance test circuit and graphs mna673 40 RON (Ω) 30 (1) 20 VSW 10 V VCC VIL or VIH (2) (3) S Y0 1 Z Y1 2 switch S 1 VIL 2 VIH switch ISW VI GND 001aac360 RON = VSW / ISW Figure 9. Test circuit for measuring ON resistance 001aaa712 55 RON (Ω) (4) 0 0 1 (5) 2 3 4 VI (V) 5 (1) VCC = 1.8 V. (2) VCC = 2.5 V. (3) VCC = 2.7 V. (4) VCC = 3.3 V. (5) VCC = 5.0 V. Figure 10. Typical ON resistance as a function of input voltage; Tamb = 25 °C 001aaa708 15 RON (Ω) 45 13 35 11 (4) (3) (2) (1) 25 (1) (2) 9 (3) (4) 15 5 7 0 0.4 0.8 1.2 1.6 VI (V) 2.0 (1) Tamb = 125 °C. (2) Tamb = 85 °C. (3) Tamb = 25 °C. (4) Tamb = -40 °C. Product data sheet 0 0.5 1.0 1.5 2.0 VI (V) 2.5 (1) Tamb = 125 °C. (2) Tamb = 85 °C. (3) Tamb = 25 °C. (4) Tamb = -40 °C. Figure 11. ON resistance as a function of input voltage; VCC = 1.8 V 74LVC1G3157 5 Figure 12. ON resistance as a function of input voltage; VCC = 2.5 V All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 001aaa709 13 001aaa710 10 RON (Ω) RON (Ω) 11 8 (1) (1) 9 (2) (2) 6 (3) (3) 7 (4) 5 0 0.5 1.0 (4) 1.5 2.0 4 2.5 3.0 VI (V) (1) Tamb = 125 °C. (2) Tamb = 85 °C. (3) Tamb = 25 °C. (4) Tamb = -40 °C. 0 1 2 3 VI (V) 4 (1) Tamb = 125 °C. (2) Tamb = 85 °C. (3) Tamb = 25 °C. (4) Tamb = -40 °C. Figure 13. ON resistance as a function of input voltage; VCC = 2.7 V Figure 14. ON resistance as a function of input voltage; VCC = 3.3 V 001aaa711 7 RON (Ω) 6 5 (1) (2) (3) 4 (4) 3 0 1 2 3 4 VI (V) 5 (1) Tamb = 125 °C. (2) Tamb = 85 °C. (3) Tamb = 25 °C. (4) Tamb = -40 °C. Figure 15. ON resistance as a function of input voltage; VCC = 5.0 V 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 11 Dynamic characteristics Table 9. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 19. Symbol Parameter Conditions -40 °C to +85 °C Min tpd propagation delay Z to Yn or Yn to Z; see Figure 16 enable time disable time [1] [2] [3] [4] [5] [6] break-beforemake time Min Max - - 2 - 3.0 ns VCC = 2.3 V to 2.7 V - - 1.2 - 2.0 ns VCC = 2.7 V - - 1.0 - 1.5 ns VCC = 3 V to 3.6 V - - 0.8 - 1.5 ns - - 0.6 - 1.0 ns VCC = 1.65 V to 1.95 V 3.1 8.7 20.8 3.1 22.0 ns VCC = 2.3 V to 2.7 V 2.2 5.3 11.5 2.2 12.5 ns VCC = 2.7 V 2.1 4.9 9.3 2.1 10.2 ns VCC = 3 V to 3.6 V 1.8 4.0 7.6 1.8 9.0 ns 1.5 3.0 5.7 1.5 6.1 ns VCC = 1.65 V to 1.95 V 3.0 6.0 11.4 3.0 11.7 ns VCC = 2.3 V to 2.7 V 2.1 4.4 7.3 2.1 7.6 ns VCC = 2.7 V 2.1 4.2 6.3 2.1 6.6 ns VCC = 3 V to 3.6 V 1.7 3.6 5.3 1.7 5.9 ns 1.3 2.9 3.8 1.3 4.3 ns VCC = 1.65 V to 1.95 V 0.5 - - 0.5 - ns VCC = 2.3 V to 2.7 V 0.5 - - 0.5 - ns VCC = 2.7 V 0.5 - - 0.5 - ns VCC = 3 V to 3.6 V 0.5 - - 0.5 - ns VCC = 4.5 V to 5.5 V 0.5 - - 0.5 - ns S to Yn; see Figure 17 [4] S to Yn; see Figure 17 [5] VCC = 4.5 V to 5.5 V tb-m Max VCC = 1.65 V to 1.95 V VCC = 4.5 V to 5.5 V tdis [1] [2] [3] VCC = 4.5 V to 5.5 V ten Typ -40 °C to +125 °C Unit [6] see Figure 18 Typical values are measured at Tamb = 25 °C and nominal VCC. tpd is the same as tPLH and tPHL. Propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified capacitance when driven by an ideal voltage source (zero output impedance). ten is the same as tPZH and tPZL. tdis is the same as tPLZ and tPHZ. Break-before-make specified by design. 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 11.1 Waveforms and test circuits VI Yn or Z input VM VM GND tPLH tPHL VOH Z or Yn output VM VM VOL 001aac361 Measurement points are given in Table 10. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Figure 16. Input (Yn or Z) to output (Z or Yn) propagation delays VI S input VM GND tPLZ Yn output LOW to OFF OFF to LOW tPZL VCC VM VX VOL tPZH tPHZ Yn output HIGH to OFF OFF to HIGH VOH VY VM GND switch enabled switch disabled switch enabled 001aac362 Measurement points are given in Table 10. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Figure 17. Enable and disable times Table 10. Measurement points Supply voltage Input Output VCC VM VM VX VY 1.65 V to 5.5 V 0.5 × VCC 0.5 × VCC VOL + 0.3 V VOH - 0.3 V 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer VCC VI G VO RL 0.5VCC S Y0 Z Y1 CL GND 001aac367 a. Test circuit VI 0.5VI 0.9VO 0.9VO VO tb-m 001aag572 b. Input and output measurement points Figure 18. Test circuit for measuring break-before-make timing VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 11. