RC0603JR-070RP
RC0603JR-070RP
    YAGEO(国巨)
    贴片电阻 0603 0Ω ±5% 1/10W
RC0603JR-070RP 数据手册
DATA SHEET LEAD FREE CHIP RESISTORS RC_P series ±0.5%, ±1%, ±5% Product specification – May 11, 2022 V.4 Sizes 0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification Chip Resistor Surface Mount RC_P SERIES SCOPE This specification describes RC series chip resistors with made by thick film process. ORDERING INFORMATION - GLOBAL PART NUMBER APPLICATIONS RC XXXX X X X XX XXXX P  All general purpose application 2 10 0100 to 2512 Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Total lead free without RoHS exemption  Halogen Free Epoxy  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space (2) TOLERANCE D = ± 0.5% F = ± 1.0% J = ± 5.0% ( for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (5) TAPING REEL 07 = 7 inch dia. Reel 13 =13 inch dia. Reel 7N = 7 inch dia. Reel, ESD safe reel (0100 only) 7W = 7 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point. Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter P is lead free (without RoHS exemption) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩ with ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KP. www.yageo.com May. 11, 2022 V.4 Product specification Chip Resistor Surface Mount RC_P 3 10 0100 to 2512 SERIES MARKING RC0100 / RC0201 / RC0402 No Marking ynsc007 Fig. 1 RC0603 03 Fig. 2 E24 series: 3 digits, 5% YNSC001 First two digits for significant figure and 3rd digit for number of zeros Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC1218 / RC2010 / RC2512 00 Fig. 3 E24/E96 series: 4 digits, 1%, 0.5% YNSC004 Value = 10 KΩ First three digits for significant figure and 4th digit for number of zeros Note For further marking information, please see special data sheet "Chip resistors marking". CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added, as shown in Fig.4. Outlines For dimensions, please refer to Table 1 marking layer overcoat primary glass layer resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode H ceramic substrate I2 overcoat I1 W YNSC086 L Fig. 4 Chip resistor outlines www.yageo.com May. 11, 2022 V.4 Product specification Chip Resistor Surface Mount RC_P SERIES 4 10 0100 to 2512 DIMENSION Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 RC0201 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 RC0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 RC0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 RC1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.45±0.20 RC1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC1218 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.55±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.60±0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE POWER Fig. 4 Operating Max. Max. Dielectric Temperature Working Overload Withstanding Range Voltage Voltage Voltage Chip resistor outlines RESISTANCE RANGE Temperature Coefficient of Resistance E24 ± 5% 1Ω ≤ R ≤ 10MΩ 1Ω≤R
RC0603JR-070RP AI解析
物料型号:YAGEO RC_P系列
器件简介:该系列电阻采用厚膜工艺制造,具有无铅和无卤素环氧树脂封装,旨在减少环境危害并提高组件和设备的可靠性。
引脚分配:文档中未明确指出引脚分配,但通常这类表面贴装电阻器有两端的金属电极作为引脚。
参数特性: - 尺寸范围:0100至2512 - 公差:±0.5%,±1%,±5% - 包装类型:纸质胶带卷轴、压花胶带卷轴、防静电安全卷轴 - 温度系数:根据规格书 - 额定功率:不同尺寸的电阻有不同的额定功率,例如RC0100为1/32W,RC0201为1/20W,RC0402有1/16W和1/8W等
功能详解: - 电阻体由高等级陶瓷基板构成,内部金属电极与厚膜电阻元件接触。 - 电阻元件由嵌入玻璃中的贵金属组成,覆盖有第二层玻璃以防止环境影响。 - 电阻通过激光修调至额定电阻值。 - 外部终端为镀锡的镍屏障。
应用信息:适用于所有通用目的应用,包括节省PCB空间和提高组件及设备可靠性。
封装信息:提供了不同尺寸的详细尺寸信息,包括长度、宽度、高度以及内电极尺寸。
电气特性:包括工作温度范围、最大电压、介质耐压、电阻范围、温度系数、跳线标准等。
测试和要求:包括温度系数、高温暴露、耐湿性、湿度、热冲击、短时间过载、板弯曲/弯曲、焊接性等测试条件、程序和要求。
*介绍内容由AI识别生成
RC0603JR-070RP 价格&库存
很抱歉,暂时无法提供与“RC0603JR-070RP”相匹配的价格&库存,您可以联系我们找货
RC0603JR-070RP
  • 50+0.02329
  • 500+0.02096
  • 5000+0.01941
  • 10000+0.01863
  • 30000+0.01785
  • 50000+0.01739
库存:3980
