1PGSMC5348 – 1PGSMC5369
Taiwan Semiconductor
5W, 11V - 51V Surface Mount Zener Diode
FEATURES
KEY PARAMETERS
Photo Glass passivated chip junction
Ideal for automated placement
Low inductance
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
VZ
11 - 51
V
PD
5
W
TJ MAX
175
°C
Package
DO-214AB (SMC)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.210g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
DC power dissipation at TL = 75°C, measure at zero lead
length (Note 1) derate above 75°C
Junction temperature
SYMBOL
VALUE
UNIT
PD
5
W
TJ
-55 to +175
°C
TSTG
-55 to +175
°C
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
°C/W
Junction-to-ambient thermal resistance
RӨJA
55
°C/W
Junction-to-case thermal resistance
RӨJC
22
°C/W
Storage temperature
Notes:
1. Mounted on 16mm x 16mm Cu pad test board
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: Units mounted on PCB (16mm x 16mm Cu pad test board)
1
Version: D2102
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Device
Marking
Code
Device
(Note 1)
Nominal Zener
Voltage
Test
Leakage Maximum DC
Zener Impedance
Current
Current Zener Current
VZ @ IZT
V
Min
Nom
Max
IZT
mA
ZZT @ IZT
Ω
ZZK @ IZK
Ω
mA
IR @ VR
μA
V
IZM
mA
1PGSMC5348
P348B
10.45
11
11.55
125
3
125
1
5
8.4
430
1PGSMC5349
P349B
11.40
12
12.60
100
3
150
1
2
9.1
395
1PGSMC5350
P350B
12.35
13
13.65
100
3
150
1
1
9.9
365
1PGSMC5351
P351B
13.30
14
14.70
100
3
150
1
1
10.6
345
1PGSMC5352
P352B
14.25
15
15.75
75
3
150
1
1
11.5
315
1PGSMC5353
P353B
15.20
16
16.80
75
3
150
1
1
12.2
295
1PGSMC5354
P354B
16.15
17
17.85
70
3
150
1
0.5
12.9
280
1PGSMC5355
P355B
17.10
18
18.90
65
3
150
1
0.5
13.7
264
1PGSMC5356
P356B
18.05
19
19.95
65
3
150
1
0.5
14.4
250
1PGSMC5357
P357B
19.00
65
3
150
1
0.5
15.2
237
1PGSMC5358
P358B
20.90
22
23.10
50
4
150
1
0.5
16.7
216
1PGSMC5359
P359B
22.80
24
25.20
50
4
180
1
0.5
18.2
198
1PGSMC5360
P360B
23.75
25
26.25
50
4
180
1
0.5
19.0
190
1PGSMC5361
P361B
25.65
27
28.35
50
5
180
1
0.5
20.6
176
1PGSMC5362
P362B
26.60
28
29.40
50
6
180
1
0.5
21.2
170
1PGSMC5363
P363B
28.50
30
31.50
40
8
180
1
0.5
22.8
158
1PGSMC5364
P364B
31.35
33
34.65
40
10
180
1
0.5
25.1
144
1PGSMC5365
P365B
34.20
36
37.80
30
11
200
1
0.5
27.4
132
1PGSMC5366
P366B
37.05
39
40.95
30
14
200
1
0.5
29.7
122
1PGSMC5367
P367B
40.85
43
45.15
30
1
0.5
32.7
110
1PGSMC5368
P368B
44.65
47
49.35
25
25
200
1
0.5
35.8
100
1PGSMC5369
P369B
48.45
51
53.55
25
27
200
1
0.5
38.8
93
Notes:
1. Tolerance and type number designation the type numbers listed indicate a tolerance of 5%
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
1PGSMC53x
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 11V(1PGSMC5348) to 51V(1PGSMC5369)
2
Version: D2102
CHARACTERISTICS CURVES
Fig.1 Steady State Power Derating
Fig.2 Typical Junction Capacitance
6
1000
1PGSMC5349
4
CAPACITANCE (pF)
PD - Power Dissipation (W)
5
3
2
1
1PGSMC5359
100
1PGSMC5366
1PGSMC5369
Heat sink
16mm x 16mm
Cu pad test board
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
150
1
175
10
100
REVERSE VOLTAGE (V)
LEAD TEMPERATURE (°C)
Fig.3 Typical Zener Impedance
Zz - DYNAMIC IMPEDANCE (Ω)
1000
100
1PGSMC5349
10
1PGSMC5359
1PGSMC5366
1
1PGSMC5369
0.1
1
10
100
1000
Iz - ZENER TEST CURRENT (mA)
3
Version: D2102
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: D2102
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for
application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to any
intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for
such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale
and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability,
or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers
using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for
any damages resulting from such improper use or sale.
5
Version: D2102
很抱歉,暂时无法提供与“1PGSMC5369HR7G”相匹配的价格&库存,您可以联系我们找货
