TSF30U100C – TSF30U120C
Taiwan Semiconductor
30A, 100V - 120V Low VF Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ high efficiency
High forward surge capability
Compliant RoHS
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
100 -120
V
IFSM
160
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 0.56 N⋅m maximum
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSF30U100C TSF30U120C UNIT
TSF30U100C
TSF30U120C
Repetitive peak reverse voltage
VRRM
100
120
V
Reverse voltage, total rms value
VR(RMS)
70
84
V
Isolation voltage from terminal to heatsink t = 1 min
VAC
1500
V
Forward current
Surge peak forward current, 8.3ms single half sinewave superimposed on rated load
Critical rate of rise of off-state voltage
IF
30
A
IFSM
160
A
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: E2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TSF30U100C
Junction-to-case thermal resistance
TSF30U120C
RӨJC
TYP
UNIT
2.5
°C/W
3.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per diode
CONDITIONS
(1)
TSF30U100C
TSF30U120C
TSF30U100C
TSF30U120C
TSF30U100C
TSF30U120C
TSF30U100C
TSF30U120C
TSF30U100C
TSF30U120C
TSF30U100C
TSF30U120C
Reverse current @ rated VR per diode
(2)
SYMBOL
IF = 5A, TJ = 25°C
IF = 7.5A, TJ = 25°C
IF = 15A, TJ = 25°C
VF
IF = 5A, TJ = 125°C
IF = 7.5A, TJ = 125°C
IF = 15A, TJ = 125°C
TJ = 25°C
TJ = 125°C
IR
TYP
0.52
0.56
0.56
0.65
0.66
0.78
0.44
0.49
0.51
0.56
0.60
0.65
MAX
0.74
0.88
0.67
0.75
UNIT
V
V
V
V
V
V
V
V
V
V
V
V
500
µA
35
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TSF30UxC
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 100V(TSF30U100C) to 120V(TSF30U120C)
2
Version: E2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
TSF30U100C
25
TSF30U120C
15
10
TSF30U100C
TSF30U120C
100
5
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
10
INSTANTANEOUS REVERSE CURRENT (mA)
INSTANTANEOUS FORWARD CURRENT (A)
100
10
40
50
60
70
100
Fig.4 Typical Forward Characteristics
80
90
100
100 10
TSF30U100C
10
TJ=150°C
UF1DLW
1
TJ=125°C
TJ=125°C
0.1
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.1
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.3
0.4
0.5
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1
1.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
Fig.6 Typical Forward Characteristics
Fig.3 Typical Reverse Characteristics
TSF30U100C
10
REVERSE VOLTAGE (V)
100
TSF30U120C
10
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
TJ=25°C
0.001
0.0001
10
40
50
60
70
80
90 100
3
1.1
1.2
1.1
1.2
100 10
TSF30U120C
10
UF1DLW
TJ=150°C
1
TJ=125°C
TJ=125°C
0.1
TJ=25°C
TJ=25°C
1
TJ=100°C
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.1
0.3
(A)
(A)
30
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
35
0.3
0.4
0.5
0.7
0.5
0.6 VOLTAGE
0.7
0.8
FORWARD
(V)
0.9
0.9
1.1
1
Version: E2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: E2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: E2105
很抱歉,暂时无法提供与“TSF30U120C C0G”相匹配的价格&库存,您可以联系我们找货
