8
7
5
6
4
1.
2.
D
3.
4.
5.
6.
7.
8.
2
3
1
REVISIONS
NOTES:
ROHS COMPLIANT
MATERIALS:
FIBER OPTIC:
1.5MM OPTICAL CORE, 2.2MM POLYETHYLENE
CABLE JACKET
LENS MOUNT: OPTICAL GRADE ACRYLIC
LED MOUNTS: FOR SMD 22 & THR 22 - NYLON 66, UL RATING 94-V2
FOR THR 5 22 - NYLON 66, UL RATING 94-HB
LENS: POLYCARBONATE UL RATING 94-V2
LENS RETAINING RING: POLYPROPYLENE
LENS SEAL: TPE
OPTICAL CORE ENDS POLISHED TO 10 MICRONS
MOUNTS THROUGH FRONT OF PANEL. COMPRESSION OF THE SEAL
IS ACCOMPLISHED BY PRESSING THE RETAINING RING IN PLACE
LENSES MOUNT THROUGH A 9/32" (7.12mm) HOLE ON 3/8" (9.52mm) CENTERS
PANEL THICKNESS 1/32" (0.79mm)TO 1/8" (3.18mm)
FOR BEST RESULTS USE ONLY NARROW VIEWING ANGLE NON-DIFFUSED LEDS
WITH OUTPUT POWER GREATER THAN 100mcd
U.S. AND FOREIGN PAT. ISSUED
ECN #
REV.
DESCRIPTION
DATE
396
001
002
003
004
INITIAL RELEASE
DWG FORMAT UPDATE
REVISED PER ECR 092810AA01
REVISED PER ECR 011812KH01
7/8/09
8/2/10
10/4/10
1/20/12
INITIALS CHK'D
SMU
KH
KH
KH
AZ
AZ
AZ
AZ
D
LITE PIPE ASSEMBLY
ORDERING CODE (EXAMPLE): FLX
322 XXX XX
LENS COLOR
RED TRANSPARENT
AMBER TRANSPARENT
GREEN TRANSPARENT
BLUE TRANSPARENT
YELLOW TRANSPARENT
CLEAR TRANSPARENT
WHITE TRANSLUCENT
LENS TYPE CODE
RTP
ATP
GTP
BTP
YTP
CTP
GLO
CMS 322, LOW PROFILE FRESNEL LENS
WITH MOISTURE SEAL AND RETAINING
RING. MEETS NEMA 4 RATING.
322
C
MOUNTING OPTIONS
(ORDER SEPARATELY)
FIBER LENGTH
CODE
02
2.0"
04
4.0"
6.0"
06
08
8.0"
12
12.0"
CUSTOM LENGTHS
AVAILABLE UPON
REQUEST
C
LENS MOUNT
FIBER OPTIC
SMD 22
SEAL
RETAINING RING
LENS
B
B
.06in±.02
1.52mm±0.51
FIBER OPTIC LENGTH XX .25
THR 22
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
A
.X
.XX
.XXX
THR 5 22
63
INCHES
.020
.010
.005
ANGLE 1'
MM
.508
.254
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
APPROVAL
DATE
DRAWN
KHOWARD
8/2/10
CHECKED
AZANELLI
8/2/10
OPTOELECTRONICS
190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA
Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com
TITLE:
MATERIAL
SEE NOTES
FLX 322 FLEXFIRE
FLEXIBLE LITEPIPE
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
8
7
6
5
4
3
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 2:1
DO NOT SCALE DRAWING
2
FLX 322 XXX XX
004
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“FLX_322_YTP_02”相匹配的价格&库存,您可以联系我们找货
