【AR Series】
Thin Film Precision Chip Resistor
(AR Series)
■Features
-Advanced thin film technology
-Very tight tolerance down to ±0.01%
-Extremely low TCR down to ±2PPM/°C
-Wide resistance range 1ohm ~ 3Mega ohm
-Miniature size 0201 available
■Applications
-Medical Equipment
-Testing / Measurement Equipment
-Printer Equipment
-Automatic Equipment Controller
-Converters
-Communication Device, Cell Phone, GPS, PDA
■Construction
L
D1
W
3
4
5
6
T
9
D2
871
1 Alumina Substrate
4 Edge Electrode (NiCr)
Bottom
Electrode
(Ag)
2
5 Barrier Layer (Ni)
3 Top Electrode (Ag)
6 External Electrode (Sn)
2
7 Resistor Layer (NiCr)
8 Overcoat (Epoxy)
9 Marking
■Dimensions
Unit: mm
Type
Size
(Inch)
L
W
T
D1
D2
AR01
AR02
AR03
AR05
AR06
AR13
AR10
AR12
0201
0402
0603
0805
1206
1210
2010
2512
0.58±0.05
1.00±0.05
1.55±0.10
2.00±0.15
3.05±0.15
3.10±0.15
4.90±0.15
6.30±0.15
0.29±0.05
0.50±0.05
0.80±0.10
1.25±0.15
1.55±0.15
2.40±0.15
2.40±0.15
3.10±0.15
0.23±0.05
0.30±0.05
0.45±0.10
0.55±0.10
0.55±0.10
0.55±0.10
0.55±0.10
0.55±0.10
0.12±0.05
0.20±0.10
0.30±0.20
0.30±0.20
0.42±0.20
0.40±0.20
0.60±0.30
0.60±0.30
0.15±0.05
0.20±0.10
0.30±0.20
0.40±0.20
0.35±0.25
0.55±0.25
0.50±0.25
0.50±0.25
Weight
(g)
(1000pcs)
0.14
0.54
1.83
4.71
9.02
10
23.61
38.06
■Part Numbering
AR
03
T
T
B
Y
1001
N
Product
Type
Dimensions
(L×W)
Resistance
Tolerance
Packaging
Code
TCR
(PPM/°C)
Power
Rating
Resistance
Marking
Code
01: 0201
02: 0402
03: 0603
05: 0805
06: 1206
13: 1210
10: 2010
12: 2512
T: ±0.01%
A: ±0.05%
B: ±0.1%
C: ±0.25%
D: ±0.5%
F: ±1%
www.viking.com.tw
T: Taping Reel
B: Bulk
: Standard
Y: 1/16W
X: 1/10W
W: 1/8W
M: 1/6W
P: 1/5W
V: 1/4W
O: 1/3W
U: 1/2W
Q: 3/4W
T: 1W
X: ±2
O:±3
S: ±5
B: ±10
N: ±15
C: ±25
D: ±50
For detail questions, contact : sales@viking.com.tw
1
0010: 1Ω
4R70: 4.7Ω
1001: 1KΩ
1004: 1MΩ
: Standard Marking
for E96 / E24
N: No Marking
Edition : REV.D7
Revision:28-Apr-2015
【AR Series】
■Derating Curve
Power ratio(%)
100
80
60
40
60
80
100
120
140
160
180
Ambient Temperature(℃)
■Standard Electrical Specifications
Item
Type
Power
Rating
at 70°C
Operating
Temp. Range
Max.
Operating
Voltage
Max.
