SRAF10100HC0G
SRAF10100HC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE SCHOTTKY 100V 10A ITO220AC
SRAF10100HC0G 数据手册
SRAF1020 – SRAF10150 Taiwan Semiconductor 10A, 20V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for over-voltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 10 A VRRM 20 - 150 V IFSM 200 A TJ MAX 125, 150 °C Package ITO-220AC Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage Junction temperature Storage temperature SRAF 1020 SRAF 1020 SRAF 1030 SRAF 1030 SRAF 1040 SRAF 1040 SRAF 1050 SRAF 1050 SRAF 1060 SRAF 1060 VRRM 20 30 40 50 60 90 100 150 V VR(RMS) 14 21 28 35 42 63 70 105 V SYMBOL SRAF SRAF SRAF UNIT 1090 10100 10150 SRAF SRAF SRAF 1090 10100 10150 IF 10 A IFSM 200 A dv/dt 10,000 V/µs TJ -55 to +125 -55 to +150 TSTG -55 to +150 1 °C °C Version: I2105 SRAF1020 – SRAF10150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 4 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SRAF1020 SRAF1030 SRAF1040 SRAF1050 SRAF1060 SRAF1090 SRAF10100 SRAF10150 SRAF1020 SRAF1030 SRAF1040 SRAF1050 SRAF1060 SRAF1090 SRAF10100 SRAF10150 SRAF1020 SRAF1030 SRAF1040 SRAF1050 SRAF1060 SRAF1090 SRAF10100 SRAF10150 SRAF1020 SRAF1030 SRAF1040 SRAF1050 SRAF1060 SRAF1090 SRAF10100 SRAF10150 IF = 10A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.85 V - 0.95 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SRAF10x ITO-220AC 50 / Tube SRAF10xH ITO-220AC 50 / Tube Notes: 1. “x” defines voltage from 20V(SRAF1020) to 150V(SRAF10150) 2. “H” means AEC-Q101 qualified 2 Version: I2105 SRAF1020 – SRAF10150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SRAF1050-10150 10 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 12 8 6 SRAF1020-1040 4 SRAF1020-1040 1000 SRAF1050-1060 SRAF1090-10150 2 f=1.0MHz Vsig=50mVp-p 100 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) 1 TJ=25°C 0.01 20 30 40 50 60 70 80 90 100 10 10 SRAF1020-1040 1 UF1DLW TJ=125°C SRAF1050-1060 TJ=25°C 10.1 (A) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C SRAF1090-10100 0.01 SRAF10150 0.1 0.001 0.1 0.2 0.3 0.4 0.3 0.4 0.5 Pulse width 300μs 1% duty cycle Pulse width 0.5 0.6 0.6 0.7 0.8 0.9 1 0.7 0.8 0.9 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 220 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 0.1 10 200 180 160 140 120 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2105 1.2 SRAF1020 – SRAF10150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: I2105 SRAF1020 – SRAF10150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: I2105 SRAF1020 – SRAF10150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2105
SRAF10100HC0G 价格&库存
很抱歉,暂时无法提供与“SRAF10100HC0G”相匹配的价格&库存,您可以联系我们找货
