Stackpole Electronics, Inc.
CSRF Series
Resistive Product Solutions
Foil on Ceramic Current Sensing Chip Resistor
Features:
High power rating
Wide resistance range
Current handling up to 26 amps
TCR down to ± 50 ppm/C
Other resistance values may be available
RoHS compliant, lead free and halogen free
Electrical Specifications - CSRF
Type / Code
Power Rating (W)
TCR (ppm/ºC)
(1)
1
CSRF2512 (2)
2
CSRF2817
5
4
± 300
± 200
± 100
± 150
± 75
± 100
± 50
± 100
± 50
± 100
± 50
± 100
± 100
± 75
± 100
± 50
± 100
± 50
± 50
± 50
CSRF4320
5
± 50
CSRF0402
(2)
0.125
CSRF0603
(2)
0.25
CSRF0805
(2)
0.5
CSRF0508 (2)
1
(2)
1
CSRF1206
1.5
CSRF0612
CSRF2010
1
Ohmic Range (Ω) and Tolerance
1% and 5%
0.003 - 0.007
0.008 - 0.02
0.002 - 0.004
0.005 - 0.009
0.01 - 0.03
0.003 - 0.01
0.011 - 0.03
0.005 - 0.009
0.01 - 0.062
0.003 - 0.01
0.011 - 0.05
0.002
0.003 - 0.004
0.005 - 0.03
0.003 - 0.009
0.01 - 0.1
0.003 - 0.01
0.011 - 0.6
0.005, 0.006, 0.008, 0.01, 0.015, 0.02
0.033
0.01 - 0.33
(1) For 2010 size, MOQ of 20K pieces per value is required.
(2) Qualified to AEC-Q200
Electrical Specifications – CSRF-HP
Type / Code
CSRF0402…-HP
Power Rating (W)
(2)
TCR (ppm/ºC)
±400
±300
±200
±100
±100
±75
±100
±50
0.25
CSRF0603…-HP (2)
0.5
CSRF0805…-HP
1
1% and 5%
0.0025
0.003 - 0.004
0.005 - 0.007
0.008 - 0.02
0.002 - 0.009
0.01 - 0.03
0.005 - 0.009
0.01 - 0.03
Please refer to the High-Power Resistor Application Note (page 8) for more information on designing and implementing high power
resistor types.
Rev Date: 03/24/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
CSRF Series
Mechanical Specifications – CSRF0402
Type / Code
CSRF0402
0.003 Ω - 0.007 Ω
CSRF0402
0.008 Ω - 0.02 Ω
L
Body Length
0.039 ± 0.004
1.00 ± 0.10
0.039 ± 0.004
1.00 ± 0.10
W
Body Width
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
t
Body Height
0.018 ± 0.004
0.45 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
A
Bottom Termination
0.014 ± 0.004
0.35 ± 0.10
0.010 ± 0.004
0.25 ± 0.10
Unit
inches
mm
inches
mm
Mechanical Specifications – CSRF0402…-HP
Type / Code
CSRF0402…-HP
0.0025 Ω
CSRF0402… -HP
0.003 Ω - 0.004 Ω
Type / Code
CSRF0402…-HP
0.005 Ω - 0.007 Ω
CSRF0402…-HP
0.008 Ω - 0.02 Ω
L
Body Length
0.039 ± 0.004
1.00 ± 0.10
0.039 ± 0.004
1.00 ± 0.10
W
Body Width
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
t
Body Height
0.018 ± 0.004
0.45 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
A
Bottom Termination
0.018 ± 0.004
0.45 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
L
Body Length
0.039 ± 0.004
1.00 ± 0.10
0.039 ± 0.004
1.00 ± 0.10
W
Body Width
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
t
Body Height
0.018 ± 0.004
0.45 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
A
Bottom Termination
0.014 ± 0.004
0.35 ± 0.10
0.010 ± 0.004
0.25 ± 0.10
2
Unit
inches
mm
inches
mm
Unit
inches
mm
inches
mm
www.seielect.com
CSRF Series
Mechanical Specifications – CSRF0603 and CSRF0603…-HP
L
Body Length
CSRF0603
0.063 ± 0.004
0.002 Ω - 0.004 Ω
1.60 ± 0.10
CSRF0603
0.063 ± 0.004
0.005 Ω - 0.03 Ω
1.60 ± 0.10
Note: CSRF0603…2L50 has no marking.
