HEF4060B-Q100
14-stage ripple-carry binary counter/divider and oscillator
Rev. 2 — 9 September 2014
Product data sheet
1. General description
The HEF4060B-Q100 is a 14-stage ripple-carry binary counter/divider and oscillator. It
has three oscillator terminals (RS, REXT and CEXT) and ten buffered outputs (Q3 to Q9
and Q11 to Q13). It also has an overriding asynchronous master reset input (MR).
The oscillator configuration allows the design of either RC or crystal oscillator circuits. An
external clock signal at input RS can replace the oscillator. The Schmitt trigger action of
the clock makes it highly tolerant to slower clock rise and fall times. The counter advances
on the negative-going transition of RS. A HIGH level on MR resets the counter (Q3 to
Q9 and Q11 to Q13 = LOW), independent of other input conditions.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS
(usually ground). Unused inputs must be connected to VDD, VSS, or another input.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 3) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 3)
Specified from 40 C to +85 C
Tolerant of slow clock rise and fall times
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Inputs and outputs are protected against electrostatic effects
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Complies with JEDEC standard JESD 13-B
3. Ordering information
Table 1.
All types operate from 40 C to +85 C.
Type number
HEF4060BT-Q100
Package
Name
Description
Version
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4060B-Q100
Nexperia
4. Functional diagram
10
9
REXT
11
12
CEXT
RS
14-STAGE BINARY COUNTER
CP
CD
MR
Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q11 Q12 Q13
7
5
4
6
14
13
15
1
2
3
001aae652
Fig 1.
Functional diagram
CEXT
REXT
FF1
FF4
FF10
FF12
FF14
CP
CP
CP
RS
CP
CP
Q
CD
Q
Q
CD
MR
Q
CD
Q3
Q
CD
Q9
CD
Q11
Q13
001aae654
Fig 2.
Logic diagram
5. Pinning information
5.1 Pinning
+()%4
4
9''
4
4
4
4
4
4
4
05
4
56
4
5(;7
966
&(;7
DDD
Fig 3.
Pin configuration
HEF4060B_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
HEF4060B-Q100
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
Q11 to Q13
1, 2, 3
counter output
Q3 to Q9
7, 5, 4, 6, 14, 13, 15
counter output
VSS
8
ground supply voltage
CEXT
9
external capacitor connection
REXT
10
oscillator pin
RS
11
clock input/oscillator pin
MR
12
master reset
VDD
16
supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Output
RS
MR
Q3 to Q9 and Q11 to Q13
L
no change
L
count
X
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; = LOW-to-HIGH clock transition; HIGH-to-LOW clock transition.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
II/O
Conditions
Min
0.5
VI < 0.5 V or VI > VDD + 0.5 V
0.5
VO < 0.5 V or VO > VDD + 0.5 V
Max
Unit
+18
V
10
mA
VDD + 0.5
V
10
mA
input/output current
10
mA
IDD
supply current
50
mA
Tstg
storage temperature
65
+150
C
Tamb
ambient temperature
40
+85
C
Ptot
total power dissipation
Tamb 40 C to +85 C
P
power dissipation
per output
[1]
[1]
500
mW
100
mW
For SO16 package: Ptot derates linearly with 8 mW/K above 70 C.
HEF4060B_Q100
Product data sheet
3 of 14
HEF4060B-Q100
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VDD
VI
Conditions
Min
Typ
Max
Unit
supply voltage
3
15
V
input voltage
VDD
V
40
+85
C
VDD = 5 V
3.75
s/V
VDD = 10 V
0.5
s/V
VDD = 15 V
0.08
s/V
Tamb
ambient temperature
in free air
t/V
input transition rise and fall
rate
input MR
9. Static characteristics
Table 6.
VSS = 0 V; VI = VSS or VDD unless otherwise specified.
Symbol Parameter
VIH
VIL
VOH
VOL
IOH
IOL
HIGH-level
input voltage
IO < 1 A
LOW-level
input voltage
IO < 1 A
HIGH-level
output voltage
IO < 1 A
LOW-level
output voltage
HIGH-level
output current
LOW-level
output current
II
input leakage current
IDD
supply current
CI
Conditions
input capacitance
HEF4060B_Q100
Product data sheet
IO < 1 A
VDD
5V
Tamb = 40 C
Tamb = 25 C
Tamb = 85 C
Min
Max
Min
Max
Min
Max
3.5
3.5
3.5
Unit
V
10 V
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
V
15 V
0.05
0.05
0.05
V
VO = 2.5 V
5V
1.7
1.4
1.1
mA
VO = 4.6 V
5V
0.52
0.44
0.36
mA
VO = 9.5 V
10 V
1.3
1.1
0.9
mA
VO = 13.5 V
15 V
3.6
3.0
2.4
mA
VO = 0.4 V
5V
0.52
0.44
0.36
mA
VO = 0.5 V
10 V
1.3
1.1
0.9
mA
VO = 1.5 V
15 V
3.6
3.0
2.4
mA
15 V
0.3
0.3
1.0
A
5V
A
IO = 0 A
10 V
40
40
300
A
15 V
80
80
600
A
7.5
pF
4 of 14
HEF4060B-Q100
Nexperia
10. Dynamic characteristics
Table 7.
