8
D
5
6
7
4
MOISTURE
SEAL
C
2
3
NOTES:
1.
ROHS COMPLIANT
2.
MATERIAL:
LIGHTPIPE - ACRYLIC (CLEAR OPTICAL GRADE), UL 94-HB
LENS - POLYCARBONATE, UL 94-V2
SEAL - EPDM
RETAINING RING - POLYPROPYLENE (BLACK)
3.
MOUNTING: MOUNTS IN A .171" .002 [ 4.34mm .05] PANEL HOLE ON
.250" [6.35mm] CENTER
4.
PANEL HOLE SHALL BE DEBURRED, BUT NOT CHAMFERED
5.
PANEL THICKNESS: .031" [.8mm] TO .094" [2.39mm]
6.
ASSEMBLY:
A.) INSERT LITEPIPE THROUGH PANEL HOLE
B.) PRESS ON RETAINING RING TO SECURE UNIT TO PANEL
C.) SLIDE PCB INTO POSITION ALIGNING LED WITH END OF LITEPIPE UNIT
7.
U.S AND FOREIGN PATENTS ISSUED
1
REVISIONS
ECN #
REV.
DESCRIPTION
DATE
INITIALS
CHK'D
391
000
INITIAL RELEASE
2/20/12
KH
AZ
D
.170in
4.32mm
RETAINING
RING
.125in
3.16mm
.193in
4.91mm
C
.240in
6.10mm
B
B
.080in
2.03mm
.XXX
ORDERING CODE: LSS XXX XXX
LITEPIPE
A
LENS
XXX =
LENGTH
XXX =
COLOR
024
.240" (6.10mm)
RTP
RED TRANSPARENT
044
.440" (11.18mm)
ATP
AMBER TRANSPARENT
064
.640" (16.26mm)
084
.840" (21.34mm)
104
1.04" (26.4mm)
124
1.24" (31.5mm)
CUSTOM LENGTHS
AVAILABLE UPON
REQUEST
8
GTP
BTP
GREEN TRANSPARENT
BLUE TRANSPARENT
YTP
YELLOW TRANSPARENT
CTP
7
LENS
LITEPIPE
LED
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
DISPLAY
PANEL
GAP
.050"
PCB
RNG 132
RETAINING RING
INCHES
.020
.010
.005
ANGLE 1'
MM
.508
.254
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
DATE
KHOWARD
2/20/12
CHECKED
AZANELLI
3/6/12
12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A
PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
ASSY, 3MM MOISTURE
SEALED LITEPIPE
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
5
APPROVAL
DRAWN
SEE NOTES
ASSEMBLY
CLEAR TRANSPARENT
6
.X
.XX
.XXX
4
3
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 8:1
DO NOT SCALE DRAWING
2
000
LSS XXX XXX
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“LSS_024_ATP”相匹配的价格&库存,您可以联系我们找货
