5400 Series Ø 0.315" (8.0 mm)
Panel Mount LED Indicator
A unique design, the 5400 Series is a two-piece unit
consisting of a lens and the housing-LED assembly.
Simple, fast installation.
Available in 4 colors: Red, Amber, Green and Yellow.
Applications
• Industrial
• People Movers
• Electro medical devices and systems
• Appliances
• Transportation and Infrastructures
• Food Services and Industries
Key Features
• Simple and fast installation
• Low profile, damage-resistant lens
• Discharge protection
8 mm panel mounting LED Indicator
5 mm colored polycarbonate lens
Unique design in a two piece unit
Wide-angle viewing
Installation Instructions
The panel mount LED indicator light consists of one lens and one body in lead wires terminations.
The fast installation is provided by inserting the lens into mounting hole in the front display panel
and snapping the housing assembly onto the lens from the rear.
Allows pre-wiring into the circuit and testing before installation.
Product Specifications
Installation and Operating Specifications
Material
Housing
Natural Nylon
Mounting Hole
Lens
Polycarbonate
Panel Thickness
Wire Leads
24 AWG PVC (105o C)
4.4/4.8” long, stripped
.430/.570”
engineered to light up your design
Operating Temperature
Anode (+)
www.vcclite.com
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
.312/.317”
(7.9/8.1mm)
.062 to .125”
(1.6 to 3.2 mm)
-25 oC/+85 oC
-13 oF/+185 oF
Red Lead
1.800.522.5546
08/15 Rev 1
Product Dimensions
Body:
Lens:
.910 MAX
[23.1 MAX]
.380
Ø [9.7]
Low Profile
PANEL
LIGHT
DIFFUSING
RINGS
Lens
.030
[0.7]
.330
[8.4]
Ø .380
[9.7]
.680 Ref.
[17.3 Ref.]
Ø.270
[6.9]
Ø.310
[7.9]
.090
[2.3]
All dimensions in inches [mm]
Ordering Data
Electro-optical Characteristics
Part Number
Color
Typ. Intensity
(mcd)
Rated
Current (mA)
Continuous
Forward
Current Max. (mA)
Forward
Voltage
Typ. (V)
Forward
Voltage
Max. (V)
Current @ 1msReverse
Peak Forward
Break-down
300pps (A)
Voltage Min. (V)
Include
Lens
Model No.
5400A1
Red
120
2.0
3.0
1.0
5
4741
5400A3
Amber
120
2.0
3.0
1.0
5
4743
5400A5
Green
120
2.5
4
4745
5400A7
Yellow
120
2.1
3.0
1.0
5
4747
Compliance & approvals
www.vcclite.com
1.800.522.5546
08/15 Rev 1
很抱歉,暂时无法提供与“5400A5”相匹配的价格&库存,您可以联系我们找货
