Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
dbook, halfpage
M3D088
PLVA6xxA series
Low-voltage avalanche regulator
diodes
Product data sheet
Supersedes data of 1999 May 25
2004 Jan 14
NXP Semiconductors
Product data sheet
Low-voltage avalanche regulator diodes
FEATURES
PLVA6xxA series
PINNING
• Very low dynamic impedance at low currents:
approximately 1⁄20 of conventional series
PIN
• Hard breakdown knee
• Low noise: approximately 1⁄10 of conventional series
• Total power dissipation: max. 250 mW
DESCRIPTION
1
anode
2
not connected
3
cathode
• Small tolerances of VZ
• Working voltage range: nominal 5.00 to 6.80 V
• Non-repetitive peak reverse power dissipation:
maximal 30 W.
handbook, halfpage
2
1
APPLICATIONS
2
n.c.
• Low current, low power, low noise applications
• CMOS RAM back-up circuits
1
3
• Voltage stabilizers
3
• Voltage limiters
Top view
MAM243
• Smoke detector relays.
DESCRIPTION
Fig.1 Simplified outline (SOT23) and symbol.
High performance voltage regulator diodes in small
SOT23 plastic SMD packages.
The series consists of PLVA650A to PLVA668A.
MARKING
TYPE NUMBER
MARKING CODE(1)
PLVA650A
*9A
PLVA653A
*9B
PLVA656A
*9C
PLVA659A
*9D
PLVA662A
*9E
PLVA665A
*9F
PLVA668A
*9G
Note
1. * = p: Made in Hong Kong.
* = t: Made in Malaysia.
* = W: Made in China.
2004 Jan 14
2
NXP Semiconductors
Product data sheet
PLVA6xxA series
ORDERING INFORMATION
TYPE
NUMBER
PLVA6xxA
PACKAGE
NAME
DESCRIPTION
VERSION
plastic surface mounted package; 3 leads
SOT23
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
250
mA
250
mA
continuous forward current
IZRM
repetitive peak working current
PZSM
non-repetitive peak reverse power dissipation tp = 100 μs; Tj = 150 °C −
Ptot
total power dissipation
Tstg
Tj
30
W
250
mW
storage temperature
−65
+150
°C
junction temperature
150
°C
Tamb = 25 °C; note 1
Note
1. Device mounted on an FR4 printed circuit-board.
2004 Jan 14
UNIT
IF
tp = 100 μs; δ = 10%
MAX.
3
NXP Semiconductors
Product data sheet
PLVA6xxA series
ELECTRICAL CHARACTERISTICS
Tj = 25 °C; unless otherwise specified.
SYMBOL
PARAMETER
CONDITIONS
V
PLVA650A
4.80
5.00
5.20
V
PLVA653A
5.10
5.30
5.50
V
PLVA656A
5.40
5.60
5.80
V
PLVA659A
5.70
5.90
6.10
V
PLVA662A
6.00
6.20
6.40
V
PLVA665A
6.30
6.50
6.70
V
PLVA668A
6.60
6.80
7.00
V
PLVA650A
4.30
V
PLVA653A
5.20
V
PLVA656A
5.51
V
PLVA659A
5.85
V
PLVA662A
6.19
V
PLVA665A
6.49
V
6.80
V
700
Ω
PLVA653A
250
Ω
PLVA656A to PLVA668A
100
Ω
PLVA650A
0.20
mV/K
PLVA653A
1.60
mV/K
PLVA656A
1.90
mV/K
PLVA659A
2.40
mV/K
PLVA662A
2.65
mV/K
PLVA665A
2.90
mV/K
PLVA668A
3.40
mV/K
PLVA650A
20 000
nA
PLVA653A
5 000
nA
PLVA656A
1 000
nA
PLVA659A
500
nA
PLVA662A
100
nA
PLVA665A
50
nA
PLVA668A
10
nA
IZ = 250 μA
working voltage
IZ = 10 μA
PLVA668A
dynamic resistance
PLVA650A
IR
2004 Jan 14
UNIT
0.9
IF = 10 mA
working voltage
SZ
MAX.
forward voltage
VZ
RZ
TYP.
VF
VZ
MIN.
temperature coefficient
reverse current
1 kHz superimposed;
IZAC is 10% of IZDC; IZ = 250 μA
IZ = 250 μA
VR = 80% VZ nominal
4
NXP Semiconductors
Product data sheet
SYMBOL
IR
IR
ΔVZ
Vn
PARAMETER
reverse current
PLVA6xxA series
CONDITIONS
MIN.
TYP.
MAX.