Overload
Voltage
AR01 (0201)
1/32W
-55 ~ +155°C
15V
30V
Resistance Range
±0.05%
±0.1%
±0.25%
±0.5%
±1%
49.9Ω - 4.99KΩ
49.9Ω - 33KΩ
AR02 (0402)
1/16W
-55 ~ +155°C
25V
50V
49.9Ω - 12KΩ 10Ω - 255KΩ
4.7Ω – 511KΩ
AR03 (0603)
1/16W
-55 ~ +155°C
50V
100V
4.7Ω -332KΩ
4.7Ω - 1MΩ
1Ω - 1MΩ
AR05 (0805)
1/10W
-55 ~ +155°C
100V
200V
4.7Ω -1MΩ
4.7Ω - 2MΩ
1Ω - 2MΩ
AR06 (1206)
1/8W
AR13 (1210)
1/4W
-55 ~ +155°C
150V
300V
4.7Ω - 1MΩ 4.7Ω - 2.49MΩ
AR10 (2010)
1/4W
AR12 (2512)
1/2W
-55 ~ +155°C
150V
300V
4.7Ω - 1MΩ
4.7Ω - 3MΩ
TCR
(PPM/°C)
±25
±50
±25
±50
±25
±50
±25
±50
1Ω - 2.49MΩ
±25
±50
1Ω - 3MΩ
±25
±50
Lower Resistance:1~10Ω
■Special Electrical Specifications
Item
Type
Power
Rating
at 70°C
Operating
Temp. Range
Max.
Operating
Voltage
Max.
Overload
Voltage
Resistance Range
±0.01% ±0.05% ±0.1%
±0.25%
49.9Ω - 4.99KΩ
AR02 (0402)
1/16W
-55 ~ +155°C
25V
50V
49.9Ω - 12KΩ
49.9Ω - 4.99KΩ
49.9Ω - 60KΩ
49.9Ω -69.8KΩ
24.9Ω - 15KΩ
AR03 (0603)
1/16W
-55 ~ +155°C
50V
100V
24.9Ω - 15KΩ
24.9Ω 100KΩ
4.7Ω332KΩ
4.7Ω - 511KΩ
24.9Ω - 30KΩ
AR05 (0805)
1/10W
-55 ~ +155°C
100V
200V
24.9Ω - 30KΩ
24.9Ω 200KΩ
4.7Ω – 1MΩ
24.9Ω - 49.9KΩ
AR06 (1206)
1/8W
-55 ~ +155°C
150V
300V
24.9Ω - 49.9KΩ
24.9Ω 499KΩ
4.7Ω - 1MΩ
24.9Ω - 49.9KΩ
AR13 (1210)
1/ 4W
-55 ~ +155°C
150V
300V
24.9Ω - 49.9KΩ
24.9Ω 499KΩ
4.7Ω - 1MΩ
24.9Ω - 100KΩ
AR10 (2010)
1/4W
-55 ~ +155°C
150V
300V
24.9Ω - 100KΩ
24.9Ω 499KΩ
4.7Ω - 1MΩ
24.9Ω - 100KΩ
AR12 (2512)
1/2W
-55 ~ +155°C
150V
300V
24.9Ω - 100KΩ
24.9Ω 499KΩ
www.viking.com.tw
±0.5%
4.7Ω - 1MΩ
2
±1%
TCR
(PPM/°C)
±2
±3
±5
±10
±15
±2
±3
±5
±10
±15
±2
±3
±5
±10
±15
±2
±3
±5
±10
±15
±2
±3
±5
±10
±15
±2
±3
±5
±10
±15
±2
±3
±5
±10
±15
Edition : REV.D7
【AR Series】
■High Power Rating Electrical Specifications
Item
Type
Power
Rating
at 70°C
Operating
Temp.
Range
Max.
Max.
