BAS21VD
High-voltage switching diodes
1 August 2013
Product data sheet
1. General description
Triple high-voltage switching diodes, encapsulated in a SOT457 (SC-74/TSOP6) small
Surface-Mounted Device (SMD) plastic package.
2. Features and benefits
High switching speed: trr ≤ 50 ns
Low capacitance: Cd ≤ 5 pF
Reverse voltage: VR ≤ 200 V
AEC-Q101 qualified
Repetitive peak reverse voltage: VRRM ≤ 250 V
Repetitive peak forward current: IFRM ≤ 1 A
Small SMD plastic package
3. Applications
High-voltage switching in surface-mounted circuits
Automotive
Communication
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
IF
forward current
pulsed; tp ≤ 300 µs; δ ≤ 0.02
VR
reverse voltage
Min
Typ
Max
Unit
200
mA
200
V
25
100
nA
16
50
ns
Per diode
[1]
Per diode
IR
reverse current
VR = 200 V; Tamb = 25 °C; pulsed;
trr
reverse recovery time
IF = 30 mA; IR = 30 mA; IR(meas) = 3 mA;
RL = 100 Ω; Tamb = 25 °C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
BAS21VD
Nexperia
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
K1
cathode (diode 1)
2
K2
cathode (diode 2)
3
K3
cathode (diode 3)
4
A3
anode (diode 3)
5
A2
anode (diode 2)
6
A1
anode (diode 1)
Simplified outline
Graphic symbol
6
5
4
1
2
3
6
5
1
2
4
TSOP6 (SOT457)
3
006aab241
6. Ordering information
Table 3.
Type number
Package
BAS21VD
Name
Description
Version
TSOP6
plastic surface-mounted package (TSOP6); 6 leads
SOT457
7. Marking
Table 4.
Marking codes
Type number
Marking code
BAS21VD
B5
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Per diode
VRRM
repetitive peak reverse voltage
250
V
VR
reverse voltage
200
V
IF
forward current
200
mA
IFRM
repetitive peak forward current
tp ≤ 1 ms; δ ≤ 25 %
1
A
IFSM
non-repetitive peak forward
current
tp = 10 µs; Tj(init) = 25 °C; square wave
16
A
tp = 100 µs; Tj(init) = 25 °C; square wave
8
A
tp = 10 ms; Tj(init) = 25 °C; square wave
2
A
BAS21VD
Product data sheet
All information provided in this document is subject to legal disclaimers.
1 August 2013
[1]
Nexperia B.V. 2017. All rights reserved
2 / 11
BAS21VD
Nexperia
Symbol
Parameter
Conditions
Min
Max
Unit
[1]
250
mW
[2]
295
mW
Per device; one diode loaded
Ptot
total power dissipation
Tamb ≤ 25 °C
Tstg
storage temperature
-65
150
°C
Tj
junction temperature
150
°C
Tamb
ambient temperature
-65
150
°C
[1]
[2]
footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm .
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
[1]
500
K/W
[2]
425
K/W
[3]
140
K/W
Rth(j-a)
Rth(j-sp)
thermal resistance
from junction to
ambient
in free air
thermal resistance
from junction to solder
point
[1]
[2]
[3]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2
Soldering point of cathode tab.
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
forward voltage
IF = 100 mA; Tamb = 25 °C
1
V
IF = 200 mA; Tamb = 25 °C
1.25
V
VR = 200 V; pulsed; tp ≤ 300 µs;
25
100
nA
VR = 200 V; Tj = 150 °C
100
µA
f = 1 MHz; VR = 0 V; Tamb = 25 °C
0.6
5
pF
IF = 30 mA; IR = 30 mA; Tamb = 25 °C;
16
50
ns
Per diode
VF
IR
reverse current
δ ≤ 0.02 ; Tamb = 25 °C
Cd
diode capacitance
trr
RL = 100 Ω; IR(meas) = 3 mA
BAS21VD
Product data sheet
1 August 2013
3 / 11
BAS21VD
Nexperia
mbg384
600
IF
(mA)
mle165
102
IFSM
(A)
(1)
400
(2)
(3)
10
200
VF (V)
1
2
(1) Tj = 150 °C; typical values
(3) Tj = 25 °C; maximum values
Fig. 2.