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. VEXT = External voltage for measuring switching times. Figure 19. Test circuit for measuring switching times 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer Table 11. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 1.65 V to 1.95 V VCC ≤ 2.0 ns 50 pF 500 Ω open GND 2 × VCC 2.3 V to 2.7 V VCC ≤ 2.0 ns 50 pF 500 Ω open GND 2 × VCC 2.7 V VCC ≤ 2.5 ns 50 pF 500 Ω open GND 2 × VCC 3 V to 3.6 V VCC ≤ 2.5 ns 50 pF 500 Ω open GND 2 × VCC 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open GND 2 × VCC Load VEXT 11.2 Additional dynamic characteristics Table 12. Additional dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); Tamb = 25 °C. Symbol Parameter Conditions THD fi = 600 Hz to 20 kHz; RL = 600 Ω; CL = 50 pF; VI = 0.5 V (p-p); see Figure 20 f(−3dB) αiso Qinj total harmonic distortion −3 dB frequency response isolation (OFF-state) charge injection 74LVC1G3157 Product data sheet Min Typ Max Unit VCC = 1.65 V - 0.260 - % VCC = 2.3 V - 0.078 - % VCC = 3.0 V - 0.078 - % VCC = 4.5 V - 0.078 - % VCC = 1.65 V - 200 - MHz VCC = 2.3 V - 300 - MHz VCC = 3.0 V - 300 - MHz VCC = 4.5 V - 300 - MHz VCC = 1.65 V - -42 - dB VCC = 2.3 V - -42 - dB VCC = 3.0 V - -40 - dB VCC = 4.5 V - -40 - dB VCC = 1.8 V - 3.3 - pC VCC = 2.5 V - 4.1 - pC VCC = 3.3 V - 5.0 - pC VCC = 4.5 V - 6.4 - pC VCC = 5.5 V - 7.5 - pC RL = 50 Ω; see Figure 21 RL = 50 Ω; CL = 5 pF; fi = 10 MHz; see Figure 22 CL = 0.1 nF; Vgen = 0 V; Rgen = 0 Ω; fi = 1 MHz; RL = 1 MΩ; see Figure 23 All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 11.3 Test circuits VCC VIL or VIH fi 0.1 µF 0.5VCC S Y0 1 Z Y1 2 RL switch 10 µF S 1 VIL 2 VIH D CL 600 Ω switch GND 001aac363 Figure 20. Test circuit for measuring total harmonic distortion VCC VIL or VIH DC bias = 350 mV fi 0.1 µF S Y0 1 Z Y1 2 switch S 1 VIL 2 VIH switch RL 50 Ω dB GND aaa-022366 Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads -3 dB. Figure 21. Test circuit for measuring the frequency response when switch is in ON-state 0.5VCC VCC 0.5VCC RL VIL or VIH fi 0.1 µF RL S Y0 1 Z Y1 2 switch CL 50 Ω switch S 1 VIH 2 VIL dB GND 001aac365 Adjust fi voltage to obtain 0 dBm level at input. Figure 22. Test circuit for measuring isolation (OFF-state) 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer VCC G S Y0 1 Z Y1 2 Rgen VI switch RL CL VO Vgen GND aaa-022367 a. Test circuit logic (S) off input on VO off ΔVO 001aac478 b. Input and output pulse definitions Qinj = ΔVO × CL. ΔVO = output voltage variation. Rgen = generator resistance. Vgen = generator voltage. Figure 23. Test circuit for measuring charge injection 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 12 Package outline Plastic surface-mounted package; 6 leads SOT363 D B E y A X HE 6 5 v M A 4 Q pin 1 index A 1 2 e1 A1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA SC-88 EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 Figure 24. Package outline SOT363 (SC-88) 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer Plastic surface-mounted package (TSOP6); 6 leads D SOT457 B E y A HE 6 5 X v M A 4 Q pin 1 index A A1 1 2 c 3 Lp e bp w M B detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.1 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT457 JEITA SC-74 EUROPEAN PROJECTION ISSUE DATE 05-11-07 06-03-16 Figure 25. Package outline SOT457 (SC-74) 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 17 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit max nom min mm A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Figure 26. Package outline SOT886 (XSON6) 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 18 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 4 e1 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Figure 27. Package outline SOT891 (XSON6) 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 19 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 mm 1 mm scale L L1 0.35 0.40 0.30 0.35 0.27 0.32 0.3 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Figure 28. Package outline