Operating Overload
Voltage
Voltage
Resistance Range
±0.01%
±0.05%
±0.1% ±0.25% ±0.5%
24.9Ω - 15KΩ
24.9Ω - 15KΩ
AR03
(0603)
1/10W
-55 ~ +155°C
75V
150V
4.7Ω - 332KΩ
24.9Ω 100KΩ
1/6W
-55 ~ +155°C
100V
150V
4.7Ω - 332KΩ
4.7Ω -1MΩ
10Ω - 332KΩ
24.9Ω - 30KΩ
24.9Ω - 30KΩ
AR05
(0805)
1/8W
-55 ~ +155°C
150V
300V
4.7Ω -511KΩ
24.9Ω 200KΩ
4.7Ω - 1MΩ
4.7Ω -511KΩ
4.7Ω 1MΩ
1/4W
-55 ~ +155°C
150V
300V
1Ω - 1MΩ
10Ω - 499KΩ
24.9Ω - 49.9KΩ
24.9Ω - 49.9KΩ
AR06
(1206)
1/4W
1/3W
-55 ~ +155°C
-55 ~ +155°C
200V
200V
400V
4.7Ω - 1MΩ
10Ω ~1MΩ
24.9Ω – 49.9KΩ
AR13
(1210)
1/ 3W
-55 ~ +155°C
200V
24.9Ω – 49.9KΩ
400V
24.9Ω 499KΩ
4.7Ω - 1MΩ
24.9Ω - 49.9KΩ
AR10(2010)
24.9Ω - 49.9KΩ
1/3W
-55 ~ +155°C
200V
400V
24.9Ω 499KΩ
3/4W
-55 ~ +155°C
200V
400V
1W
-55 ~ +155°C
200V
400V
4.7Ω - 1MΩ
24.9Ω - 2KΩ
4.7Ω – 2KΩ
1Ω – 2KΩ
AR12(2512)
4.7Ω –
100Ω
±2
±3
±5
±10
±15
±25
±50
±25
±50
±2
±3
±5
±10
±15
±25
±50
±25
±50
±2
±3
±5
400V
24.9Ω 499KΩ
±1%
TCR
(PPM/°C)
1Ω – 100Ω
±10
±15
±25
±50
±25
±50
±2
±3
±5
±10
±15
±25
±50
±2
±3
±5
±10
±15
±25
±50
±10
±15
±25
±50
±25
±50
Operating Voltage=√(P*R) or Max. operating voltage listed above, whichever is lower.
Overload Voltage=2.5*√(P*R) or Max. overload voltage listed above, whichever is lower.
Viking is capable of manufacturing the optional spec based on customer’s requirement.
(Lower Resistance:1~10Ω ; High Power Rating)
www.viking.com.tw
3
Edition : REV.D7
【AR Series】
■Environmental Characteristics
Requirement
Item
Tol. ≦ 0.05%
MIL-STD-202 Method 304
+25/-55/+25/+125/+25°C
Temperature Coefficient of Resistance
As Spec.
(T.C.R.)
ΔR±0.05%
Short Time Overload
JIS-C-5201-1 5.5
RCWV*2.5 or Max. overload voltage whichever is
lower for 5 seconds
ΔR±0.2%
ΔR±0.2% for high power rating
Insulation Resistance
MIL-STD-202 Method 302
Apply 100VDC for 1 minute
>1000 MΩ
ΔR±0.05%
Endurance
ΔR±0.2%
MIL-STD-202 Method 108A
70±2°C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5
hrs “OFF”
>7kΩ ΔR±0.5%
ΔR±0.5% for high power rating
ΔR±0.05%
Damp Heat with Load
MIL-STD-202 Method 103B
40±2°C, 90~95% R.H. RCWV for 1000 hrs with 1.5
hrs “ON” and 0.5 hrs “OFF”
ΔR±0.3%
Bending Strength
ΔR±0.05%
Solderability
95% min. coverage
Resistance to Soldering Heat
ΔR±0.05%
Dielectric Withstand Voltage
By Type
Thermal Shock
ΔR±0.05%
ΔR±0.25%
ΔR±0.05%
ΔR±0.2%
Low Temperature Operation
Test Method
Tol. > 0.05%
JIS-C-5201-1 6.1.4
Bending amplitude 3 mm for 10 seconds
ΔR±0.2%
MIL-STD-202 Method 208H
245±5°C for 3 seconds
MIL-STD-202 Method 210E
