CT81-Q10Y5P1D102KSEW 数据手册
CERAMIC DISC CAPACITOR
HOW TO ORDER
CC1
1
F
2
1
7
3
SL
4
1
5
B
6
331
7
J
8
S
9
P
10
W
11
Capacitor Type Code
Type
2
CC1
Low voltage temperature compensated disk ceramic capacitor
CC81
High voltage temperature compensated disk ceramic capacitor
CT1
Low voltage high dielectric constant disk ceramic capacitor
CT81
High voltage high dielectric constant disk ceramic capacitor
CS1
Semiconductor dielectric insulator disk ceramic capacitor
CT7
Alternating current disk ceramic capacitor
Rated voltage
Letter symbol
D
E
rated voltage
16V
25V
3
F
G
J
K
L
N
M
P
Q
X
Y
50V 100V 160V 250V 500V 1KV 2KV 3KV 4KV 250VAC 400VAC
Diameter
symbol
4
5
6
7
8
9
10
12
diameter(mm)
4.0
5.0
6.0
7.0
8.0
9.0
10.0
12.0
4
EIA
Temperature coefficient:Please consider temperature characteristics and EIA code
5
Lead style
symbol
Style
1
23mm)b
Straight lead (length 23mm)
2
17mm)b
Straight lead (length 17mm)
3
Cutting lead (short lead)
4
(b )
5
(a
Tape small inside kink
6
(a
Tape large inside kink
7
(c )
Double inside kinks
8
(c )
Double outside kinks
9
(w )
Outside kink
Tape straight lead
1
6
Lead Spacing
Lead spacing(mm)
symbol
7
A
2.5 0.5
B
5.0 0.5
D
7.5 0.5
E
10.0 0.5
Standard capacitance
1R0
1PF
4R7
4.7PF
100
10PF
560
56PF
821
820PF
102
1000PF
8
pF
R
Note: The unit of standard capacitance if consisting of 3 digits,
the first and second digits stand for effective value of the Standard
capacitance;third digit indicates the number of zeros; R indicates
decimal.
EIA
Capacitance tolerance, Please consider EIA code
J
9
K
M
Z
S
Packing style
symbol
10
Packing style
T
Tape
S
bulk
Enclosure style
code
Enciosure style
E
Epoxy resin
P
Phenol resin
11.W-
Lead-Free
TEMPERATURE CHARACTERISTICS
:X10-6/
0 60
750
140
120
1000
EIA
JIS
GB
NP0
C0H
CH
N750
U 2J
UJ or U2J
P140 N1000(SL)
S 2L
SL or S2L
2
EIA
EIA CODE
The Second Letter
The First Letter
Y: 25
Z:
5:
10
7:
The Third Letter
85
P:
10
125
R:
15
U:
22
56
V:
22
82
DIMENSIONS
a
b
Tmax
Tmax
2.5max
Dmax
11max
17min
2.5max
2.5max
F 0.8
0.2
Tmax
Dmax
Dmax
c
F 0.8
0.2
F 0.8
0.2
d 10%
d 10%
d 10%
EIA JIS
NOTE: Lead style and distance are fit of JIS and EIA standard. Other we can produce with customers requirement.
3
CT81
CT81
High voltage High dielectric constant capacitor
FEATURE:
The capacitor have various category of T.C, widely used in all sorts of electronic instrument and high voltage
or coupling circuit.
EIA
Operating Temperature Range, please consider EIA code
Capacitance Range
T.C/
(UR)
(General Model)
operating
voltage
1KV
Capacitance(PF)
2B4(Y5P)
2E4(Y5U)
2F4(Y5V)
BN(Y5P)
(mm)
Dimension
1000
1500
2200
3300
100
470
8
4700
5600
560
820
10
1000
1800
12
6
100 560
470
680 1000
1500
2200
1200 1800
2700
3300
2200 3300
3900
4700
2200
2700
14
3900 4700
5600
6800
3300
4700
16
8200
100 330
330
1000
DMax
(Low DF Model)
8200
10000
18
10000
470
1500
2200
100
330
8
1000
3300
4700
390
680
10
5600
8200
1000
12
470 680
560
820 1200
1500
2200
1500 1800
2700
3300
2200 3300
3900
3900 4700
6800
820
2KV
100 470
3KV
470
1200
1800
14
4700
2200
3300
16
8200
3900
4700
18
10000
560
2200
3300
100
270
10
1000
4700
5600
330
680
12
1500
14
560 820
680
1000 1500
1500
2200
8200
820
1800 2200
3300
3900
10000
1800
2700 3300
2200
16
18
4700
Test Voltage:1.5U R 500V
I.R:Insulation resistance R i
4000M .
tangent of loss angel: Y5P: tg
0.020
Y5U Z5U: tg
0.030
BN: tg
0.005 R: tg
4
0.0035
CT81-Q10Y5P1D102KSEW 价格&库存
很抱歉,暂时无法提供与“CT81-Q10Y5P1D102KSEW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.93654
- 50+0.78318
- 150+0.70650
- 500+0.54572
- 国内价格
- 10+0.64770
- 100+0.59055
- 500+0.53340
- 1000+0.47625
- 2000+0.43815
- 4000+0.42672
