74HC4053-Q100;
74HCT4053-Q100
Triple 2-channel analog multiplexer/demultiplexer
Rev. 3 — 5 March 2020
Product data sheet
1. General description
The 74HC4053-Q100; 74HCT4053-Q100 is a triple single-pole double-throw analog switch
(3x SPDT) suitable for use in analog or digital 2:1 multiplexer/demultiplexer applications. Each
switch features a digital select input (Sn), two independent inputs/outputs (nY0 and nY1) and a
common input/output (nZ). A digital enable input (E) is common to all switches. When E is HIGH,
the switches are turned off. Inputs include clamp diodes. This enables the use of current limiting
resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide analog input voltage range from -5 V to +5 V
Low ON resistance:
• 80 Ω (typical) at VCC - VEE = 4.5 V
• 70 Ω (typical) at VCC - VEE = 6.0 V
• 60 Ω (typical) at VCC - VEE = 9.0 V
Logic level translation: to enable 5 V logic to communicate with ±5 V analog signals
Typical ‘break before make’ built-in
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
• CDM AEC-Q100-011 revision B exceeds 1000 V
Multiple package options
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
Nexperia
4. Ordering information
Table 1. Ordering information
Type number
Package
74HC4053D-Q100
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads; SOT403-1
body width 4.4 mm
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
16 terminals; body 2.5 × 3.5 × 0.85 mm
74HCT4053D-Q100
74HC4053PW-Q100
74HCT4053PW-Q100
74HC4053BQ-Q100
74HCT4053BQ-Q100
SOT763-1
5. Functional diagram
E
6
VCC
16
13 1Y1
S1 11
LOGIC
LEVEL
CONVERSION
12 1Y0
DECODER
14 1Z
1 2Y1
S2 10
LOGIC
LEVEL
CONVERSION
2 2Y0
15 2Z
3 3Y1
S3 9
LOGIC
LEVEL
CONVERSION
5 3Y0
4 3Z
8
GND
Fig. 1.
7
VEE
001aak341
Functional diagram
74HC_HCT4053_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 25
Nexperia
6
11
S1
1Y0
12
10
S2
1Y1
13
9
6
S3
E
11
1Z
14
2Y0
2
2Y1
1
10
2Z
15
15
3Y0
5
3Y1
3
3Z
4
EN
14
9
MUX/DMUX
0/1
Logic symbol
13
1
2
1
5
4
3
001aae126
001aae125
Fig. 2.
12
Fig. 3.
IEC logic symbol
Y
VCC
VEE
VCC
VCC
VCC
VEE
from
logic
VEE
Z
001aad544
Fig. 4.
Schematic diagram (one switch)
74HC_HCT4053_Q100
Product data sheet
3 / 25
Nexperia
6. Pinning information
6.1. Pinning
1
terminal 1
index area
2Y0
2
15 2Z
3Y1
3
14 1Z
3Z
4
13 1Y1
3Y0
5
12 1Y0
E
6
11 S1
VEE
7
10 S2
GND
8
9
14 1Z
3Z
4
13 1Y1
3Y0
5
E
6
VEE
7
12 1Y0
VCC(1)
11 S1
10 S2
aaa-003165
Transparent top view
(1) This is not a supply pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to VCC.
S3
aaa-003164
Fig. 5.
3Y1
9
16 VCC
15 2Z
3
S3
1
2
8
2Y1
2Y0
GND
74HC4053-Q100
74HCT4053-Q100
16 VCC
2Y1
74HC4053-Q100
74HCT4053-Q100
Pin configuration SOT109-1 (SO16) and
SOT403-1 (TSSOP16)
Fig. 6.
Pin configuration SOT763-1 (DHVQFN16)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
E
6
enable input (active LOW)
VEE
7
supply voltage
GND
8
ground supply voltage
S1, S2, S3
11, 10, 9
select input
1Y0, 2Y0, 3Y0
12, 2, 5
independent input or output
1Y1, 2Y1, 3Y1
13, 1, 3
1Z, 2Z, 3Z
14, 15, 4
common output or input
VCC
16
supply voltage
7. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
Inputs
Channel on
E
Sn
L
L
nY0 to nZ
L
H
nY1 to nZ
H
X
switches off
74HC_HCT4053_Q100
Product data sheet
4 / 25
Nexperia
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground).