Tamb = 25 C; VSS = 0 V; CL = 50 pF; tr = tf 20 ns; unless otherwise specified.
Symbol
Parameter
propagation delay
tpd
transition time
tt
pulse width
tW
recovery time
trec
Conditions
Typ
Max
Unit
183 ns + (0.55 ns/pF) CL
210
420
ns
5V
see Figure 4
10 V
69 ns + (0.23 ns/pF) CL
80
160
ns
15 V
42 ns + (0.16 ns/pF) CL
50
100
ns
Qn Qn + 1;
5V
25
50
ns
see Figure 4
10 V
10
ns
15 V
6
12
ns
MR Qn;
5V
73 ns + (0.55 ns/pF) CL
100
200
ns
HIGH to LOW
10 V
29 ns + (0.23 ns/pF) CL
40
80
ns
see Figure 4
15 V
22 ns + (0.16 ns/pF) CL
30
60
ns
see Figure 4
5V
[3]
10 ns + (1.00 ns/pF) CL
60
120
ns
10 V
9 ns + (0.42 ns/pF) CL
30
60
ns
15 V
6 ns + (0.28 ns/pF) CL
ns
120
60
ns
minimum width; 5 V
RS HIGH;
10 V
50
25
ns
see Figure 4
15 V
30
15
ns
minimum width; 5 V
50
25
ns
MR HIGH;
10 V
30
15
ns
see Figure 4
15 V
ns
input MR;
5V
160
80
ns
see Figure 4
10 V
80
40
ns
15 V
60
30
ns
see Figure 4
[1]
[2]
Extrapolation formula[1] Min
RS Q3;
maximum frequency input RS;
fmax
VDD
5V
4
8
MHz
10 V
10
MHz
15 V
15
30
MHz
The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF).
[2]
tpd is the same as tPHL and tPLH.
[3]
tt is the same as tTHL and tTLH.
HEF4060B_Q100
Product data sheet
5 of 14
HEF4060B-Q100
Nexperia
Table 8.
Power dissipation
Dynamic power dissipation PD and total power dissipation Ptot can be calculated from the formulas shown. Tamb = 25 C.
Symbol Parameter
Conditions
VDD
Typical formula for PD and Ptot (W)[1]
PD
per device
5V
PD = 700 fi + (fo CL) VDD2
dynamic power
dissipation
10 V PD = 3300 fi + (fo CL) VDD2
15 V PD = 8900 fi + (fo CL) VDD2
Ptot
[1]
total power
dissipation
when using
the on-chip
oscillator
5V
Ptot = 700 fosc + (fo CL) VDD2 + 2 Ct VDD2 fosc + 690 VDD
10 V Ptot = 3300 fosc + (fo CL) VDD2 + 2 Ct VDD2 fosc + 6900 VDD
15 V Ptot = 8900 fosc + (fo CL) VDD2 + 2 Ct VDD2 fosc + 22000 VDD
Where:
fi = input frequency in MHz; fo = output frequency in MHz;
CL = output load capacitance in pF;
VDD = supply voltage in V;
(fo CL) = sum of the outputs;
Ct = timing capacitance (pF);
fosc = oscillator frequency (MHz).
11. Waveforms
tr
tf
90 %
VM
MR input
10 %
tW
1/fmax
trec
VM
RS input
tPHL
tPLH
tW
tPHL
90 %
Qn output
VM
10 %
tt
tt
001aaj472
Measurement points are given in Table 9.
Fig 4.
Waveforms showing propagation delays for MR to Qn and CP to Q0, minimum MR, and CP pulse widths
Table 9.
Measurement points
Supply voltage
Input
Output
VDD
VM
VM
5 V to 15 V
0.5VDD
0.5VDD
HEF4060B_Q100
Product data sheet
6 of 14
HEF4060B-Q100
Nexperia
9''
9,
92
'87
57
DDJ
Test data is given in Table 10.
Definitions for test circuit:
DUT = Device Under Test;
CL = load capacitance including jig and probe capacitance;
RT = termination resistance should be equal to the output impedance Zo of the pulse generator.
Fig 5.
Test circuit for measuring switching times
Table 10.
Measurement point and test data
Supply voltage
Input
Load
VDD
VI
tr, tf
CL
5 V to 15 V
VSS or VDD
20 ns
50 pF
12. RC oscillator
+()%4
05IURPORJLF
56
5
5(;7
&(;7
5W
&W
DDD
1
Typical formula for oscillator frequency: f osc = -----------------------------2.3 R t C t
Fig 6.
External component connection for RC oscillator
12.1 Timing component limitations
The oscillator frequency is mainly determined by Rt Ct, provided Rt
很抱歉,暂时无法提供与“HEF4060BT-Q100J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+2.058332500+0.26569
- 5000+2.001165000+0.25831
- 7500+1.972547500+0.25462
- 12500+1.9408412500+0.25053
- 17500+1.9223017500+0.24813
- 25000+1.9044625000+0.24583
- 国内价格 香港价格
- 1+5.487961+0.70839
- 10+3.9014810+0.50361
- 25+3.4998925+0.45177
- 100+3.05390100+0.39420
- 250+2.84159250+0.36680
- 500+2.71384500+0.35031
- 1000+2.657051000+0.34298
