74HC7541-Q100;
74HCT7541-Q100
Octal Schmitt trigger buffer/line driver; 3-state
Rev. 1 — 24 March 2014
Product data sheet
1. General description
The 74HC7541-Q100; 74HCT7541-Q100 is an 8-bit buffer/line driver with Schmitt-trigger
inputs and 3-state outputs. The device features two output enables (OE1 and OE2). A
HIGH on OEn causes the outputs to assume a high-impedance OFF-state. Inputs include
clamp diodes that enable the use of current limiting resistors to interface inputs to voltages
in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into
sharply defined jitter-free output signals.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Non-inverting outputs
Low-power dissipation
Input levels:
For 74HC7541-Q100: CMOS level
For 74HCT7541-Q100: TTL level
Complies with JEDEC standard no. 7A
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
3. Ordering information
Table 1.
Type number
74HC7541D-Q100
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
40 C to +125 C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74HCT7541D-Q100
74HC7541PW-Q100
74HCT7541PW-Q100
74HC74541-Q100; 74HCT7541-Q100
Nexperia
4. Functional diagram
2
3
4
5
A0
Y0
A1
Y1
A2
Y2
A3
Y3
18
17
16
15
1
19
6
7
8
9
1
19
Y4
A4
A5
Y5
A6
Y6
A7
Y7
Fig 1.
EN
14
13
12
11
OE1
OE2
2
18
3
17
4
16
5
15
6
14
7
13
8
12
9
11
aaa-000085
aaa-000084
Logic symbol
Fig 2.
IEC logic symbol
5. Pinning information
5.1 Pinning
+&4
+&74
+&4
+&74
2(
9&&
2(
2(
9&&
2(
很抱歉,暂时无法提供与“74HCT7541D-Q100J”相匹配的价格&库存,您可以联系我们找货