W
Body Width
0.031 ± 0.004
0.80 ± 0.10
0.031 ± 0.004
0.80 ± 0.10
Type / Code
t
Body Height
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
A
Bottom Termination
0.022 ± 0.008
0.55 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
Unit
inches
mm
inches
mm
Mechanical Specifications – CSRF0805
Type / Code
CSRF0805
L
Body Length
0.083 ± 0.008
2.10 ± 0.20
W
Body Width
0.051 ± 0.006
1.30 ± 0.15
t
Body Height
0.028 ± 0.006
0.70 ± 0.15
A
Top Termination
0.016 ± 0.008
0.40 ± 0.20
B
Bottom Termination
0.018 ± 0.008
0.45 ± 0.20
Unit
inches
mm
Mechanical Specifications – CSRF0805…-HP
Type / Code
CSRF0805…-HP
L
Body Length
0.083 ± 0.008
2.10 ± 0.20
W
Body Width
0.051 ± 0.006
1.30 ± 0.15
t
Body Height
0.028 ± 0.006
0.70 ± 0.15
B
Bottom Termination
0.018 ± 0.008
0.45 ± 0.20
Unit
inches
mm
Mechanical Specifications – CSRF0508
Type / Code
CSRF0508
L
Body Length
0.047 ± 0.010
1.20 ± 0.25
W
Body Width
0.079 ± 0.010
2.00 ± 0.25
3
H
Body Height
0.026 ± 0.008
0.65 ± 0.20
t
Bottom Termination
0.017 ± 0.008
0.43 ± 0.20
Unit
inches
mm
www.seielect.com
CSRF Series
Mechanical Specifications – CSRF1206 and CSRF2512
Type / Code
CSRF1206
CSRF2512
L
Body Length
0.122 ± 0.008
3.10 ± 0.20
0.254 ± 0.008
6.45 ± 0.20
W
Body Width
0.061 ± 0.008
1.55 ± 0.20
0.128 ± 0.008
3.25 ± 0.20
t
Body Height
0.031 ± 0.006
0.80 ± 0.15
0.031 ± 0.006
0.80 ± 0.15
A
Top Termination
0.020 ± 0.008
0.50 ± 0.20
0.035 ± 0.010
0.90 ± 0.25
B
Bottom Termination
0.022 ± 0.008
0.55 ± 0.20
0.043 ± 0.010
1.10 ± 0.25
Unit
inches
mm
inches
mm
Mechanical Specifications – CSRF0612
Type / Code
CSRF0612
L
Body Length
0.063 ± 0.008
1.60 ± 0.20
W
Body Width
0.126 ± 0.008
3.20 ± 0.20
t
Body Height
0.024 ± 0.008
0.60 ± 0.20
A
Bottom Termination
0.012 ± 0.008
0.30 ± 0.20
Unit
inches
mm
Mechanical Specifications – CSRF2010
Type / Code
CSRF2010
< 0.005 Ω
CSRF2010
≥ 0.005 Ω
L
Body Length
0.197 ± 0.008
5.00 ± 0.20
0.197 ± 0.008
5.00 ± 0.20
W
Body Width
0.098 ± 0.008
2.50 ± 0.20
0.098 ± 0.008
2.50 ± 0.20
H
Body Height
0.030 ± 0.008
0.75 ± 0.20
0.030 ± 0.008
0.75 ± 0.20
A
Bottom Termination
0.063 ± 0.008
1.60 ± 0.20
0.024 ± 0.008
0.60 ± 0.20
Unit
inches
mm
inches
mm
Mechanical Specifications – CSRF2817
Type / Code
CSRF2817
L
Body Length
0.280 ± 0.012
7.10 ± 0.30
W
Body Width
0.165 ± 0.012
4.20 ± 0.30
4
H
Body Height
0.031 ± 0.008
0.80 ± 0.20
T
Bottom Termination
0.039 ± 0.012
1.00 ± 0.30
Unit
inches
mm
www.seielect.com
CSRF Series
Mechanical Specifications – CSRF4320
L
Body Length
0.433 ± 0.008
11.00 ± 0.20
Type / Code
CSRF4320
W
Body Width
0.197 ± 0.008
5.00 ± 0.20
t
Body Height
0.026 ± 0.008
0.65 ± 0.20
A
Bottom Termination
0.093 ± 0.012
2.36 ± 0.30
Unit
inches
mm
Performance Characteristics
Test
Test Method
Test Specification
Typical
Test Condition
Load Life
MIL-STD-202F-Method 108A
±1%
≤ 0.5%
RCWV at 70 °C; 1.5 hours "ON"; 0.5 hour "OFF"
Total 1000 ± 24 hours
Resistance to Soldering Heat
MIL-STD-202F-Method 210E
±1%
≤ 0.3%
260 ± 5°C for 10 ± 1 seconds
Solderability
MIL-STD-202F-Method 208H
minimum 95%
coverage
> 95%
245 ± 5°C for 2 ± 0.5 seconds
Thermal Shock
MIL-STD-202F-Method 107G
±1%
≤ 0.3%
-55°C to 150°C, 100 cycles
JIS-C-5202-5.5
± 1% + 0.5 m Ω
≤ 0.3%
High Temperature Exposure
Moisture Resistance
MIL- STD-202F-Method 106G
±1%
±1%
≤ 0.2%
≤ 0.5%
Insulation Resistance
MIL-STD-202F-Method 302
1MΩ minimum
≥ 1MΩ
Short Time Overload
Size 0805-HP: 2.5 X rated power for 5 seconds
Sizes 0508, 2817: 2.5 X rated power for 5 seconds
Size 4320: 3 X rated power for 5 seconds
All other sizes: 5 X rated power for 5 seconds
125ºC, 1000 hours
Apply 100VDC for 1 minute
(*) Sufficient copper size and weight required to maintain component temperature below 100°C
Storage Temperature: 5 ~ 35°C. humidity: 40 ~ 75%
