74HC590
8-bit binary counter with output register; 3-state
Rev. 02 — 28 April 2009
Product data sheet
1. General description
The 74HC590 is a high-speed Si-gate CMOS device and is pin compatible with Low
power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard no. 7A.
The 74HC590 is an 8-bit binary counter with a storage register and 3-state outputs. The
storage register has parallel (Q0 to Q7) outputs. The binary counter features a master
reset counter (MRC) and count enable (CE) inputs. The counter and storage register have
separate positive edge triggered clock (CPC and CPR) inputs. If both clocks are
connected together, the counter state always is one count ahead of the register. Internal
circuitry prevents clocking from the clock enable. A ripple carry output (RCO) is provided
for cascading. Cascading is accomplished by connecting RCO of the first stage to CE of
the second stage. Cascading for larger count chains can be accomplished by connecting
RCO of each stage to the counter clock (CPC) input of the following stage. If both clocks
are connected together, the counter state always is one count ahead of the register.
2. Features
n
n
n
n
n
Counter and register have independent clock inputs
Counter has master reset
Complies with JEDEC standard no. 7A
Multiple package options
ESD protection:
u HBM JESD22-A114E exceeds 2000 V
u MM JESD22-A115-A exceeds 200 V
u CDM JESD22-C101C exceeds 2000 V
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number Package
Temperature range Name
Description
Version
74HC590N
−40 °C to +125 °C
DIP16
plastic dual in-line package; 16 leads (300 mil)
SOT38-4
74HC590D
−40 °C to +125 °C
SO16
plastic small outline package; 16 leads; body width 3.9 mm SOT109-1
74HC590PW
−40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads; body
width 4.4 mm
74HC590BQ
−40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal enhanced very thin
quad flat package; no leads; 16 terminals; body
2.5 × 3.5 × 0.85 mm
SOT403-1
SOT763-1
74HC590
NXP Semiconductors
4. Functional diagram
12 CE
11 CPC
8-BIT BINARY COUNTER
10 MRC
13 CPR
RCO 9
8-BIT STORAGE REGISTER
Q0 15
Q1 1
Q2 2
Q3 3
14 OE
3-STATE OUTPUTS
Q4 4
Q5 5
Q6 6
Q7 7
001aac542
Fig 1.
Functional diagram
OE
CPR
11
CPC
13
CE
CPR
RCO
Q0
Q1
Q2
12
Q3
CE
Q4
Q5
Q6
Q7
MRC
9
15
CPC
MRC
14
13
12
11
10
EN3
C2
G1
1+
CTR8
9
(CT=255)Z4
CT=0
1
1D
2D
Fig 2.
Logic symbol
3
2
4
3
5
4
6
5
7
6
OE
14
15
1
001aac544
3
7
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
001aac545
Fig 3.
IEC logic symbol
74HC590_2
Product data sheet
3
2
2D
10
RCO
© NXP B.V. 2009. All rights reserved.
2 of 21
74HC590
NXP Semiconductors
OE
CPR
14
13
12
CE
CPC
9
11
T
MRC
10
15
1R
RCO
Q0
C1
R
1S
T
1
1R
Q1
C1
R
1S
T
2
1R
Q2
C1
R
1S
T
3
1R
Q3
C1
R
1S
T
4
1R
Q4
C1
R
1S
T
5
1R
Q5
C1
R
1S
T
6
1R
Q6
C1
R
1S
T
7
1R
Q7
C1
R
1S
001aac543
Fig 4.
Logic diagram
74HC590_2
Product data sheet
3 of 21
74HC590
NXP Semiconductors
5. Pinning information
5.1 Pinning
1
terminal 1
index area
Q2
2
15 Q0
Q3
3
14 OE
Q4
4
Q5
Q1
1
Q2
2
16 VCC
15 Q0
Q3
3
14 OE
Q4
4
13 CPR
Q5
5
12 CE
Q6
6
11 CPC
Q7
7
10 MRC
GND
8
13 CPR
12 CE
5
Q6
6
11 CPC
Q7
7
10 MRC
GND
74HC590
9
8
RCO
9
001aaj535
Fig 5.
Pin configuration DIP16
RCO
001aac564
Fig 6.
