PhotoElectric Sensors
M18 Photoelectric Sensors
Metal / Plastic Barrel
Through Beam
Retroreflective / Diffused
Reflective
Fixed Sensing
Fixed Sensing
Adjustable Sensing Adjustable Sensing
Fixed Sensing
PNP – Normally Open (light on)
PES18C32FPC PES18C32FMC
PES18C32APC
PES18C32AMC PES18C32FPM12
PNP – Normally Closed
PES18C33FPC PES18C33FMC
PES18C33APC
PES18C33AMC PES18C33FPM12
(light off)
PNP – NO / NC (2 outputs)
PES18C38FPC PES18C38FMC
NPN – Normally Open
PES18C22FPC PES18C22FMC
PES18C22APC
PES18C22AMC PES18C22FPM12
PES18C23FPC PES18C23FMC
PES18C23APC
PES18C23AMC PES18C23FPM12
PES18C28FPC PES18C28FMC
(light on)
NPN – Normally Closed
(light off)
NPN – NO / NC (2 outputs)
PES18C38FPM12
PES18C28FPM12
M18 Plastic
M18 Metal
M18 Plastic
M18 Metal
M18 Plastic
3000mm*
3000mm*
2 to 3000mm*
2 to 3000mm*
3000mm*
Housing Material
Plastic
Metal
Plastic
Metal
Plastic
Termination Type
2.0 Meter Cable
2.0 Meter Cable
2.0 Meter Cable
2.0 Meter Cable
M12 Connector
10 to 30Vdc
10 to 30Vdc
10 to 30Vdc
10 to 30Vdc
10 to 30Vdc
250mA
250mA
250mA
250mA
250mA
AC Normally Open (light on)
AC Normally Closed (light off)
Mating cables / connectors
Form
Nominal Sensing Distance (Sn)
Min / Max Supply Voltage
Max. Load Current (Ir)
Max ripple factor (Vr)
Voltage Drop (Ud)
≤ 10%
≤ 2V @ 250mA
≤ 10%
Power Consumption (Io)
Switching Frequency (Hz)
≤ 10%
≤ 2V @ 250mA
≤ 2V @ 250mA
≤ 10%
≤ 2V @ 250mA
很抱歉,暂时无法提供与“PES18C32APC”相匹配的价格&库存,您可以联系我们找货
