Economical Line Laser
VLM-650-28 LPT
FEATURES:
Economical Red Line Laser.
Line-width optimize at short distance(1m) for consumer grade laser line generator
applications.
This module has integrated wavy lens, collimating lens, laser diode, and APC driver
circuit.
APC driver circuit enables the Laser power output safe and constant.
Includes patented solid brass structure for the best shock resistance and better heat
transfer consideration.
Aspherical Plastic Lens and Plastic Wavy Lens provides Line Laser.
Dimensions : Ø 9 x 26 mm (Ø 0.354" x 1.024")
Wavelength : 645~665 nm
Laser power output : LPT - Class 1M - less than 0.39mW.
Laser line accuracy: 80" (± 2mm @5m).
Emitting Angle : > 60°
2.6~6 VDC operation.
Connection type : Lead wire
APPLICATIONS:
Economical Red Line Laser Module, Line-width optimize at short distance(1m) for
consumer grade 3d-Scanner, barcode reader, leveling, alignment, adjusting,
positioning, measuring and targeting device.
Wood processing.
Metal processing.
Stone processing.
Textile industry.
Food industry.
Automotive industry.
Medical science.
@Copyright 2014 Quarton inc.All Rights Reserved.
www.quarton.com
VLM-650-28 LPT
OUTLINE DIMENSIONS (UNITS: mm)
Outline (Lead Wire type)
SPECIFICATIONS
SPECIFICATIONS
1 Dimensions
VLM-650-28 LPT
2 Operating voltage (Vop)
2.6~6 VDC
3 Operating current (Iop)
Less than 35mA
4 Optical power*
Less than 2mW
5 Laser power output**
6 Laser class
Less than 0.39mW
Class 1M
7 Wavelength at peak emission (λp)
645~665nm
8 Collimating lens
Plastic lens
9 Line lens
Plastic lens
10 Beam shape
Line
11 Laser Line width
1.2mm@1m
12 Laser line accuracy
80” (± 2mm @5M)
13 Emitting angle
More than 60°
14 Operating temp. range***
+15°C ~+30°C
15 Storage temp. range
-20°C ~+65°C
16 Housing material
Brass
17 Potential housing****
VDD(+)
www.quarton.com
VLM-650-28 LPT
18 Electrostatic discharge (ESD)
30KV
19 Moisture sensitivity level (MSL)
Level 1 - acc to JEDEC J-STD-020E.
20 Wire type
1007-26 AWG
21 Cable length
115±15mm
22 Mean time to failure (MTTF) 25°C
23 Application
10000hrs
Economic 3D scanner
24 Suggestion work distance
0.3~1.8 meters / 1~6 feet
* Optical power is total power output measured at the aperture of the laser.
** According to FDA 1040.10 & IEC 60825-1 regulations, laser power output is measured by 7mm aperture stop from a 10
cm distance of the laser.
*** Operation temperature means within this temperature range, the laser spot/line will not be affected
to change the spot
size/line width. It can still work over this range, but the laser spot size or laser line width will be larger.
**** Laser module housing is an electrical positive surface, it is imperative that contact between the laser module and the
machine be avoided. This is to prevent damage from the machine electrical leakage. Surge protected power supply to
the laser module is strongly recommended.
ORDER CODE
Order Code
Wavelength
Optical power*
Laser power
Laser Class
output**
VLM-650-28 LPT
650 nm
Less than
2mW
Less than
0.39mW
Connection
Type
Class 1M
Lead Wire
aperture stop from a 10 cm distance of the laser.
SAFETY LABEL
www.quarton.com
很抱歉,暂时无法提供与“VLM-650-28-LPT”相匹配的价格&库存,您可以联系我们找货
