Industrial Use Line Laser
VLM-635-27 Series
FEATURES:
Industrial Red Line Laser.
The best line-accuracy and the widest emitting angle line Laser module for use with
high-precision devices.
This module has integrated quartz cylindrical lens, collimating lens, laser diode, and
APC driver circuit.
APC driver circuit enables the Laser output power safe and constant.
Includes patented solid brass structure for the best shock resistance and better heat
transfer consideration.
Aspherical Plastic Lens and Quartz Cylindrical Lens provides Line Laser.
Dimensions : Ø 12.5 x 30 mm (Ø 0.492" x 1.181")
Wavelength : 635 nm
Two laser power output : Class 1M / Class 2M
Laser line accuracy: 40" (+/- 1mm @5m).
Emitting Angle : >90°
2.6~6 VDC operation.
Connection type : Lead wire
APPLICATIONS:
High accuracy Red Straight Line Laser, for Industrial high-precision leveling,
alignment, adjusting, positioning, measuring and targeting device.
Wood processing.
Metal processing.
Stone processing.
Textile industry.
Food industry.
Automotive industry.
Medical science.
@Copyright 2021 Quarton inc.All Rights Reserved.
www.quarton.com
VLM-635-27 Series
OUTLINE DIMENSIONS (UNITS: mm)
Outline (Lead Wire type)
SPECIFICATIONS
SPECIFICATIONS
1 Dimensions
VLM-635-27
LPT
LPT-10
2 Operating voltage (Vop)
2.6~6 VDC
3 Operating current (Iop)
Less than 50mA
Less than 55mA
4 Optical power*
Less than 2mW
4~5mW
5 Laser power output**
6 Laser class
Less than 0.39mW
Class 1M
7 Wavelength at peak emission (λp)
630~645nm
8 Collimating lens
Plastic lens
9 Line lens
Plastic lens
10 Beam shape
Line
11 Laser Line width
3 ±0.5mm @5m, 6 ±0.5mm @10m
12 Laser line accuracy
40” (± 1mm @5M)
13 Emitting angle
More than 90°
14 Operating temp. range***
+10°C ~+40°C
15 Storage temp. range
-20°C ~+65°C
16 Housing material
Brass
17 Potential housing****
VDD(+)
www.quarton.com
VLM-635-27 Series
18 Electrostatic discharge (ESD)
30KV
19 Moisture sensitivity level (MSL)
Level 1 - acc to JEDEC J-STD-020E.
20 Wire type
1007-26 AWG
21 Cable length
115±15mm
22 Mean time to failure (MTTF) 25°C
23 Application
10000hrs
General industrial alignment
24 Suggestion work distance
Above 2 meters
* Optical power is total power output measured at the aperture of the laser.
** According to FDA 1040.10 & IEC 60825-1 regulations, laser power output is measured by 7mm aperture stop from a 10
cm distance of the laser.
*** Operation temperature means within this temperature range, the laser spot/line will not be affected
to change the spot
size/line width. It can still work over this range, but the laser spot size or laser line width will be larger.
**** Laser module housing is an electrical positive surface, it is imperative that contact between the laser module and the
machine be avoided. This is to prevent damage from the machine electrical leakage. Surge protected power supply to
the laser module is strongly recommended.
ORDER CODE
Order Code
Wavelength
Optical power*
Laser power
Laser Class
output**
Connection
Type
VLM-635-27 LPT
635 nm
Less than
2mW
Less than
0.39mW
Class 1M
Lead Wire
VLM-635-27 LPT-10
635 nm
4~5mW
Less than
0.39mW
Class 1M
Lead Wire
aperture stop from a 10 cm distance of the laser.
SAFETY LABEL
www.quarton.com
VLM-635-27 Series
www.quarton.com
很抱歉,暂时无法提供与“VLM-650-27-LPT”相匹配的价格&库存,您可以联系我们找货