Pin configuration SO16
and TSSOP16
14 OE
Q4
4
13 CPR
Q5
5
Q6
6
Q7
7
12 CE
GND(1)
11 CPC
10 MRC
9
16 VCC
15 Q0
3
RCO
1
2
Q3
8
Q1
Q2
GND
74HC590
16 VCC
Q1
74HC590
Transparent top view
001aac547
(1) The die substrate is attached to
the exposed die pad using
conductive die attach material. It
can not be used as a supply pin
or input.
Fig 7.
Pin configuration
DHVQFN16
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
Q0 to Q7
15, 1, 2, 3, 4, 5, 6, 7
parallel data output
GND
8
ground (0 V)
RCO
9
ripple carry output (active LOW)
MRC
10
master reset counter input (active LOW)
CPC
11
counter clock input (active HIGH)
CE
12
count enable input (active LOW)
CPR
13
register clock input (active HIGH)
OE
14
output enable input (active LOW)
VCC
16
supply voltage
74HC590_2
Product data sheet
4 of 21
74HC590
NXP Semiconductors
6. Functional description
Table 3.
Function table[1] [2]
Inputs
Description
OE
CPR
MRC
CE
CPC
H
X
X
X
X
Q outputs disable
L
X
X
X
X
Q outputs enable
X
X
X
X
counter data stored into register
X
X
X
X
register stage is not changed
X
X
L
X
X
counter clear
X
X
H
L
advance one count
X
X
H
L
no count
X
X
H
H
X
no count
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
↑ = LOW-to-HIGH transition;
↓ = HIGH-to-LOW transition.
[2]
RCO = Q0’ · Q1’ · Q2’ · Q3’ · Q4’ · Q5’ · Q6’ · Q7’ (Q0’ to Q7’ are internal outputs of the counter).
74HC590_2
Product data sheet
5 of 21
74HC590
NXP Semiconductors
CPC
CPR
MRC
CE
OE
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
RCO
count
inhibit
counter clear
high-impedance
OFF-state
001aac548
Fig 8.
Typical timing sequence
74HC590_2
Product data sheet
6 of 21
74HC590
NXP Semiconductors
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
IIK
input clamping current
VI < −0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to VCC + 0.5 V
RCO standard output
Min
Max
Unit
−0.5
+7.0
V
±20
mA
±20
mA
±25
mA
±35
mA
ICC
supply current
70
mA
IGND
ground current
−70
mA
Tstg
storage temperature
−65
+150
°C
DIP16 package
750
mW
SO16 package
500
mW
TSSOP16 package
500
mW
Qn bus driver output
total power dissipation
Ptot
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For DIP16 package: Ptot derates linearly with 12 mW/K above 70 °C.
For SO16 packages: Ptot derates linearly with 8 mW/K above 70 °C.
For TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 °C.
For DHVQFN16 packages: Ptot derates linearly with 8 mW/K above 60 °C.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
VI
Min
Typ
Max
Unit
supply voltage
2.0
5.0
6.0
V
input voltage
VCC
V
VO
output voltage
∆t/∆V
input transition rise and fall rate
Tamb
Conditions
VCC
V
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
−40
+125
°C
ambient temperature
74HC590_2
Product data sheet
7 of 21
74HC590
NXP Semiconductors
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
Min
VIH
VIL
VOH
HIGH-level
input voltage
LOW-level
input voltage
Typ
−40 °C to +85 °C −40 °C to +125 °C Unit
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
HIGH-level
VI = VIH or VIL
output voltage
all outputs
IO = −20 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −20 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −20 µA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = −4 mA; VCC = 4.5 V
4.18 4.31
4.13
4.1
V
IO = −5.2 mA; VCC = 6.0 V
5.68 5.80
5.63
5.6
V
IO = −6.0 mA; VCC = 4.5 V
4.18 4.31
4.13
4.1
V
IO = −7.8 mA; VCC = 6.0 V
5.68 5.80
5.63
5.6
V
RCO standard output
VOL
LOW-level
VI = VIH or VIL
output voltage
all outputs
IO = 20 µA; VCC = 2.0 V
0.1
0.1
V
IO = 20 µA; VCC = 4.5 V
0.1
0.1
V
IO = 20 µA; VCC = 6.0 V
0.1
0.1
V
IO = 4 mA; VCC = 4.5 V
0.17
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.18
0.26
0.33
0.4
V
IO = 6.0 mA; VCC = 4.5 V
0.17
0.26
0.33
0.4
V
IO = 7.8 mA; VCC = 6.0 V
0.18
0.26
0.33
0.4
V
RCO standard output
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
±0.1
±1.0
±1.0
µA
IOZ
OFF-state
output current
per pin; VI = VIH or VIL;
VO = VCC or GND;
other inputs at VCC or GND;
VCC = 6.0 V
±0.5
±5.0
±10
µA
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
4.0
40
80
µA
CI
input
capacitance
3.5
pF
74HC590_2
Product data sheet
8 of 21
74HC590
NXP Semiconductors
10. Dynamic characteristics
Table 7.