Symbol Parameter
Conditions
Max
Unit
-0.5
+11.0
V
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
ISK
switch clamping current
VSW < -0.5 V or VSW > VCC + 0.5 V
±20
mA
ISW
switch current
-0.5 V < VSW < VCC + 0.5 V
±25
mA
IEE
supply current
±20
mA
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
P
power dissipation
100
mW
[1]
[2]
[1]
Min
[2]
per switch
To avoid drawing VCC current out of terminal nZ, when switch current flows into terminals nYn, the voltage drop across the bidirectional
switch must not exceed 0.4 V. If the switch current flows into terminal nZ, no VCC current will flow out of terminals nYn, and in this case
there is no limit for the voltage drop across the switch, but the voltages at nYn and nZ may not exceed VCC or VEE.
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
74HC4053-Q100
74HCT4053-Q100
Unit
Min
Typ
Max
Min
Typ
Max
VCC - GND
2.0
5.0
10.0
4.5
5.0
5.5
V
VCC - VEE
2.0
5.0
10.0
2.0
5.0
10.0
V
see Fig. 7 and Fig. 8
VI
input voltage
GND
VCC
GND
VCC
V
VSW
switch voltage
VEE
VCC
VEE
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall VCC = 2.0 V
rate
VCC = 4.5 V
625
ns/V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
VCC = 10.0 V
31
ns/V
74HC_HCT4053_Q100
Product data sheet
5 / 25
Nexperia
001aad545
10
001aad546
10
VCC - GND
(V)
VCC - GND
(V)
8
8
6
6
operating area
operating area
4
4
2
2
Fig. 7.
4
6
10
VCC - VEE (V)
Guaranteed operating area as a function of the
supply voltages for 74HC4053-Q100
Fig. 8.
4
6
8
10
VCC - VEE (V)
supply voltages for 74HCT4053-Q100
10. Static characteristics
Table 6. RON resistance per switch for 74HC4053-Q100 and 74HCT4053-Q100
VI = VIH or VIL; for test circuit see Fig. 9.
Vis is the input voltage at a nYn or nZ terminal, whichever is assigned as an input.
Vos is the output voltage at a nYn or nZ terminal, whichever is assigned as an output.
For 74HC4053-Q100: VCC - GND or VCC - VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V.
For 74HCT4053-Q100: VCC - GND = 4.5 V and 5.5 V, VCC - VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Tamb = 25 °C
RON(peak) ON resistance (peak)
Vis = VCC to VEE
VCC = 2.0 V; VEE = 0 V; ISW = 100 μA
RON(rail)
ON resistance (rail)
Ω
VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA
[1]
100
180
Ω
VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA
90
160
Ω
VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA
70
130
Ω
Vis = VEE
150
Ω
[1]
80
140
Ω
70
120
Ω
60
105
Ω
Vis = VCC
ΔRON
150
Ω
90
160
Ω
80
140
Ω
65
120
Ω
ON resistance mismatch Vis = VCC to VEE
between channels
74HC_HCT4053_Q100
Product data sheet
[1]
Ω
9
Ω
8
Ω
6
Ω
[1]
6 / 25
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Tamb = -40 °C to +85 °C
Vis = VCC to VEE
RON(rail)
Ω
[1]
225
Ω
200
Ω
165
Ω
Vis = VEE
Ω
[1]
175
Ω
150
Ω
130
Ω
Vis = VCC
Ω
[1]
200
Ω
175
Ω
150
Ω
Ω
270
Ω
240
Ω
195
Ω
Ω
210
Ω
180
Ω
160
Ω
Ω
240
Ω
210
Ω
180
Ω
Tamb = -40 °C to +125 °C
Vis = VCC to VEE
RON(rail)
[1]
Vis = VEE
[1]
Vis = VCC
[1]
[1]
When supply voltages (VCC - VEE) near 2.0 V the analog switch ON resistance becomes extremely non-linear. When using a supply of
2 V, it is recommended to use these devices only for transmitting digital signals.
74HC_HCT4053_Q100
Product data sheet
7 / 25
Nexperia
mnb047
110
(1)
RON
(Ω)
90
70
(2)
Vsw
from select
input
VCC
Sn
30
nYn
Vis
nZ
GND
VEE
10
Isw
3.6
5.4
7.2
Vis (V)
9.0
Vis = 0 V to (VCC - VEE).