Operating temperature range: CSRF2817 = -55°C to + 155°C; all other sizes = -55°C to + 170°C
Power Derating Curve:
Percent Rated Power (%)
100
-55ºC
70ºC
100°C
80
60
2010
2817
All others
40
155°C
60
80
100
120
140
160
170ºC
180
Terminal Temperature (ºC)
5
www.seielect.com
CSRF Series
Taping Specifications – Paper Tape
Type / Code
CSRF0402
CSRF0603
CSRF0805
CSRF0508
CSRF1206
CSRF0612
A
0.028
0.70
0.043
1.10
0.063
1.60
0.066
1.68
0.079
2.00
0.079
2.00
Type / Code
CSRF0402
CSRF0603
CSRF0805
CSRF0508
CSRF1206
CSRF0612
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
B
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
± 0.008
± 0.20
± 0.004
± 0.10
± 0.004
± 0.10
P0
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.047
1.20
0.075
1.90
0.094
2.40
0.094
2.38
0.142
3.60
0.142
3.60
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
E
± 0.002
± 0.05
± 0.004
± 0.10
± 0.004
± 0.10
± 0.008
± 0.20
± 0.004
± 0.10
± 0.004
± 0.10
P1
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
F
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
± 0.004
± 0.10
P2
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.002
0.05
0.002
0.05
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
W
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.004
± 0.10
± 0.002
± 0.05
± 0.002
± 0.05
D0
0.061
1.55
0.061
1.55
0.061
1.55
0.059
1.50
0.061
1.55
0.061
1.55
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.002
0.05
0.002
0.05
Unit
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
T
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.008
0.20
0.008
0.20
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Unit
0.024
0.60
0.028
0.70
0.038
0.97
0.034
0.87
0.038
0.97
0.038
0.97
0.004
0.10
0.004
0.10
0.004
0.10
0.008
0.20
0.004
0.10
0.004
0.10
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
0.012
0.30
0.008
0.20
Inches
mm
Inches
mm
0.008
0.20
0.008
0.20
Inches
mm
Inches
mm
Taping Specifications – Embossed Plastic Tape
Type / Code
CSRF2010
CSRF2512
A
0.110
2.80
0.138
3.50
Type / Code
CSRF2010
CSRF2512
B
0.006
0.15
0.004
0.10
0.217
5.50
0.268
6.80
0.004
0.10
0.002
0.05
0.157
4.00
0.157
4.00
P0
0.157
4.00
0.157
4.00
E
0.006
0.15
0.004
0.10
0.069
1.75
0.069
1.75
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
P1
F
0.004
0.10
0.004
0.10
0.217
5.50
0.217
5.50
0.002
0.05
0.002
0.05
0.059
1.50
0.059
1.50
P2
6
W
0.002
0.05
0.002
0.05
0.472
12.00
0.472
12.00
± 0.004
± 0.1
0.10
± 0.004
± 0.10
0.033
0.84
0.039
1.00
D0
Unit
T
Unit
www.seielect.com
CSRF Series
Type / Code
A
0.181
4.60
0.211
5.36
CSRF2817
CSRF4320
Type / Code
B
0.004
0.10
0.004
0.10
0.295
7.50
0.462
11.74
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
P1
0.315
8.00
0.315
8.00
CSRF2817
CSRF4320
E
0.004
0.10
0.004
0.10
0.069
1.75
0.069
1.75
0.004
0.10
0.004
0.10
0.059
1.50
0.059
1.50
P2
F
0.004
0.10
0.004
0.10
0.217
5.50
0.453
11.50
0.004
0.10
0.004
0.10
0.061
1.55
0.059
1.50
D0
W
0.004
0.10
0.004
0.10
0.472
12.00
0.945
24.00
0.004
0.10
0.010
0.25
0.010
0.25
0.013
0.33
D1
P0
0.012
0.30
0.012
0.30
0.157
4.00
0.157
4.00
0.002
0.05
0.004
0.10
0.047
1.20
0.077
1.96
T1
Unit
0.004
0.10
0.004
0.10
Inches
mm
Inches
mm
0.004
0.10
0.004
0.10
Inches
mm
Inches
mm
T2
Unit
Recommended Pad Layouts - CSRF
Size
a
b
c
Unit
CSRF0402
0.003 Ω - 0.007 Ω
CSRF0402
0.008 Ω - 0.02 Ω
CSRF0603
0.002 Ω - 0.004 Ω
CSRF0603
0.005 Ω - 0.009 Ω
CSRF0603
0.01 Ω - 0.03 Ω
0.012
0.30
0.020
0.50
0.014
0.35
0.024
0.60
0.035
0.90
0.047
1.20
0.024
0.60
0.087
2.20
0.024
0.60
0.063
1.60
0.106
2.70
0.150
3.80
0.165
4.20
0.157
4.00
0.024
0.60
0.020
0.50
0.043
1.10
0.035
0.90
0.028
0.70
0.047
1.20
0.043
1.10
0.051
1.30
0.051
1.30
0.093
2.35
0.071
1.80
0.083
2.10
0.079
2.00
0.197
5.00
0.024
0.60
0.024