GND (ground = 0 V); for test circuit see Figure 15.
Symbol Parameter
25 °C
Conditions
Min Typ Max
tpd
propagation
delay
CPC to RCO; see Figure 9
Min
Max
Min
Max
[1]
VCC = 2.0 V
52
150
190
230
ns
VCC = 4.5 V
19
30
38
45
ns
VCC = 6.0 V
15
26
33
40
ns
VCC = 2.0 V
50
140
175
210
ns
VCC = 4.5 V
17
28
35
42
ns
VCC = 6.0 V
14
24
30
36
ns
53
130
165
200
ns
18
26
33
40
ns
14
22
28
34
ns
VCC = 2.0 V
28
105
130
160
ns
VCC = 4.5 V
13
21
26
32
ns
11
18
22
27
ns
VCC = 2.0 V
28
105
130
160
ns
VCC = 4.5 V
13
21
26
32
ns
VCC = 6.0 V
11
18
22
27
ns
VCC = 2.0 V
100
24
125
145
ns
VCC = 4.5 V
25
29
ns
VCC = 6.0 V
17
8
21
25
ns
VCC = 2.0 V
75
28
95
110
ns
VCC = 4.5 V
15
8
19
22
ns
VCC = 6.0 V
13
6
16
19
ns
VCC = 2.0 V
100
46
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
10
21
26
ns
VCC = 2.0 V
100
44
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
9
21
26
ns
CPR to Qn; see Figure 10
tPLH
LOW to HIGH MRC to RCO; see Figure 11
propagation
VCC = 2.0 V
delay
VCC = 4.5 V
VCC = 6.0 V
ten
enable time
OE to Qn; see Figure 12
[2]
VCC = 6.0 V
tdis
tW
disable time
pulse width
[3]
CPC and CPR; HIGH or
LOW; see Figure 9 and
Figure 10
MRC; LOW; see Figure 11
tsu
set-up time
CPC to CPR; see Figure 14
CE to CPC; see Figure 13
74HC590_2
Product data sheet
9 of 21
74HC590
NXP Semiconductors
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 °C
Conditions
Min Typ Max
th
hold time
recovery time
trec
maximum
frequency
fmax
power
dissipation
capacitance
[1]
Max
Min
Max
VCC = 2.0 V
ns
VCC = 4.5 V
ns
VCC = 6.0 V
ns
VCC = 2.0 V
75
28
95
110
ns
VCC = 4.5 V
15
7
19
22
ns
VCC = 6.0 V
13
6
16
19
ns
VCC = 2.0 V
6.6
16
5.2
4.4
MHz
VCC = 4.5 V
33
52
26
22
MHz
39
61
31
26
MHz
44
pF
MRC to CPC; see Figure 11
CPC or CPR; see Figure 9
and Figure 10
VCC = 6.0 V
CPD
Min
VI = GND to VCC
[4]
tpd is the same as tPHL, tPLH.
[2]
ten is the same as tPZH and tPZL.
[3]
tdis is the same as tPLZ and tPHZ.
[4]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + ∑(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
∑(CL × VCC2 × fo) = sum of outputs.
74HC590_2
Product data sheet
10 of 21
74HC590
NXP Semiconductors
11. Waveforms
1/fmax
VI
CPC input
VM
GND
tW
tPLH
tPHL
VOH
RCO output
VM
VOL
001aac550
Measurement points are given in Table 8.
VOL and VOH are the typical output voltage levels that occur with the output load.
Fig 9.
Table 8.