(1) VCC = 4.5 V
(2) VCC = 6 V
(3) VCC = 9 V
001aah826
Fig. 9.
(3)
50
V
Test circuit for measuring RON
Fig. 10. Typical RON as a function of input voltage Vis
Table 7. Static characteristics for 74HC4053-Q100
Voltages are referenced to GND (ground = 0 V).
Vis is the input voltage at pins nYn or nZ, whichever is assigned as an input.
Vos is the output voltage at pins nZ or nYn, whichever is assigned as an output.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 9.0 V
6.3
4.7
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
VCC = 9.0 V
4.3
2.7
V
VCC = 6.0 V
±0.1
μA
VCC = 10.0 V
±0.2
μA
per channel
±0.1
μA
all channels
±0.1
μA
±0.1
μA
VCC = 6.0 V
8.0
μA
VCC = 10.0 V
16.0
μA
3.5
pF
Tamb = 25 °C
VIH
VIL
II
IS(OFF)
HIGH-level input
voltage
LOW-level input
voltage
input leakage
current
OFF-state leakage
current
VEE = 0 V; VI = VCC or GND
VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL;
|VSW| = VCC - VEE; see Fig. 11
IS(ON)
ON-state leakage
current
|VSW| = VCC - VEE; see Fig. 12
ICC
supply current
VEE = 0 V; VI = VCC or GND; Vis = VEE or VCC;
Vos = VCC or VEE
CI
input capacitance
74HC_HCT4053_Q100
Product data sheet
8 / 25
Nexperia
Symbol Parameter
Conditions
Csw
switch capacitance
Min
Typ
Max
Unit
independent pins nYn
5
pF
common pins nZ
8
pF
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 9.0 V
6.3
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
VCC = 9.0 V
2.7
V
VCC = 6.0 V
±1.0
μA
VCC = 10.0 V
±2.0
μA
per channel
±1.0
μA
all channels
±1.0
μA
±1.0
μA
VCC = 6.0 V
80.0
μA
VCC = 10.0 V
160.0
μA
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 9.0 V
6.3
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
VCC = 9.0 V
2.7
V
VCC = 6.0 V
±1.0
μA
VCC = 10.0 V
±2.0
μA
per channel
±1.0
μA
all channels
±1.0
μA
±1.0
μA
VIH
VIL
II
IS(OFF)
HIGH-level input
voltage
LOW-level input
voltage
input leakage
current
OFF-state leakage
current
|VSW| = VCC - VEE; Fig. 11
IS(ON)
ON-state leakage
current
ICC
supply current
Vos = VCC or VEE
VIH
VIL
II
IS(OFF)
IS(ON)
HIGH-level input
voltage
LOW-level input
voltage
input leakage
current
OFF-state leakage
current
ON-state leakage
current
74HC_HCT4053_Q100
Product data sheet
9 / 25
Nexperia
Symbol Parameter
Conditions
ICC
Vos = VCC or VEE
supply current
Min
Typ
Max
Unit
VCC = 6.0 V
160.0
μA
VCC = 10.0 V
320.0
μA
Conditions
Min
Typ
Max
Unit
Table 8. Static characteristics for 74HCT4053-Q100
Symbol Parameter
Tamb = 25 °C
VIH
HIGH-level input
voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
V
VIL
LOW-level input
voltage
1.2
0.8
V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V; VEE = 0 V
±0.1
μA
IS(OFF)
OFF-state leakage
current
per channel
±0.1
μA
all channels
±0.1
μA
±0.1
μA
8.0
μA
VCC = 5.0 V; VEE = -5.0 V
16.0
μA
50
180
μA
3.5
pF
5
pF
common pins nZ
8
pF
IS(ON)
ON-state leakage
current
ICC
supply current
VI = VCC or GND; Vis = VEE or VCC;Vos = VCC or VEE
ΔICC
additional supply
current
CI
input capacitance
Csw
switch capacitance