UNIT
VR = 50% VZ nominal
PLVA650A
34
nA
PLVA653A
22
nA
PLVA656A
1.1
nA
PLVA659A
0.9
nA
PLVA662A
0.9
nA
PLVA665A
0.9
nA
PLVA668A
0.8
nA
PLVA650A
21
μA
PLVA653A
3.5
μA
PLVA656A
1.3
μA
PLVA659A
1.0
μA
PLVA662A
0.05
μA
PLVA665A
0.04
μA
PLVA668A
0.006
μA
reverse current
VR = 90% VZ nominal
line regulation
PLVA659A to PLVA668A
ILO = 10 μA; IHI = 1 mA
0.1
V
PLVA656A
ILO = 50 μA; IHI = 1 mA
0.1
V
PLVA650A
ILO = 100 μA; IHI = 1 mA
0.4
V
PLVA653A
0.2
V
f = 1 kHz; B = 1 kHz; IZ = 250 μA
1.0
μV
-----------Hz
noise voltage density
THERMAL CHARACTERISTICS
SYMBOL
PARAMETER
Rth(j-tp)
thermal resistance from junction to tie-point
Rth(j-a)
thermal resistance from junction to ambient
CONDITIONS
note 1
Note
2004 Jan 14
5
VALUE
UNIT
330
K/W
500
K/W
NXP Semiconductors
Product data sheet
PLVA6xxA series
PACKAGE OUTLINE
Plastic surface-mounted package; 3 leads
SOT23
D
E
B
A
X
HE
v M A
3
Q
A
A1
1
2
e1
bp
c
w M B
Lp
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max.
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.9
0.1
0.48
0.38
0.15
0.09
3.0
2.8
1.4
1.2
1.9
0.95
2.5
2.1
0.45
0.15
0.55
0.45
0.2
0.1
OUTLINE
VERSION
SOT23
2004 Jan 14
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-04
06-03-16
TO-236AB
6
NXP Semiconductors
Product data sheet
PLVA6xxA series
DATA SHEET STATUS
DOCUMENT
STATUS(1)
PRODUCT
STATUS(2)
DEFINITION
Objective data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary data sheet
Qualification
This document contains data from the preliminary specification.
Product data sheet
Production
This document contains the product specification.
Notes
1. Please consult the most recently issued document before initiating or completing a design.
2. The product status of device(s) described in this document may have changed since this document was published
and may differ in case of multiple devices. The latest product status information is available on the Internet at
URL http://www.nxp.com.
above those given in the Characteristics sections of this
document is not implied. Exposure to limiting values for
extended periods may affect device reliability.
DISCLAIMERS
General ⎯ Information in this document is believed to be
accurate and reliable. However, NXP Semiconductors
does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness
of such information and shall have no liability for the
consequences of use of such information.
Terms and conditions of sale ⎯ NXP Semiconductors
products are sold subject to the general terms and
conditions of commercial sale, as published at
http://www.nxp.com/profile/terms, including those
pertaining to warranty, intellectual property rights
infringement and limitation of liability, unless explicitly
otherwise agreed to in writing by NXP Semiconductors. In
case of any inconsistency or conflict between information
in this document and such terms and conditions, the latter
will prevail.
Right to make changes ⎯ NXP Semiconductors
reserves the right to make changes to information
published in this document, including without limitation
specifications and product descriptions, at any time and
without notice. This document supersedes and replaces all
information supplied prior to the publication hereof.
No offer to sell or license ⎯ Nothing in this document
may be interpreted or construed as an offer to sell products
that is open for acceptance or the grant, conveyance or
implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use ⎯ NXP Semiconductors products are
not designed, authorized or warranted to be suitable for
use in medical, military, aircraft, space or life support
equipment, nor in applications where failure or malfunction
of an NXP Semiconductors product can reasonably be
expected to result in personal injury, death or severe
property or environmental damage. NXP Semiconductors
accepts no liability for inclusion and/or use of NXP
Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at
the customer’s own risk.
Export control ⎯ This document as well as the item(s)
described herein may be subject to export control
regulations. Export might require a prior authorization from
national authorities.
Quick reference data ⎯ The Quick reference data is an
extract of the product data given in the Limiting values and
Characteristics sections of this document, and as such is
not complete, exhaustive or legally binding.
Applications ⎯ Applications that are described herein for
any of these products are for illustrative purposes only.
NXP Semiconductors makes no representation or
warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values ⎯ Stress above one or more limiting
values (as defined in the Absolute Maximum Ratings
System of IEC 60134) may cause permanent damage to
the device. Limiting values are stress ratings only and
operation of the device at these or any other conditions
2004 Jan 14
7
NXP Semiconductors
Customer notification
This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal
definitions and disclaimers. No changes were made to the technical content, except for package outline
drawings which were updated to the latest version.
Contact information
For additional information please visit: http://www.nxp.com
For sales offices addresses send e-mail to: salesaddresses@nxp.com
© NXP B.V. 2009
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
R76/03/pp8
Date of release: 2004 Jan 14
Document order number: 9397 750 12445
很抱歉,暂时无法提供与“PLVA659A,215”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1808+0.668351808+0.08070
- 3000+0.530573000+0.06406
- 6000+0.354426000+0.04279
