engineered to light up your design
www.vcclite.com
1.800.522.5546
5640 Series T-1 3/4 Right Angle 4 Wide LED Assembly
Description and Features
All dimensions
in inches.
.990
.210
MAX.
.350
.250 TYP.
.240
.200
.130
.020
.130 MIN.
.200
.100 TYP.
ANODE(+)
CATHODE(-)
.250 TYP.
The user who may have a requirement calling for various
color / electrical specifications , a part number can be determined
by referring to the chart shown below.
Model No. is as follows: 5640H
Pos. 1
Pos. 2
Pos. 3
Features
•Quad assembly with 4 LEDs permits
easy installation-assures matched
height and center to center spacing,
reduces assembly time and costs .
•Super Brite LEDs
•High contrast ratio.
•Low current - only 2mA
•Built-in resistor chips - operates off
5 volt or 12 volt supply without
external resistor.
•Standoffs prevent flux entrapment.
•RoHS Compliant
Housing: Black Nylon, UL94V-O
Refer to “Mounting Hole Pattern 4.pdf”
Pos. 4
When specifying all 4 LEDs of the same type Example: 4 each 5 volt red LEDs, the part number is 5640H1-5V
When specifying a variety of colors Example: Position 1 is green, position 2 is red, position 3 is yellow, position 4 is amber. All standard voltage.
The part number is 5640H5;1;7;3.
Alternate LEDs are also available in this package as a standard variation.
Electro-Optical Characteristics and Ratings
Part Number
1
3
5
7
1LC
5LC
7LC
1-5V
3-5V
5-5V
1-12V
LED
Emitted
Color
Red
Amber
Green
Yellow
Red
Green
Yellow
Red
Amber
Green
Red
Red
1
Typical
Intensity
(mcd)
Rated
Current
(mA)
Continuous
Forward
Current Max.
(mA)
6.3
10.0
10.0
6.3
2.3
2.3
2.1
8
8
8
8
10
10
10
10
2.0
2.0
2.0
10
10
12
12
35.0
35.0
30.0
35.0
7.0
7.0
7.0
15.0
15.0
15.0
Amber
3
Green
5
Yellow
7
Forward Voltage
Typ.
(V)
Max.
(V)
Reverse
Breakdown
Voltage Min.(V)
Peak
Wavelength
(nm)
2.0
2.0
2.2
2.1
1.8
1.8
1.9
5.0
5.0
5.0
12
3.0
3.0
3.0
3.0
2.7
2.2
2.7
7.5
7.5
7.5
15.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
650
608
563
585
635
565
583
635
583
565
635
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“5640H5”相匹配的价格&库存,您可以联系我们找货