Waveforms showing the propagation delays from the counter clock input (CPC) to ripple carry (RCO)
output and the CPC pulse width
Measurement points
Type
Input
74HC590
Output
VI
VM
VM
VCC
0.5VCC
0.5VCC
1/fmax
VI
CPR input
VM
GND
tW
tPLH
tPHL
VOH
Qn output
VM
VOL
001aac549
Fig 10. Waveforms showing the propagation delays from the register clock input (CPR) to output (Qn) and the
register clock pulse width
74HC590_2
Product data sheet
11 of 21
74HC590
NXP Semiconductors
tW
VI
MRC input
VM
GND
tPLH
VOH
VM
RCO output
VOL
trec
VI
VM
CPC input
GND
001aac551
Fig 11. Waveforms showing the propagation delays from the master reset counter input (MRC) to output (RCO),
the MRC pulse width and recovery time
VI
OE input
VM
GND
output
VCC
tPLZ
tPZL
VM
LOW-to-OFF
OFF-to-LOW VOL
10 %
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
90 %
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aac554
Fig 12. Waveforms showing the 3-state enable and disable times
74HC590_2
Product data sheet
12 of 21
74HC590
NXP Semiconductors
VI
VM
CE input
GND
tsu
th
tsu
th
VOH
VM
CPC input
VOL
001aac553
Fig 13. Waveforms showing the set-up and hold times for the count enable input (CE) to the counter clock input
(CPC)
VI
VM
CPC input
GND
tsu
th
VOH
VM
CPR input
VOL
001aac552
Fig 14. Waveforms showing the set-up and hold times for the counter clock input (CPC) to the register clock
input (CPR)
74HC590_2
Product data sheet
13 of 21
74HC590
NXP Semiconductors
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
G
VI
VO
RL
S1
open
DUT
RT
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig 15. Test circuit for measuring switching times
Table 9.
Test data
Supply voltage
Input
Load
Switch position
VCC
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
2.0 V to 6.0 V
VCC
6 ns
50 pF
1 kΩ
open
GND
VCC
74HC590_2
Product data sheet
14 of 21
74HC590
NXP Semiconductors
12. Package outline
DIP16: plastic dual in-line package; 16 leads (300 mil)
SOT38-4
ME
seating plane
D
A2
A
A1
L
c
e
Z
w M
b1
(e 1)
b
b2
MH
9
16
pin 1 index
E
1
8
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
min.
A2
max.
b
b1
b2
c
D (1)
E (1)
e
e1
L
ME
MH
w
Z (1)
max.
mm
4.2
0.51
3.2
1.73
1.30
0.53
0.38
1.25
0.85
0.36
0.23
19.50
18.55
6.48
6.20
2.54
7.62
3.60
3.05
8.25
7.80
10.0
8.3
0.254
0.76
inches
0.17
0.02
0.13
0.068
0.051
0.021
0.015
0.049
0.033
0.014
0.009
0.77
0.73
0.26
0.24
0.1
0.3
0.14
0.12
0.32
0.31
0.39
0.33
0.01
0.03
Note
1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
95-01-14
03-02-13
SOT38-4
Fig 16. Package outline SOT38-4 (DIP16)
74HC590_2
Product data sheet
15 of 21
74HC590
NXP Semiconductors
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
detail X
w M
bp
2.5
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.16
0.15
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 17. Package outline SOT109-1 (SO16)
74HC590_2
Product data sheet
16 of 21
74HC590
NXP Semiconductors
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
E
D
A
X
c
y
HE
v M A
Z
9
16
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 18. Package outline SOT403-1 (TSSOP16)
74HC590_2
Product data sheet
17 of 21
74HC590
NXP Semiconductors
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
7
y
y1 C
v M C A B
w M C
b
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
mm
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
c
D (1)
Dh
E (1)
Eh
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 19. Package outline SOT763-1 (DHVQFN16)
74HC590_2
Product data sheet
18 of 21
74HC590
NXP Semiconductors
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC590_2
20090428
Product data sheet
74HC590_1
Modifications:
74HC590_1
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Quick reference data incorporated in to Section 9 and Section 10.
Added type number 74HC590N (DIP16 package)
20050330
Product data sheet
74HC590_2
Product data sheet
19 of 21
74HC590
NXP Semiconductors
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
74HC590_2
Product data sheet
20 of 21
74HC590
NXP Semiconductors
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 7
Recommended operating conditions. . . . . . . . 7
Static characteristics. . . . . . . . . . . . . . . . . . . . . 8
Dynamic characteristics . . . . . . . . . . . . . . . . . . 9
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 15
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 19
Legal information. . . . . . . . . . . . . . . . . . . . . . . 20
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 20
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Contact information. . . . . . . . . . . . . . . . . . . . . 20
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2009.
Date of release: 28 April 2009
Document identifier: 74HC590_2
很抱歉,暂时无法提供与“74HC590PW,118”相匹配的价格&库存,您可以联系我们找货