260±5°C for 10 seconds
ΔR±0.2%
MIL-STD-202 Method 301
Max. overload voltage for 1 minute
MIL-STD-202 Method 107G
-55°C ~150°C, 100 cycles
JIS-C-5201-1 7.1
1 hour, -65°C, followed by 45 minutes of RCWV
RCWV(Rated continuous working voltage)= √(P*R) or Max. Operating voltage whichever is lower
Storage Temperature: 25±3°C; Humidity < 80%RH
■Soldering Condition
IR Reflow Soldering
Wave Soldering (Flow Soldering)
(1) Time of IR reflow soldering at maximum temperature point 260°C:10s
(2) Time of wave soldering at maximum temperature point 260°C:10s
(3) Time of soldering iron at maximum temperature point 410°C:5s
www.viking.com.tw
4
Edition : REV.D7
【AR Series】
▓Marking
0603 3digit marking
3digit marking for Example: 14C=13K7Ω
14C
68B=4K99Ω
13C=13K3Ω
68X=49.9Ω
Marking Table
Code
E96
Code
E96
Code
E96
Code
E96
01
100
25
178
49
316
73
562
02
102
26
182
50
324
74
576
03
105
27
187
51
332
75
590
04
107
28
191
52
340
76
604
05
110
29
196
53
348
77
619
06
113
30
200
54
357
78
634
07
115
31
205
55
365
79
649
08
118
32
210
56
374
80
665
09
121
33
215
57
383
81
681
10
124
34
221
58
392
82
698
11
127
35
226
59
402
83
715
12
130
36
232
60
412
84
732
13
133
37
237
61
422
85
750
14
137
38
243
62
432
86
768
15
140
39
249
63
442
87
787
16
143
40
255
64
453
88
806
17
147
41
261
65
464
89
825
18
150
42
267
66
475
90
845
19
154
43
274
67
487
91
866
44
280
68
499
92
887
21
162
45
287
69
511
93
909
22
165
46
294
70
523
94
931
23
169
47
301
71
536
95
953
24
174
48
309
72
549
96
976
Code
A
Multiplier
10
B
C
1
10
0603 3digit marking for E24
E24
10
11
12
0805~2512 4digit marking
www.viking.com.tw
13
D
2
10
E
3
10
F
4
10
G
5
10
H
6
10
X
7
10
Y
-1
10
Z
-2
10
-3
Example: 101=100Ω 102=1KΩ
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
82
91
Example
Resistance
100Ω
2.2KΩ
10KΩ
49.9KΩ
100KΩ
marking
1000
2201
1002
4992
1003
5
Edition : REV.D7
【AR Series】
■Packaging
Unit :mm
Packing Quantity & Reel Specifications
Type
ØA
ØB
ØC
W
T
Paper
Tape (EA)
Emboss
Plastic
Tape (EA)
AR01
178.0±1.0 60.0+1.0 13.5±0.7
9.5±1.0
11.5±1.0
10,000
AR02
9.5±1.0
11.5±1.0
10,000
AR03
9.5±1.0
11.5±1.0
5,000
AR05
9.5±1.0
11.5±1.0
5,000
AR06
9.5±1.0
11.5±1.0
5,000
AR13
178.0±1.0 60.0±1.0 13.5±0.7
9.5±1.0
11.5±1.0
5,000
AR10
178.0±1.0 60.0+1.0 13.5±0.7 13.5±1.0 15.5±1.0
4,000
AR12
4,000
Paper Tape Specifications
Top Tape
Bottom Tape
ψ D0
E
A
F
B
T
P1
Resistor
Paper Tape
P0
P2
W
direction of unreeling
Unit: mm
Type
A
B
W
E
F
P0
P1
P2
ΦD0
T
AR01
0.40±0.05
0.70±0.05
8.00±0.10
