UGF2004G – UGF2008G
Taiwan Semiconductor
20A, 200V - 600V Ultra Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, low VF
High current capability
High surge current capability
Low power loss
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
A
VRRM
200 - 600
V
IFSM
150
A
TJ MAX
150, 175
°C
Package
ITO-220AB
Configuration
Dual dies
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
UGF
UGF
UGF
UGF
UGF
2004G 2005G 2006G 2007G 2008G
UGF
UGF
UGF
UGF
UGF
2004G
2005G
2006G
2007G
2008G
UNIT
Repetitive peak reverse voltage
VRRM
200
300
400
500
600
V
Reverse voltage, total rms value
VR(RMS)
140
210
280
350
420
V
Forward current
Surge peak forward current, 8.3ms single
half sine wave superimposed on rated load
Junction temperature
IF
A
IFSM
150
A
TJ
-55 to +175
-55 to +150
°C
Storage temperature
TSTG
-55 to +175
-55 to +150
°C
1
Version: C2105
UGF2004G – UGF2008G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
2
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
UGF2004G
UGF2005G
(1)
Forward voltage per diode
UGF2006G IF = 10A, TJ = 25°C
VF
UGF2007G
UGF2008G
Reverse current @ rated VR per diode
(2)
TJ = 25°C
TJ = 125°C
IR
TYP
MAX
UNIT
0.95
V
1.25
V
1.70
V
5
µA
100
µA
ns
25
ns
UGF2004G
UGF2005G
Reverse recovery time
UGF2006G
UGF2007G
IF = 0.5A , IR = 1.0A
Irr = 0.25A
UGF2008G
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
UGF20xG
ITO-220AB
50 / Tube
UGF20xGH
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 200V(UGF2004G) to 600V(UGF2008G)
2. “H” means AEC-Q101 qualified
2
Version: C2105
UGF2004G – UGF2008G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
UGF2004G-06G
CAPACITANCE (pF)
16
12
UGF2007G-08G
8
10
4
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
150
1
175
10
CASE TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=125°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
100 10
10
UF1DLW
1
TJ=125°C
TJ=125°C
TJ=25°C
TJ=25°C
0.1
1
UGF2004G
UGF2005G-06G
UGF2007G-08G
Pulse width
300μs
Pulse
width
1% duty cycle
0.01
0.1
0.001
0.2 0.30.4 0.4
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.8
0.5
1.0
0.6
1.2
0.7 1.4
0.8 1.60.91.8 1 2.0 1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
175
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
1
100
REVERSE VOLTAGE (V)
150
8.3ms single half sine wave
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
(A)
AVERAGE FORWARD CURRENT (A)
24
Version: C2105
1.2
UGF2004G – UGF2008G
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: C2105
UGF2004G – UGF2008G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: C2105
很抱歉,暂时无法提供与“UGF2007GHC0G”相匹配的价格&库存,您可以联系我们找货
