EABS1D – EABS1J
Taiwan Semiconductor
1A, 200V - 600V Super Fast Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Ideal for automated placement, for compact PCB design
High surge current capability
Super fast reverse recovery time for high frequency
Negligible leakage current
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
200 - 600
V
IFSM
40
A
TJ MAX
150
°C
Package
ABS
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: ABS
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.090g (approximately)
ABS
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
EABS1D
EABS1G
EABS1J
EABS1D
EABS1G
EABS1J
UNIT
Repetitive peak reverse voltage
VRRM
200
400
600
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
V
Forward current
Peak forward surge current, 8.3ms single
half sine-wave superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“EABS1GHRGG”相匹配的价格&库存,您可以联系我们找货
