Adjustable Laser
VLM-650-02 Series
Lead Wire Type
Spring Type
FEATURES:
Industrial Red Dot Laser.
Adjustable focus (Focus range 100mm ~ Infinity) Laser module with APC Driver
Circuit inside, ideal for industrial Laser application.
This module has integrated optic, laser diode, and APC driver circuit.
APC Driver Circuit enables the Laser output power safe and constant.
Includes patented solid brass structure for the best shock resistance and better heat
transfer consideration.
Aspherical plastic lens provides Dot Laser.
Dimensions : Ø 10.5 x 26 mm (Ø 0.413" x 1.023").
Wavelength : 650 nm
Laser power output : LPT - Class II – less than 1mW
LPA - Class IIIa – less than 3mW.
Beam Divergence (Half Angle) : 0.5 mRad
2.6~6 VDC operation.
Connection type : Lead wire / Spring.
APPLICATIONS:
Industrial Red Dot Laser –Adjustable focus function. Ideal for Industrial positioning,
measuring, pointing which would need an focusable beam at specific distances.
Wood processing.
Metal processing.
Stone processing.
Textile industry.
Food industry.
Automotive industry.
Medical science.
@Copyright 2021 Quarton inc.All Rights Reserved.
www.quarton.com
VLM-650-02 Series
OUTLINE DIMENSIONS (UNITS: mm)
Outline (Lead Wire type)
Outline (Spring type)
SPECIFICATIONS
VLM-650-02
SPECIFICATIONS
LPT
1 Dimensions
LPA
SPT
SPA
2 Operating voltage (Vop)
2.6~6 VDC
3 Operating current (Iop)
Less than 35mA Less than 50mA Less than 35mA Less than 50mA
4 Laser power output
5 Laser class
6 Wavelength at peak emission (λp)
Less than 1mW
Less than 3mW
Less than 1mW
Less than 3mW
Class II
Class IIIa
Class II
Class IIIa
645~665nm
7 Collimating lens
8 Output aperture
4mm
9 Beam shape
Ellipse
10 Focus range
100mm ~ Infinity
11 Spot size at 5M
12 Divergence (Half Angle)
13 Beam alignment
14 Operating temp. range*
5±1 mm
0.5 mRad
Less than 3°
+10°C ~+40°C
www.quarton.com
VLM-650-02 Series
15 Storage temp. range
-20°C ~+65°C
16 Housing material
Brass
17 Potential housing**
VDD(+)
18 Electrostatic discharge (ESD)
19 Moisture sensitivity level (MSL)
20 Connection type
21 Cable length
30KV
Level 1 - acc to JEDEC J-STD-020E.
1007-26 AWG
Spring
115±15mm
6.5±1mm
22 Mean time to failure (MTTF) 25°C
10000hrs
23 Application
Focus adjustable
24 Suggestion work distance
1~30 meters / 3~100 feet
* Operation temperature: it means within this temperature range, the laser spot/line will not be affected to change the spot size/line
width. It can still work over this range, but the laser spot size or laser line width will be larger.
** Laser module housing is an electrical positive surface, it is imperative that contact between the laser module and the machine be
avoided. This is to prevent damage from the machine electrical leakage. Surge protected power supply to the laser module is
strongly recommended.
ORDER CODE
Order Code
Wavelength
Laser Power Output
Laser Class
Connection Type
VLM-650-02 LPA
650 nm
Less than 3mW
Class IIIa
Lead Wire
VLM-650-02 LPT
650 nm
Less than 1mW
Class II
Lead Wire
VLM-650-02 SPA
650 nm
Less than 3mW
Class IIIa
Spring
VLM-650-02 SPT
650 nm
Less than 1mW
Class II
Spring
SAFETY LABEL
www.quarton.com
很抱歉,暂时无法提供与“VLM-650-02-LPT”相匹配的价格&库存,您可以联系我们找货