0.60
0.039
1.00
0.039
1.00
0.039
1.00
0.055
1.40
0.091
2.30
0.071
1.80
0.142
3.60
0.114
2.90
0.114
2.90
0.134
3.40
0.189
4.80
0.276
7.00
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
CSRF0805
CSRF0508
CSRF1206
CSRF0612
CSRF2010
0.003 Ω - 0.009 Ω
CSRF2010
0.01 Ω - 0.1 Ω
CSRF2512
CSRF2817
CSRF4320
7
www.seielect.com
CSRF Series
Recommended Pad Layouts – CSRF-HP
Size
a
b
c
Unit
CSRF0402…-HP
0.008
0.20
0.024
0.60
0.035
0.90
0.047
1.20
0.031
0.80
0.035
0.90
0.028
0.70
0.047
1.20
0.024
0.60
0.039
1.00
0.039
1.00
0.055
1.40
inches
mm
inches
mm
inches
mm
inches
mm
CSRF0603…-HP
0.005 Ω - 0.009 Ω
CSRF0603…-HP
0.01 Ω - 0.03 Ω
CSRF0805…-HP
Soldering Recommendations:
Peak reflow temperatures and durations:
o IR Reflow Peak = 260 °C max for 10 seconds
o Wave Solder = 260 °C max for 10 seconds
Compatible with lead and lead-free solder reflow process
Recommended IR Reflow Profile:
High Power Chip Resistors and Thermal Management
Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had
higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to
how to reliably use these resistors at the higher power ratings in their designs.
The data sheets for the RHC, RMCP, RNCP, CSR,
CSRN, CSRF, CSS, and CSSH state that the rated
power assumes an ambient temperature of no more
than 100ºC for the CSS / CSSH series and 70ºC for all
other high power resistor series. In addition, IPC and
UL best practices dictate that the combined
temperature on any resistor due to power dissipated
and ambient air shall be no more than 105ºC. At first
glance this wouldn’t seem too difficult, however the
graph below shows typical heat rise for the CSR1206
100 milliohm at full rated power. The heat rise for the
RMCP and RNCP would be similar. The RHC with its
unique materials, design, and processes would have
less heat rise and therefore would be easier to
implement for any given customer.
8
www.seielect.com
CSRF Series
The 102ºC heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this
part under 105 ºC total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at
the usual power rating for this size would have a heat rise of around 72ºC. This additional heat rise may be dealt with
using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the
conductors, vias through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of
methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power
ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best
accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so
it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over
another.
Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount
of solder used. This is especially notable for resistance values ≤ 50mΩ. This should be taken into account when designing.
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
CSRF
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Surface Mount Chip Resistor
SMD
YES
100% Matte Sn over Ni
Jul-04
04/27
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
9
www.seielect.com
CSRF Series
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
C
S
R
F
F
T
8
L
H
P
Product Series
Code Description
CSRF Foil / Ceramic
Size
Code
W
0402
0.125
0402(HP) 0.25
0.25
0603
0603(HP) 0.5
0.5
0805
0805(HP)
1
0508
1
1206
1
0612
1.5
2010
1
2512
2
2817
4, 5
4320
5
Tolerance
Code Tol
F
1%
J
5%
Code
T
Packaging
Description
Size
Quantity
0402
10000
7" Reel
0603, 0805
Paper Tape 0612, 1206 5000
0508
2010
4000
Embossed
2512
Plastic Tape
2000
2817, 4320
10
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
"L" used as multiplier
-3
of 10 for any value
under 0.1 ohm..
0.005 ohm = 5L00
0.01 ohm = 10L0
0.1 ohm = R100
Special
Code Description
-HP High Power
www.seielect.com