SOT1115 (XSON6) 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 20 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 mm Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Figure 29. Package outline SOT1202 (XSON6) 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 21 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer X2SON6: plastic thermal enhanced extremely thin small outline package; no leads; 6 terminals; body 1.0 x 0.8 x 0.35 mm SOT1255 X A D B A pin 1 ID area E A1 detail X C e1 b (4x) 4 3 y1 C A B v y L (4x) 2 5 Dh (2x) 1 6 e2 0 1 mm scale Dimensions (mm are the original dimensions) Unit A A1 D Dh E e1 e2 b L v y y1 max 0.35 0.04 1.05 0.30 0.85 0.30 0.25 nom 0.32 0.02 1.00 0.25 0.80 0.60 0.40 0.25 0.20 0.10 0.05 0.05 0.22 0.17 min 0.30 0.00 0.95 0.22 0.75 mm sot1255_po Outline version References IEC JEDEC JEITA European projection Issue date 15-07-20 15-07-22 SOT1255 Figure 30. Package outline SOT1255 (X2SON6) 74LVC1G3157 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 22 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 13 Abbreviations Table 13. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14 Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G3157 v.7 20170214 Product data sheet - 74LVC1G3157 v.6 Modifications: • Table 7: The maximum limits for leakage current and supply current have changed. • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74LVC1G3157 v.6 20160512 Modifications: • • • • 74LVC1G3157 v.5 20121206 Modifications: • Package outline drawing of SOT886 (Figure 26) modified. 74LVC1G3157 v.4 20111206 Product data sheet - 74LVC1G3157 v.3 74LVC1G3157 v.3 20100916 Product data sheet - 74LVC1G3157 v.2 74LVC1G3157 v.2 20070918 Product data sheet - 74LVC1G3157 v.1 74LVC1G3157 v.1 20050207 Product data sheet - - 74LVC1G3157 Product data sheet Product data sheet - 74LVC1G3157 v.5 Added type number 74LVC1G3157GX (SOT1255 package) Table 9: Minimum and maximum values enable and disable times revised. Table 12 and Figure 21: Condition and test circuit for f(-3dB) revised. Figure 23: Test circuit for charge injection revised. Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 74LVC1G3157 v.4 © Nexperia B.V. 2017. All rights reserved. 23 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVC1G3157 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 24 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVC1G3157 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 14 February 2017 © Nexperia B.V. 2017. All rights reserved. 25 / 26 74LVC1G3157 Nexperia 2-channel analog multiplexer/demultiplexer Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 10.1 10.2 10.3 11 11.1 11.2 11.3 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Marking .................................................................2 Functional diagram ............................................. 3 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 4 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Test circuits ....................................................... 6 ON resistance ....................................................7 ON resistance test circuit and graphs ................8 Dynamic characteristics ...................................10 Waveforms and test circuits ............................ 11 Additional dynamic characteristics ...................13 Test circuits ..................................................... 14 Package outline .................................................16 Abbreviations .................................................... 23 Revision history ................................................ 23 Legal information .............................................. 24 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 14 February 2017 Document identifier: 74LVC1G3157
74LVC1G3157GN,132 价格&库存
很抱歉,暂时无法提供与“74LVC1G3157GN,132”相匹配的价格&库存,您可以联系我们找货
74LVC1G3157GN,132
  • 1+3.941601+0.50200
  • 10+2.9271010+0.37280
  • 100+1.63260100+0.20790
  • 1000+1.224501000+0.15600
  • 5000+1.049505000+0.13370
  • 10000+0.9819010000+0.12510
  • 25000+0.8979025000+0.11440
  • 50000+0.8653050000+0.11020
  • 100000+0.84780100000+0.10800
