TAI-TECH
KBM01-171100472 P1.
Ferrite Chip Inductor(Lead Free)
FCI2012F-SERIES
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
楊祥忠
羅培君
張嘉玲
楊祥忠
羅培君
張嘉玲
1.0
13/06/06 變更可靠度條件
2.0
14/01/24
3.0
14/08/01 變更 Reflow 圖示
楊祥忠
羅培君
張嘉玲
3.1
14/08/01 修正包裝帶尺寸
楊祥忠
羅培君
張嘉玲
4.0
16/01/26
楊祥忠
詹偉特
張嘉玲
5.0
17/02/16 修訂 Recommended PC Board Pattern
楊祥忠
詹偉特
張嘉玲
變更電鍍錫層厚度
3.0um min.=>3.5um min.
修訂可靠度 Life Test:
(Inductor) Temperature:85±2℃105±2℃.
備
註
www.tai-tech.com.tw
TAI-TECH
KBM01-171100472
P2.
FCI2012F-SERIES
1.Features
1. Monolithic inorganic material construction.
2. Closed magnetic circuit avoids crosstalk.
3. S.M.T. type.
4. Suitable for reflow soldering.
5. Shapes and dimensions follow E.I.A. spec.
6. Available in various sizes.
7. Excellent solder ability and heat resistance.
8. High reliability.
9.100% Lead(Pb) & Halogen-Free and RoHS compliant.
Halogen
Pb
Halogen-free
Pb-free
2. Dimensions
Chip Size
A
2.00±0.20
B
1.25±0.20
C
0.85±0.20
D
3. Part Numbering
FCI
2012
F
A
B
C
A: Series
B: Dimension
C: Material
D: Inductance
E: Inductance Tolerance
1.25±0.20
0.50±0.30
Units: mm
100
K
D
E
LxW
Lead Free Material
100=10.0uH
K=±10%, M=±20%
4.Specification
Tai-Tech
Thickness
Inductance(uH)
Rated Current
DCR
SRF
min.
Test Frequency
(MHz)
Q
(mA) max.
(Ω) max.
(MHz) min.
Part Number
C size(mm)
Tolerance
Test
Frequency (Hz)
FCI2012F-47N□
0.85±0.20
0.047
60mV / 50M
15
50
300
0.20
320
FCI2012F-68N□
0.85±0.20
0.068
60mV / 50M
15
50
300
0.20
280
FCI2012F-82N□
0.85±0.20
0.082
60mV / 50M
15
50
300
0.20
255
FCI2012F-R10□
0.85±0.20
0.10
60mV / 25M
250
0.30
235
FCI2012F-R12□
0.85±0.20
0.12
60mV / 25M
250
0.30
220
FCI2012F-R15□
0.85±0.20
0.15
60mV / 25M
250
0.40
200
FCI2012F-R18□
0.85±0.20
0.18
60mV / 25M
250
0.40
185
FCI2012F-R22□
0.85±0.20
0.22
60mV / 25M
250
0.50
170
FCI2012F-R27□
0.85±0.20
0.27
60mV / 25M
250
0.50
150
FCI2012F-R33□
0.85±0.20
0.33
60mV / 25M
250
0.55
145
FCI2012F-R39□
0.85±0.20
0.39
60mV / 25M
25
25
200
0.65
135
FCI2012F-R47□
1.25±0.20
0.47
60mV / 25M
25
25
200
0.65
125
FCI2012F-R56□
1.25±0.20
0.56
60mV / 25M
25
25
150
0.75
115
FCI2012F-R68□
1.25±0.20
0.68
60mV / 25M
25
25
150
0.80
105
NOTE: □:TOLERANCE
K=±10%, L=±15%, M=±20%
www.tai-tech.com.tw
TAI-TECH
KBM01-171100472
Tai-Tech
Thickness
Rated Current
DCR
SRF
Part Number
C size(mm)
Tolerance
Test
Frequency (Hz)
min.
Test Frequency
(MHz)
(mA) max.
(Ω) max.
(MHz) min.