per input; VI = VCC - 2.1 V;
other inputs at VCC or GND; VCC = 4.5 V to 5.5 V;
VEE = 0 V
VIH
HIGH-level input
voltage
2.0
V
VIL
LOW-level input
voltage
0.8
V
II
input leakage
current
±1.0
μA
IS(OFF)
OFF-state leakage
current
per channel
±1.0
μA
all channels
±1.0
μA
±1.0
μA
80.0
μA
160.0
μA
IS(ON)
ON-state leakage
current
ICC
supply current
74HC_HCT4053_Q100
Product data sheet
10 / 25
Nexperia
Symbol Parameter
Conditions
ΔICC
VEE = 0 V
additional supply
current
Min
Typ
Max
Unit
225
μA
VIH
HIGH-level input
voltage
2.0
V
VIL
LOW-level input
voltage
0.8
V
II
input leakage
current
±1.0
μA
IS(OFF)
OFF-state leakage
current
per channel
±1.0
μA
all channels
±1.0
μA
±1.0
μA
160.0
μA
320.0
μA
245
μA
IS(ON)
ON-state leakage
current
ICC
supply current
ΔICC
additional supply
current
from select
input
VEE = 0 V
VCC
Sn
Isw
A
nYn
Vis
Isw
nZ
GND
HIGH
from select
input
Isw
A
A
VEE
Fig. 11. Test circuit for measuring OFF-state current
nZ
GND
Vos
VEE
001aah828
001aah827
Vis = VCC and Vos = VEE.
Vis = VEE and Vos = VCC.
nYn
Vis
Vos
VCC
Sn
Vis = VCC and Vos = open-circuit.
Vis = VEE and Vos = open-circuit.
Fig. 12. Test circuit for measuring ON-state current
11. Dynamic characteristics
Table 9. Dynamic characteristics for 74HC4053-Q100
GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Fig. 15.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
15
60
ns
5
12
ns
4
10
ns
4
8
ns
Tamb = 25 °C
tpd
propagation delay
74HC_HCT4053_Q100
Product data sheet
Vis to Vos; RL = ∞ Ω; see Fig. 13
[1]
11 / 25
Nexperia
Symbol Parameter
Conditions
ton
E to Vos; RL = ∞ Ω; see Fig. 14
turn-on time
Min
Typ
Max
Unit
60
220
ns
ns
VCC = 5.0 V; VEE = 0 V; CL = 15 pF
17
ns
16
37
ns
15
31
ns
75
220
ns
25
44
ns
21
ns
ns
15
31
ns
63
210
ns
21
42
ns
18
ns
17
36
ns
15
29
ns
60
210
ns
ns
17
ns
16
36
ns
15
29
ns
36
pF
75
ns
15
ns
13
ns
10
ns
275
ns
55
ns
47
ns
39
ns
275
ns
55
ns
47
ns
39
ns
Sn to Vos; RL = ∞ Ω; see Fig. 14
toff
turn-off time
E to Vos; RL = 1 kΩ; see Fig. 14
[2]
[2]
[3]
Sn to Vos; RL = 1 kΩ; see Fig. 14
CPD
power dissipation
capacitance
[3]
per switch; VI = GND to VCC
[4]
[1]
tpd
ton
propagation delay
turn-on time
74HC_HCT4053_Q100
Product data sheet
[2]
[2]
12 / 25
Nexperia
Symbol Parameter
Conditions
toff
turn-off time
Min
Typ
Max
Unit
265
ns
53
ns
45
ns
36
ns
265
ns
53
ns
45
ns
36
ns
90
ns
18
ns
15
ns
12
ns
330
ns
66
ns
56
ns
47
ns
330
ns
66
ns
56
ns
47
ns
315
ns
63
ns
54
ns
44
ns
315
ns
63
ns
54
ns
44
ns
[3]
[3]
tpd
ton
propagation delay
turn-on time
toff
turn-off time
[1]
[2]
[3]
[4]
[1]
[2]
[2]
[3]
[3]
tpd is the same as tPHL and tPLH.
ton is the same as tPZH and tPZL.
toff is the same as tPHZ and tPLZ.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ{(CL + Csw) × VCC × fo} where:
fi = input frequency in MHz; fo = output frequency in MHz;
2
N = number of inputs switching; Σ{(CL + Csw) × VCC × fo} = sum of outputs;
CL = output load capacitance in pF; Csw = switch capacitance in pF;
VCC = supply voltage in V.