1.75±0.05
3.5±0.05
4.00±0.10
2.00±0.05
2.00±0.05
1.55±0.03
0.42±0.02
AR02
0.70±0.05
1.16±0.05
8.00±0.10
1.75±0.05
3.5±0.05
4.00±0.10
2.00±0.05
2.00±0.05
1.55±0.05
0.40±0.03
AR03
1.10±0.05
1.90±0.05
8.00±0.10
1.75±0.05
3.5±0.05
4.00±0.10
4.00±0.10
2.00±0.05
1.55±0.05
0.60±0.03
AR05
1.60±0.05
2.37±0.05
8.00±0.10
1.75±0.05
3.5±0.05
4.00±0.10
4.00±0.10
2.00±0.05
1.55±0.05
0.75±0.05
AR06
2.00±0.05
3.55±0.05
8.00±0.10
1.75±0.05
3.5±0.05
4.00±0.10
4.00±0.10
2.00±0.05
1.55±0.05
0.75±0.05
AR13
2.75±0.05
3.40±0.05
8.00±0.10
1.75±0.05
3.5±0.05
4.00±0.05
4.00±0.10
2.00±0.05
1.60±0.10
0.75±0.05
Peel force of top cover tape
The peel speed shall be about 300mm/min±5%
The peel force of top cover tape shall be between 8gf to 60gf
www.viking.com.tw
6
Edition : REV.D7
【AR Series】
Emboss Plastic Tape Specifications
Top Tape
ψ D0
E
A
F
B
W
ψ D1 1.4Min.
T
P1
Resistor
P2
P0
Emboss Tape
Unit: mm
Type
A
B
W
E
F
P0
P1
P2
ØD0
T
AR10
2.85±0.10
5.45±0.10
12.0±0.10
1.75±0.10
5.5±0.05
4.00±0.05
4.00±0.10
2.00±0.05
1.50+0.10
1.00±0.20
AR12
3.40±0.10
6.65±0.10
12.0±0.10
1.75±0.10
5.5±0.05
4.00±0.05
4.00±0.10
2.00±0.05
1.50+0.10
1.00±0.20
The peel force of top cover tape shall be between 20gf to 80gf
■Recommend Land Pattern
Unit: mm
C
B
www.viking.com.tw
A
Type
A
B
C
AR01
0.25
0.30
0.40±0.2
AR02
0.50
0.50
0.60±0.2
AR03
0.80
1.00
0.90±0.2
AR05
1.00
1.00
1.35±0.2
AR06
2.00
1.15
1.70±0.2
AR13
2.00
1.15
2.50±0.2
AR10
3.60
1.40
2.50±0.2
AR12
4.90
1.60
3.10±0.2
7
Edition : REV.D7
【AR Series】
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
Version D3
Jan. 14, 2013
DESCRIPTION
- Add resistance range for Special
Electrical and High Power Rating
Electrical Specifications.
- Adjust the mockup.
Version D4
Apr. 10, 2013
- Add "RCWV" description in Environment
Characteristic Test Method.
Version D5
Oct. 16, 2013
- Increase the resistance range of AR05,
TCR15 product.
Version D6
Oct. 17, 2014
- Correct the specification of top cover tape
peel force.
- Update the resistance range of AR05
(Standard) to 4.7Ω -1MΩ
Version D7
Apr. 28, 2015
- Add TCR ±2ppm and ±3ppm products
specification.
- Increase the resistance range of the
products below:
• AR02 and AR03 of Standard Electrical
Specifications.
• AR02, AR03 and AR05 of Special
- Correct the element of Top Electrode.
www.viking.com.tw
8
Edition : REV.D7
很抱歉,暂时无法提供与“AR05DTBW1002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.43250
- 100+0.39500
- 500+0.35750
- 1000+0.32000
- 2000+0.29500
- 4000+0.28750
