engineered to light up your design
www.vcclite.com
1.800.522.5546
5332 Series T-1 3/4 Vertical LED Assembly
Description and Features
Features
• Block mounting design assures height
and side-by-side spacing-alignment
saves assembly costs.
• Ultra Brite T-1 3/4 LED lamp-non-diffused
high intensity light.
• Press-in mounting pin secures assembly
to PC board while beingsoldered.
• Standoffs prevent flux entrapment.
• RoHS Compliant
.450±. 010
.190
.100
.150
.020 S T AND-OF F
F OR P OS T C LE ANING
.020
Housing: Black Nylon, UL94V-O
.100
Note: Alternate LEDs are also available
in this package as a standard variation.
.100
Refer to “Mounting Hole Pattern 3.pdf”
All dimensions in inches.
ÿ. 290
Electro-Optical Characteristics and Ratings
Part Number
5332H1
5332H5
5332H7
Emitted
Colo r
Red
Green
Yellow
Typical
Intensity
(mcd)
68
100
160
Rated
Current
(mA )
Continuous
Forward
CurrentMax.
(mA)
60
60
60
Forward Voltage
Typ.
(V)
Max.
(V)
2.1
2.2
2.2
3.0
3.0
3.0
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
Reverse
Breakdown
VoltageMin.
(V)
5
5
5
Peak
Wavelength
(nm)
650
563
585
Peak Forward
Current at
1MS-300PPS
(A)
1.0
.09
1.0
很抱歉,暂时无法提供与“5332H5”相匹配的价格&库存,您可以联系我们找货