74HC_HCT4053_Q100
Product data sheet
13 / 25
Nexperia
Table 10. Dynamic characteristics for 74HCT4053-Q100
Symbol Parameter
Conditions
Min
Typ
Max
Unit
5
12
ns
4
8
ns
27
48
ns
23
ns
16
34
ns
25
48
ns
21
ns
16
34
ns
24
44
ns
ns
15
31
ns
22
44
ns
19
ns
15
31
ns
36
pF
15
ns
10
ns
60
ns
43
ns
60
ns
43
ns
55
ns
39
ns
55
ns
39
ns
Tamb = 25 °C
tpd
ton
propagation delay
turn-on time
[1]
[2]
toff
turn-off time
CPD
power dissipation
capacitance
[2]
[3]
[3]
per switch; VI = GND to VCC - 1.5 V
[4]
[1]
tpd
ton
propagation delay
turn-on time
[2]
[2]
toff
turn-off time
74HC_HCT4053_Q100
Product data sheet
[3]
[3]
14 / 25
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
18
ns
12
ns
72
ns
51
ns
72
ns
51
ns
66
ns
47
ns
66
ns
47
ns
tpd
ton
propagation delay
turn-on time
[1]
[2]
toff
turn-off time
[2]
[3]
[1]
[2]
[3]
[4]
[3]
2
2
2
Vis input
50 %
tPLH
tPHL
50 %
Vos output
001aad555
Fig. 13. Input (Vis) to output (Vos) propagation delays
74HC_HCT4053_Q100
Product data sheet
15 / 25
Nexperia
VI
VM
E, Sn inputs
0V
tPLZ
tPZL
50 %
Vos output
10 %
tPHZ
tPZH
90 %
50 %
Vos output
switch ON
switch ON
switch OFF
001aad556
For 74HC4053-Q100: VM = 0.5 × VCC.
For 74HCT4053-Q100: VM = 1.3 V.
Fig. 14. Turn-on and turn-off times
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC Vis
PULSE
GENERATOR
VI
VCC
Vos
RL
DUT
RT
S1
open
CL
GND
VEE
001aae382
Definitions for test circuit; see Table 11:
RT = termination resistance should be equal to the output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
RL = load resistance.
S1 = Test selection switch.
Fig. 15. Test circuit for measuring AC performance
74HC_HCT4053_Q100
Product data sheet
16 / 25
Nexperia
Table 11. Test data
Test
Input
Load
VI [1]
Vis
at fmax
other [2]
tPHL, tPLH
VCC
pulse
< 2 ns
tPZH, tPHZ
VCC
VCC
tPZL, tPLZ
VCC
VEE
[1]
[2]
tr, tf
S1 position
CL
RL
6 ns
50 pF
1 kΩ
open
< 2 ns
6 ns
50 pF
1 kΩ
VEE
< 2 ns
6 ns
50 pF
1 kΩ
VCC
For 74HCT4053-Q100: VI = 3 V
tr = tf = 6 ns; when measuring fmax, there is no constraint to tr and tf with 50 % duty factor.
11.1. Additional dynamic characteristics
Table 12. Additional dynamic characteristics
Recommended conditions and typical values; GND = 0 V; Tamb = 25 °C; CL = 50 pF.
Vos is the output voltage at pins nYn or nZ, whichever is assigned as an output.
Symbol
Parameter
Conditions
dsin
sine-wave distortion
fi = 1 kHz; RL = 10 kΩ; see Fig. 16
Min
Typ
Max
Unit
Vis = 4.0 V (p-p); VCC = 2.25 V; VEE = -2.25 V
0.04
Vis = 8.0 V (p-p); VCC = 4.5 V; VEE = -4.5 V
0.02
0.12
0.06
fi = 10 kHz; RL = 10 kΩ; see Fig. 16
αiso
isolation (OFF-state)
Xtalk
Vct
crosstalk voltage
f(-3dB)
[1]
[2]
crosstalk
-3 dB frequency
response
RL = 600 Ω; fi = 1 MHz; see Fig. 17
[1]
-50
dB
[1]
-50
dB
[1]
-60
dB
[1]
-60
dB
110
mV
220
mV
between two switches/multiplexers; RL = 600 Ω;
fi = 1 MHz; see Fig. 18
peak-to-peak value;
between control and any switch;
RL = 600 Ω; fi = 1 MHz; E or
Sn square wave between VCC and GND;
tr = tf = 6 ns; see Fig. 19
RL = 50 Ω; see Fig. 20
[2]
160
MHz
[2]
170
MHz
Adjust input voltage Vis to 0 dBm level (0 dBm = 1 mW into 600 Ω).