102
103
104
tp (µA)
105
Non-repetitive peak forward current as a
function of pulse duration; maximum values
Forward current as a function of forward
voltage
mbg381
102
mle166
0.6
Cd
(pF)
IR
(µA)
0.5
10
(1)
1
(2)
0.4
10- 1
10- 2
0.3
Tj (°C)
0.2
200
Fig. 4.
Reverse current as a function of junction
temperature
BAS21VD
Product data sheet
VR (V)
40
f = 1 MHz; Tj = 25 °C
(1) VR = VRmax; maximum values
(2) VR = VRmax; typical values
Fig. 3.
10
Based on square wave currents.
Tj(init) = 25 °C
(2) Tj = 25 °C; typical values
Fig. 1.
1
Diode capacitance as a function of reverse
voltage; typical values
1 August 2013
4 / 11
BAS21VD
Nexperia
mle167
300
VR
(V)
IF
(mA)
200
200
100
100
100
200
Tamb (°C)
FR4 PCB, standard footprint
Fig. 5.
mbg442
300
200
Tamb (°C)
Reverse voltage as a function of ambient
temperature; derating curve
Fig. 6.
Forward current as a function of ambient
11. Test information
tr
D.U.T.
IF
RS = 50 Ω
V = VR + IF × RS
tp
10 %
t
+ IF
SAMPLING
OSCILLOSCOPE
trr
t
Ri = 50 Ω
mga881
VR
(1)
90 %
input signal
output signal
(1) IR = 3 mA
Fig. 7.
Reverse recovery time test circuit and waveforms
11.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
BAS21VD
Product data sheet
1 August 2013
5 / 11
BAS21VD
Nexperia
12. Package outline
3.1
2.7
6
3.0
2.5
1.7
1.3
1.1
0.9
5
4
2
3
0.6
0.2
pin 1 index
1
0.40
0.25
0.95
1.9
Dimensions in mm
Fig. 8.
0.26
0.10
04-11-08
Package outline TSOP6 (SOT457)
13. Soldering
3.45
1.95
0.45 0.55
(6×) (6×)
0.95
solder lands
solder resist
3.3 2.825
0.95
solder paste
occupied area
0.7
(6×)
Dimensions in mm
0.8
(6×)
2.4
Fig. 9.
sot457_fr
Reflow soldering footprint for TSOP6 (SOT457)
BAS21VD
Product data sheet
1 August 2013
6 / 11
BAS21VD
Nexperia
5.3
1.5
(4×)
1.475
0.45
(2×)
5.05
1.475
solder lands
solder resist
occupied area
Dimensions in mm
preferred transport
direction during soldering
1.45
(6×)
2.85
sot457_fw
Fig. 10. Wave soldering footprint for TSOP6 (SOT457)
BAS21VD
Product data sheet
1 August 2013
7 / 11
BAS21VD
Nexperia
14. Revision history
Table 8.
Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
BAS21VD v.3
20130801
Product data sheet
BAS21VD v.2
Modifications:
Table 7. Characteristics: parameter unit of VF corrected
Packing information: removed
Legal information: updated
BAS21VD v.2
20110629
Product data sheet
BAS21VD v.1
BAS21VD v.1
20030703
Product data sheet
BAS21VD
Product data sheet
1 August 2013
8 / 11
BAS21VD
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
15. Legal information
15.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
15.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
BAS21VD
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
1 August 2013
9 / 11
BAS21VD
Nexperia
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
BAS21VD
Product data sheet
1 August 2013
10 / 11
BAS21VD
Nexperia
16. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................2
9
Thermal characteristics .........................................3
10
Characteristics ....................................................... 3
11
11.1
Test information ..................................................... 5
Quality information ............................................... 5
12
Package outline ..................................................... 6
13
Soldering ................................................................ 6
14
Revision history ..................................................... 8
15
15.1
15.2
15.3
15.4
Legal information ...................................................9
Data sheet status ................................................. 9
Definitions .............................................................9
Disclaimers ...........................................................9
Trademarks ........................................................ 10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 01 August 2013
BAS21VD
Product data sheet
1 August 2013
11 / 11
