JSM-MAX485
Low-Power
Slew-Rate-Limited RS-485/RS-422 Transceivers
General Description
Features
Low Quiescent Current: 300µA
on
-7V to +12V Common-Mode Input Voltage Range
ic
Three-State Outputs
30ns Propagation Delays, 5ns Skew
du
ct
These transceivers draw between 120µA and 500µA of
supply current when unloaded or fully loaded with disabled
drivers. All parts operate from a single 5V supply. Drivers are
short-circuit current limited and are protected against
excessive power dissipation by thermal shutdown circuitry
that places the driver outputs into a high-impedance state.
The receiver input has a fail-safe feature that guarantees a
logic-high output if the input is open circuit.
The JSM-MAX485 is designed for half-duplex applications.
or
The JSM-MAX485 is low-power transceivers for RS-485 and RS422 communication. IC contains one driver and one receiver.
The driver slew rates of the JSM-MAX485 is not limited,
allowing them to transmit up to 2.5Mbps.
Full-Duplex and Half-Duplex Versions Available
em
Operate from a Single 5V Supply
Data rate: 2,5 Mbps
S
Allows up to 32 Transceivers on the Bus
Pinning
JS
MI
CR
O
Current-Limiting and Thermal Shutdown for Driver Overload Protection
JSM-MAX485_ REV 1.0_EN
www.jsmsemi.com
第1/5页
JSM-MAX485
Low-Power
ABSOLUTE MAXIMUM RATINGS
Supply Voltage (VCC) 12V
Control Input Voltage -0.5V to (VCC + 0.5V)
Continuous Power Dissipation (TA= +70°C)
Driver Input Voltage (DI) -0.5V to (VCC+ 0.5V)
8-Pin SO (derate 5.88mW/°C above +70°C)
471mW
Driver Output Voltage (A, B) -8V to +12.5V
Operating Temperature Ranges0°C to +70°C
Receiver Input Voltage (A, B) -8V to +12.5V
Storage Temperature Range -65°C to +160°C
Receiver Output Voltage (RO) -0.5V to (VCC+0.5V) Lead Temperature (soldering, 10sec) +300°C
or
DC ELECTRICAL CHARACTERISTICS
SYMBOL
Differential Driver Output
(no load)
VOD1
Differential
Driver
Output (with load)
VOD2
Change in Magnitude of
Driver Differential Output
Voltage for Complementary
Output States
ΔVOD
Driver
Common-Mode
Output Voltage
VOC
Driver Common-Mode Output
Output States
ΔVOD
Input High Voltage
VIH
DE, DI, RE
Input Low Voltage
VIL
DE, DI, RE
0.8
V
Input Current
IIN1
DE, DI, RE
±2
µA
Input
Current (A,
B)
IIN2
DE = 0V;
VCC = 0V or 5.25V,
Receiver
Differential
Threshold Voltage
VTH
-7V VCM 12V
Receiver Input Hysteresis
ΔVTH
VCM = 0V
Receiver Output High Voltage
VOH
IO = -4mA, VID = 200mV
Receiver Output Low Voltage
VOL
IO = 4mA, VID = -200mV
0.4
V
Three-State
(high
impedance) Output Current
at Receiver
IOZR
0.4V VO 2.4V
±1
µA
Receiver Input Resistance
RIN
-7V VCM 12V
MIN
du
R = 50Ω (RS-422)
TYP
MAX
UNITS
5
V
2
1.5
5
on
R = 27Ω (RS-485), Figure 4
ic
R = 27Ω or 50Ω, Figure 4
em
S
CR
O
JS
MI
CONDITIONS
ct
PARAMETER
0.2
V
3
V
0.2
V
2.0
V
VIN = 12V
1.0
VIN = -7V
-0.8
-0.2
0.2
70
mA
V
mV
3.5
12
V
V
kΩ
(VCC = 5V ±5%, TA = TMIN to TMAX, unless otherwise noted.) (Notes 1, 2)
www.jsmsemi.com
第2/5页
JSM-MAX485
Low-Power
DC ELECTRICAL CHARACTERISTICS (continued)
PARAMETER
SYMBOL
CONDITIONS
DE = VCC
No-Load Supply Current
ICC
RE = 0V or
(Note 3)
VCC DE = 0V
300
500
µA
IOSD1
-7V VO 12V (Note 4)
35
250
mA
IOSD2
-7V VO 12V (Note 4)
35
250
mA
IOSR
0V VO VCC
or
Driver Short-Circuit Current,
MIN TYP MAX UNITS
500 900
95
mA
VO = High
VO = Low
Receiver Short-Circuit Current
ct
SWITCHING CHARACTERISTICS
7
CONDITIONS
MIN
tPLH
RDIFF = 54Ω,
tPHL
CL1 = CL2 = 100pF
Driver Output Skew to Output
tSKEW
Driver Enable to Output High
du
SYMBOL
TYP MAX UNITS
30
60
10
30
60
RDIFF = 54Ω, CL1 = CL2 = 100pF
5
10
ns
tZH
CL= 100pF, S2 closed
40
70
ns
Driver Enable to Output Low
tZL
CL= 100pF, S1 closed
40
70
ns
Driver Disable Time from Low
tLZ
CL= 15pF, S1 closed
40
70
ns
Driver Disable Time from High
tHZ
CL= 15pF, S2 closed
40
70
ns
| tPLH - tPHL | Differential
tSKD
RDIFF = 54Ω,
13
S
Receiver Skew
em
Driver Input to Output
on
10
ic
PARAMETER
ns
ns
CL1 = CL2 = 100pF
tZL
CRL = 15pF, S1 closed
ns
Receiver Enable to Output High
tZH
CRL = 15pF, S2 closed
ns
Receiver Disable
from Low
Receiver Disable
from High
Maximum Data Rate
Time
tLZ
ns
Time
tHZ
ns
JS
MI
CR
O
Receiver Enable to Output Low
fMAX
2.5
www.jsmsemi.com
Mbps
第3/5页
JSM-MAX485
Low-Power
JS
MI
CR
O
S
em
ic
on
du
ct
or
Operation timing diagrams of JSM-MAX485.
Transmission
Inputs
RE
DE
X
1
X
1
X-don’t care
Z-high resistance
Table of JSM-MAX485 operation.
DI
1
X
X
Z
Z
Z
Outputs
Y
1
Z
Z
www.jsmsemi.com
Receipt
RE
Inputs
DE
A-B
+0.2V
-0.2V
open
X
Outputs
RO
1
Z
第4/5页
JSM-MAX485
Low-Power
Symbol
S
em
ic
on
du
ct
or
PackageDimension
Dimensions in Millimeters
Dimensions in Inches
Max
Min
Max
1.350
1.750
0.053
0.069
0.100
0.250
0.004
0.010
1.350
1.550
0.053
0.061
b
0.330
0.510
0.013
0.020
c
0.170
0.250
0.006
0.010
D
4.700
5.100
0.185
0.200
E
3.800
4.000
0.150
0.157
E1
5.800
6.200
0.228
0.244
A
A1
JS
MI
A2
CR
O
Min
e
1.270 (BSC)
0.050 (BSC)
L
0.400
1.270
0.016
0.050
θ
0º
8º
0º
8º
www.jsmsemi.com
第5/5页
很抱歉,暂时无法提供与“MAX485ESA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.16000
- 30+1.12000
- 100+1.04000
- 500+0.96000
- 1000+0.92000
- 国内价格
- 5+1.82348
- 50+1.43241
- 150+1.24157
- 500+1.07126
- 2500+1.02449
- 5000+0.99641