Adjust input voltage Vis to 0 dBm level at Vos for 1 MHz (0 dBm = 1 mW into 50 Ω).
74HC_HCT4053_Q100
Product data sheet
17 / 25
Nexperia
VCC
Sn
10 µF
Vis
nYn/nZ
nZ/nYn
VEE
GND
RL
Vos
dB
CL
001aah829
Fig. 16. Test circuit for measuring sine-wave distortion
VCC
Sn
0.1 µF
Vis
nYn/nZ
nZ/nYn
VEE
GND
RL
Vos
dB
CL
001aah871
VCC = 4.5 V; GND = 0 V; VEE = -4.5 V; RL = 600 Ω; RS = 1 kΩ.
a.Test circuit
001aae332
α iso
(dB)
- 20
- 40
- 60
- 80
- 100
102
10
103
104
105
fi (kHz)
106
b.Isolation (OFF-state) as a function of frequency
Fig. 17. Test circuit for measuring isolation (OFF-state)
VCC
Sn
Vis
0.1 µF
RL
nYn/nZ
nZ/nYn
VEE
RL
CL
VCC
Sn
nYn/nZ
RL
GND
nZ/nYn
VEE
GND
RL
Vos
CL
dB
001aah873
Fig. 18. Test circuits for measuring crosstalk between any two switches/multiplexers
74HC_HCT4053_Q100
Product data sheet
18 / 25
Nexperia
2RL
Vct
nYn
G
2RL
VCC
Sn, E
nZ
VEE
2RL
GND
oscilloscope
2RL
001aah913
Fig. 19. Test circuit for measuring crosstalk between control input and any switch
VCC
Sn
Vis
10 µF
nYn/nZ
nZ/nYn
VEE
GND
RL
Vos
CL
dB
001aah829
VCC = 4.5 V; GND = 0 V; VEE = -4.5 V; RL = 50 Ω; RS = 1 kΩ.
a.Test circuit
001aad551
5
Vos
(dB)
3
1
-1
-3
-5
10
102
103
104
105
f (kHz)
106
b.Typical frequency response
Fig. 20. Test circuit for frequency response
74HC_HCT4053_Q100
Product data sheet
19 / 25
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 21. Package outline SOT109-1 (SO16)
74HC_HCT4053_Q100
Product data sheet
20 / 25
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 22. Package outline SOT403-1 (TSSOP16)
74HC_HCT4053_Q100
Product data sheet
21 / 25
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig. 23. Package outline SOT763-1 (DHVQFN16)
74HC_HCT4053_Q100
Product data sheet
22 / 25
Nexperia
13. Abbreviations
Table 13. Abbreviations
Acronym
Description
CDM
Charged Device Model
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
14. Revision history
Table 14. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT4053_Q100 v.3
20200305
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Section 1 updated.
Section 2 updated.
Table 4: Derating values for Ptot total power dissipation updated.
74HC_HCT4053_Q100 v.2
20121122
Modifications:
74HC_HCT4053_Q100 v.1
20120720
74HC_HCT4053_Q100
Product data sheet
Product data sheet
CDM added to features.
Product data sheet
23 / 25
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT4053_Q100
Product data sheet
24 / 25
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Functional diagram.......................................................2
6. Pinning information......................................................4
6.1. Pinning.........................................................................4
6.2. Pin description............................................................. 4
7. Functional description................................................. 4
8. Limiting values............................................................. 5
9. Recommended operating conditions..........................5
10. Static characteristics..................................................6
11. Dynamic characteristics...........................................11
11.1. Additional dynamic characteristics........................... 17
12. Package outline........................................................ 20
13. Abbreviations............................................................ 23
14. Revision history........................................................23
15. Legal information......................................................24
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 5 March 2020
74HC_HCT4053_Q100
Product data sheet
25 / 25