FCI2012F-1R0□
0.85±0.20
1.0
60mV / 10M
FCI2012F-1R5□
0.85±0.20
45
10
50
0.40
75
1.5
FCI2012F-1R8□
0.85±0.20
1.8
60mV / 10M
45
10
50
0.50
60
60mV / 10M
45
10
50
0.60
55
FCI2012F-2R2□
0.85±0.20
FCI2012F-2R7□
1.25±0.20
2.2
60mV / 10M
45
10
30
0.65
50
2.7
60mV / 10M
45
10
30
0.75
45
FCI2012F-3R3□
FCI2012F-4R7□
1.25±0.20
3.3
60mV / 10M
45
10
30
0.80
41
1.25±0.20
4.7
60mV / 10M
45
10
30
1.00
35
FCI2012F-100□
1.25±0.20
10.0
60mV / 2M
45
2
15
1.15
24
NOTE: □:TOLERANCE
Inductance(uH)
Q
P3.
Rated current: based on temperature rise test
In compliance with EIA 595
www.tai-tech.com.tw
TAI-TECH
KBM01-171100472 P4.
5. Reliability and Test Condition
Item
Series No.
Performance
FCI
FHI
Test Condition
FCH
HCI
-40~+105℃
(Including self-temperature rise)
Operating Temperature
-40~+105℃
(on board)
Transportation
Storage Temperature
For long storage conditions, please see the
Application Notice
Agilent4291
Inductance (Ls)
Agilent E4991
Agilent4287
Q Factor
Refer to standard electrical characteristics list
Agilent16192
DC Resistance
Agilent 4338
Rated Current
DC Power Supply
Over Rated Current requirements, there will be
some risk
Temperature Rise Test
1. Applied the allowed DC current.
2. Temperature measured by digital surface
thermometer.
Rated Current < 1A ΔT 20℃Max
Rated Current ≧ 1A ΔT 40℃Max
Life test
Appearance: no damage.
Impedance: within±15%of initial value.
Inductance: within±10%of initial value.
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not exceed the specification value
Load Humidity
Thermal shock
Preconditioning: Run through IR reflow for 2
times.( IPC/JEDEC J-STD-020D Classification
Reflow Profiles)
Temperature: 105±2℃
Applied current: rated current.
Duration: 1000±12hrs.
Measured at room temperature after placing
for 24±2 hrs.
Reflow Profiles)
Humidity: 85±2%R.H.
Temperature: 85±2℃.
Duration: 1000hrs Min. with 100% rated
current.
for 24±2 hrs.
Reflow Profiles)
Condition for 1 cycle
Step1: -40±2℃
30±5 min.
Step2: 25±2℃
≦0.5min
Step3: +105±2℃
30±5min.
Number of cycles: 500
for 24±2 hrs.
Vibration
Appearance:No damage.
Impedance:within±15% of initial value
Inductance:within±10% of initial value
Reflow Profiles)
Oscillation Frequency: 10 ~ 2K ~ 10Hz for 20
minutes
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles
each of 3 orientations)。
Bending
Impedance:within±10% of initial value
Shall be mounted on a FR4 substrate of the
following dimensions:
>=0805inch(2012mm):40x100x1.2mm
=0805inch(2012mm):1.2mm
1GΩ
More than 95% of the terminal electrode should be covered with solder.
www.tai-tech.com.tw
Preheat: 150℃,60sec.
Solder: Sn96.5%-Ag3%-Cu0.5%
Solder temperature: 245±5℃
Flux for lead free: Rosin. 9.5%
Depth: completely cover the termination.
Dip time: 4±1sec.
TAI-TECH
KBM01-171100472 P5.
Item
Performance
Test Condition
Number of heat cycles: 1
Resistance to Soldering
Heat
Temperature
(°C)
Time
(s)
Temperature
ramp/immersion
and emersion rate
260 ±5
(solder temp)
10 ±1
25mm/s ±6 mm/s
Terminal strength
Reflow Profiles)
Component mounted on a PCB apply a force
>0805inch(2012mm):1kg
很抱歉,暂时无法提供与“FCI2012F-R33K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12384
- 200+0.09833
- 600+0.08415
